Old May 9th, 2013, 03:59 PM   #1
2fidyswag
Motorcycle(s): Kawasaki Ninja 250, Kawasaki 650
Question about painting fairing?
I have a couple questions. I have decided to remove some decals from my ninja special edition. I don't care much about keeping it stock for re-sale value because I had to get a salvage title so I plan on running this to the ground.
Top two pics are the look I'm going towards, bottom one is mine. I want the 'dipped look' of matte black on a portion of the bottom side fairings. My question is as many people know, decals on the tank are under clear coat. And trying to take a decal off with a clear coat could make the bike look worse. So my idea was, if you look closely it's got a red line above the black. I was gonna keep the black because that'll be fine but I want to cover up the thin line of red. How easily could I do this, would I need to sand that stripe and prime it? Or could I get away with taping off that area and using motorcycle paint over it since it's such a small area. Thanks in advance. If you have better options I'm open to any ideas.
I guess my question is question about painting gas tank.
Last futzed with by 2fidyswag; May 9th, 2013 at 04:03 PM. Reason: I guess my question is question about painting gas tank.
2fidyswag is offline   Reply With Quote
Old May 10th, 2013, 01:10 AM   #2
sLick415
Yourd be better off just redoing the entire tank.
sLick415 is offline   Reply With Quote
Old May 14th, 2013, 11:59 AM   #3
Ivanrules
Motorcycle(s): Ninja250r
Sand and feather edge the area where decals are at starting with 220 grit and then 320. Then spot prime the area. Sand again with 600 wet or dry. paint and clear.
Ivanrules is offline   Reply With Quote
A question about painting parts Shoganai 2008 - 2012 Ninja 250R Tech Talk 67 March 19th, 2015 09:41 AM
Fairing Painting Question Apex123 2008 - 2012 Ninja 250R Tech Talk 15 January 11th, 2015 05:52 PM
Touch up painting question m_curtin52 2008 - 2012 Ninja 250R Farkles 4 May 17th, 2012 10:32 PM
Painting Question Jordan91 General Motorcycling Discussion 8 September 3rd, 2010 07:49 PM
