Old July 6th, 2009, 07:54 AM   #41
speedgsx98
Motorcycle(s): 250 ninja 2002, 2008 ZX10-R
Last time I took mine apart, I rolled a piece of sandpaper up real small, and sanded the holes on the fairing where the windscreen mounts. I also, sanded the black plastic 'nuts' that the windscreen bolts mount too. I then used gorilla glue and glued them in. Now I can change windscreens in 90 seconds =)
90 EX250 Ninja, 92 FZR600, 86 CR125, 77 GS750, 73 RD350, 86 CR250, RD350 in SRX250 frame, 75 RD350, 99 RM125, 99 GSXR750, 07 Reflex, 02 250 Ninja, 02 GSXR1k, 08 ZX10R, 07 250 Ninja, 05 250 ninja
speedgsx98 is offline   Reply With Quote
Old July 6th, 2009, 09:50 PM   #42
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
I'm planning on doing the same thing with my windscreen bolts once I get a new front fairing.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old July 7th, 2009, 06:20 PM   #43
JCCJMM_
JCCJMM_'s Avatar
Motorcycle(s): 2007 EX250
Gluing the windscreen screw inserts should be a classic top 10!
JCCJMM_ is offline   Reply With Quote
Old July 7th, 2009, 07:46 PM   #44
minuslars
Motorcycle(s): '03 EX250
Polycarbonate / Lexan vs. Acrylic windshields...
The Zero Gravity double bubble is acrylic.
Last futzed with by Alex; July 7th, 2009 at 07:58 PM. Reason: embedded the video
minuslars is offline   Reply With Quote
Old July 7th, 2009, 07:56 PM   #45
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
http://www.youtube.com/watch?v=Hsls5ZPCUnE
sweet video!
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old July 7th, 2009, 09:12 PM   #46
JCCJMM_
JCCJMM_'s Avatar
Hope nobody throws rocks at, or hits my DB with a bat!
Old July 8th, 2009, 12:08 AM   #47
Verus Cidere
I don't think it's all that big a deal really. I doubt that stuff is going to happen on the road unless you're far too close to a vehicle in front of you on the highway. I really hope somebody doesn't start shooting through stuff like that with a shotgun!!!!
Old July 8th, 2009, 05:36 AM   #48
minuslars
Ok, I just learned more info.
According to http://motorcycleinfo.calsci.com/Fairing.html, there is a class of Acrylic that is DOT approved and will not shatter when hit by rocks at speed. One would hope that the Zero Gravity shield and Laminar lip use this... so I suppose it won't stop cows , but at the very least it won't let rocks through to your chest.
Well, I think I'm going to go with the Laminar lip. Even though it's pretty pricey for a little bit of extension, the overall aesthetics are a lot better from what I can see, whereas IMO the Zero Gravity DB just accentuates the squareness of the headlight, which is pretty fugly, let's be honest.
I'll take some pictures with it mounted
Old July 8th, 2009, 01:45 PM   #49
JCCJMM_
JCCJMM_'s Avatar
I had a laminar lip prior to the DB.
It did a fantastic job of re-directing airflow and was especially good on the highway.
Unfortunately for me, I could not find a good spot to mount it. I tried MULTIPLE mounting spots and got a bunch of wind noise around my helmet.
Also, I originally put it on in the fall. Once winter rolled around the lip caused my face to become much colder due to air being re-directed at my shield.
I think it all depends on your height though. I am just shy of 6'1" and the lip just did not work out for me.
As far as the DB, I don't notice a real difference from stock until I do a semi-tuck. But I do think the DB looks much better than stock.
Old July 19th, 2009, 06:33 PM   #50
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
stocker on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...m=280371356301
if any one wants/ needs you got a day
QTRltrPWR
nate-bama is offline   Reply With Quote
Old November 16th, 2009, 02:23 PM   #51
sprale
Dead-thread Necromancer!
sprale's Avatar
Motorcycle(s): K5 V-Strom
I eyeballed one of Mike's shields and cut my own. I laid a sheet of clear Mylar over the stock shield to get the hole placement, drew a rough outline of what I wanted, then transferred that to a sheet of Lexan. I then cut a vent to reduce baffling, rides like a different bike.
2007 Kawasaki Ninja EX250 ZG250 Quarter-Concours commuter Gone
2005 Suzuki V-Strom DL1000 Big Black Vee future hack?
sprale is offline   Reply With Quote
Old November 16th, 2009, 03:01 PM   #52
Snake
Snake's Avatar
Good looking windshield sprale. Great job.
Old November 17th, 2009, 08:33 AM   #53
TonyKZ1
TonyKZ1's Avatar
Motorcycle(s): 1975 Kawasaki KZ400D (Sold), 1989 Kawasaki Ninja 250 (sold), 1997 Yamaha XJ600s Seca II
Looks good, any problems with your levers hitting the windshield? After wrecking my bike and replacing the broken parts, I'm back to the stock windshield, at least for now anyhow.
Tony
1997 Yamaha Seca II - mostly stock, Racetech upgraded forks, FZ6R rear shock, Oxford Heated Grips, Barkbusters Blizzard Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old February 23rd, 2011, 11:41 AM   #54
"A"
vampire
Motorcycle(s): 2 many 2 list
I'd like to see people post pictures of their windshield mod in this thread.
If you have a source webpage for your windshield on your Ninja 250, supply a link, too.
"A" is offline   Reply With Quote
Old June 5th, 2011, 01:34 PM   #55
"A"
vampire
Here are some pictures of Mike's shield on my 04 Ninja 250:
Old June 7th, 2011, 01:00 PM   #56
CmichRider
CmichRider's Avatar
Motorcycle(s): 2000 Ninja 250
I'm missing the front fairing, do I have any options for a windshield or am I SOL?
CmichRider is offline   Reply With Quote
Old June 7th, 2011, 01:34 PM   #57
"A"
vampire
Hopefully, you're creative.. WWMD? What Would MacGuyver Do?
Old June 7th, 2011, 01:41 PM   #58
CmichRider
CmichRider's Avatar
I'll figure something out . Nothing a little lexan, heat gun, and a dremel cant handle.
Old June 8th, 2011, 05:48 PM   #59
"A"
vampire
You forgot the chewing gum, pantyhose and a bottle of 'Head & Shoulders'.
Old June 8th, 2011, 06:57 PM   #60
CmichRider
CmichRider's Avatar
Ah I knew I was forgetting something! A trip to the Home Depot it is!
Winter Wings & Windshields EMSRacer07 1986 - 2007 Ninja 250R Farkles 119 February 6th, 2016 11:07 AM
[RoadRUNNER] - Windshields: A Blessing and a Curse Ninjette Newsbot Motorcycling News 0 July 7th, 2014 03:10 AM
7Jurock windshields Sipper' 1986 - 2007 Ninja 250R Farkles 1 November 1st, 2013 12:23 PM
Colored ninja 250 windshields Monkeytofu 1986 - 2007 Ninja 250R Farkles 2 October 19th, 2012 01:32 PM
Transparent Colored Windshields...Anyone? Bleak21 1986 - 2007 Ninja 250R Farkles 5 September 17th, 2010 01:22 PM
