Old May 27th, 2014, 09:21 AM   #1
Bob2010
Bob2010's Avatar
35 mph cruise control?
In 6th gear , choke on full - hands free riding
2010 Red Ninja 250
2009 Black Ninja 250
Old May 27th, 2014, 09:23 AM   #2
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Dose that not use a crap ton of gas?
Old May 27th, 2014, 09:25 AM   #3
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
riding like that will burn up the engine.
TEAM ALFALFA
www.apexassassins.com
Old May 27th, 2014, 09:27 AM   #4
Bob2010
Bob2010's Avatar
Dunno yet. I filled up. Drove 156 miles. Still have gas left
Going from 55mph crossing into small towns that dropped to 30mph , it was a bit helpful. Gave my thumb a chance to relax. Dunno why my right thumb cramps on long cruises.
2010 Red Ninja 250
Old May 27th, 2014, 09:28 AM   #5
it is the perfect way to burn out your exhaust valves and spark plug!
Old May 27th, 2014, 09:29 AM   #6
probably deathgrip on the bars
Old May 27th, 2014, 09:30 AM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
sounds like you need to use your fingers more when holding the throttle, and relax too.
TEAM ALFALFA
Old May 27th, 2014, 09:31 AM   #8
Bob2010
Bob2010's Avatar
I was thinking my grip was too tight. It was windy but I remind myself to stay loose on the grips. I think it's the position of my wrist on the throttle to maintain a constant 65-70mph speed.
2010 Red Ninja 250
Old May 27th, 2014, 09:54 AM   #9
Bob2010
Bob2010's Avatar
Lol at all the destruction of my engine replies. Is it really going to hurt? Isn't it just adding fuel ?
I didn't intend to ride a 10 mile parade like this. Just a moment or two of hands free riding
2010 Red Ninja 250
Old May 27th, 2014, 10:06 AM   #10
Everything in moderation. A minute or two won't make any long-term difference. But longer-term running rich like that can cause accelerated engine wear, as too much fuel will thin the oil. Once that happens, even if you run with the choke off as advised for the rest of the life of that oil, there will continue to be higher wear rates.
Old May 27th, 2014, 10:43 AM   #11
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
As others have stated it's a bad idea; wastes fuel, dilutes lubrication. If you need to relax your throttle hand on long rides I would suggest changing the grip by using different fingers occasionally and for a complete rest using a throttle-holding device. There are various commercial clamp and resistance types you could buy but I find the best one is one I made myself by out of heavy gauge wire. Get a piece of heavy gauge solid core insulated wire about 1 foot long. center it on the inner edge of the throttle then twist the 2 tails tightly so that it forms a stiff coil extending from the throttle past the front brake lever. It should be wound tightly enough that that it will hold the throttle open when rotated forward to rest on the brake lever. To disengage, just roll the throttle forward. Simplicity itself!
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old May 27th, 2014, 11:18 AM   #12
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Or if you feel like spending money on what @greenaero just described, that would be this thingy: http://www.2wheelride.com/throttle_pro.html
<-- Linky
Old May 27th, 2014, 01:57 PM   #13
Bob2010
Bob2010's Avatar
Totally agree. It's the first time in 3 years I rode the thing at sustained 65-70mph for 30 miles at a time.
Yesterday was a 156 mile trip trip to letchowrth.
Soo I found out a lot of things I don't like. Mainly the seat. Had to keep checking to make sure it wasn't made of granite.
The other things were how high the bike stays in rpms Makes me think I'm destroying the motor / oil.
But other than that. It was a great day to ride. Those small 30mph towns we pass through was a good break to relax and flip up the visor
2010 Red Ninja 250
[motorcyclistonline] - Omni-Cruise Cruise Control | MC Tested Ninjette Newsbot General Motorcycling Discussion 4 January 11th, 2014 06:45 PM
Go Cruise Throttle Control Yasko General Motorcycling Discussion 38 November 30th, 2012 08:39 AM
throttle lock or cruise control wellcraft 2008 - 2012 Ninja 250R Tech Talk 32 January 8th, 2012 03:03 AM
[webbikeworld.com] - Go Cruise Throttle Control Review Ninjette Newsbot Motorcycling News 0 October 29th, 2011 09:10 AM
Cruise Control Thoughts... (not throttle locks) dubojr1 2008 - 2012 Ninja 250R Farkles 7 April 8th, 2011 05:35 AM
