Old May 14th, 2013, 02:28 PM   #41
RedPepper64
Kawi Girl
RedPepper64's Avatar
Motorcycle(s): '10 Ninja 250R Green SE, '13 Ninja 636 Pearl White
Originally Posted by gfloyd2002 View Post
According to the Hurt Report a predominating factor in car/motorcycle accidents is the car failing to yield right of way. "Sorry, I didn't see you." This is most often a car pulling out in front (or into) a motorcycle at an intersection. This also coincides with what most motorcyclist find in their personal experience. So how do we reduce the risks from this type of accident? According to the Motorcycle Stopping Distance Calculator, it takes 150 feet to stop from 60mph, 66 feet to stop from 40mph, and 37 feet to stop from 30MPH. Think about those numbers for a minute -- small increases in speed have a huge impact in the distance we can stop.
And when one compares those stopping distances with the width of a standard intersection, an easy solution presents itself. A typical small intersection is 48 feet wide. Slowing down from 40 mph takes 66 feet, but slowing down from 30 mph takes only 37 feet. So how do we improve our chances of avoiding the most common type of motorcycle accident? Slow down to 30 approaching an intersection where a car might pull out in front of you, and give yourself the space to stop in time.
I know this is an old, old thread but it was brought up in a newer one I was just reading. Thank you for this information. I already find myself slowing at intersections but to have a greater understanding with the physics as to why and a "magic number" to shoot for.
Perspective: Everything looks better from the inside of a motorcycle helmet
RedPepper64 is offline   Reply With Quote
Old May 14th, 2013, 03:07 PM   #42
LNasty
Daily Jap rider
LNasty's Avatar
Originally Posted by nickjpass View Post
No magic speed in this accident
this is why i don't stop directly behind cars, I pull to the side of them, pretty much in between the two lanes so that if someone is not going to stop they hit the car and hopefully not me
Old May 15th, 2013, 06:49 AM   #43
Correct !!!
And even if the car hits you, you will not be crushed in between cars.
Another advantage is that, having one mirror at the correct visual angle, you have a much better view of what is approaching from behind.
There is not a single reason to stop in the position that the video shows.
Old May 28th, 2013, 02:03 PM   #44
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
I'm really happy this helped, thanks for the kind words.
Old September 2nd, 2013, 03:16 PM   #45
deeno415
deeno415's Avatar
Motorcycle(s): 2006 Kawasaki EX250(Bright Yellow)
Originally Posted by Motofool View Post
Correct !!!
Riding in the city traffic, stopping in between cars is what I tend to do. I do try to ride all the way up to the crosswalk, but learned not to always be the 1st out of the gate (as there are some drivers trying to beat the red in cross traffic). I don't care that some drivers get upset at me (which some do). I just say, "I'm trying to avoid getting rear-ended by someone that might not see me... " and then they usually understand.
I try to ride paranoid all the time, especially in a city where cagers are so impatient and try to get moving at any given chance. These safety methods/practices are necessary for any rider!
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle. Sorry, I don't speak Spanish... I'm Filipino!
deeno415 is offline   Reply With Quote
Old September 20th, 2013, 12:20 AM   #46
AlanDog
AlanDog's Avatar
Motorcycle(s): 2019 Ninja 400, 2009 KLX250-SF, 2014 Zero S
As for bike weight mattering, it is a myth. While counter-intuitive, heavier bikes still have (for the most part) sufficient braking power to lock up the wheels. Heavier weight just means you need more pressure on the brakes to achieve the same stopping power. This is because heavier weight bikes offer increased friction that balances out the increased momentum of the bike. (F = mu*N where F = frictional force (braking force between the tyres and the road), mu = friction co-efficient (changes based on road/tyre condition), N = normal force (force acting directly downwards with gravity i.e., the mass of the bike and rider). .
Okay, counter-intuitive for sure: say my bike weighs 5,000 lbs. My front tire is still 100 mm wide. won't the heavier bike just have a ton more momentum than a lighter bike? Isn't the tire contact patch skidding at the limit of tire traction, so why would a 5000 pound bike stop just as quick as a 500 lb bike?
AlanDog is offline   Reply With Quote
Old September 20th, 2013, 08:06 PM   #47
Both momentum and traction depend linearly on the weight on the contact patch; therefore, the heavy bike and the light bike can stop at the same distance and time.
When you are at maximum braking effort and your rear tire is starting to lift up, all those 5,000 lbs go vertically to ground through the front contact patch.
The heavier bike has as much forward momentum as heavier it is respect to another bike: your 5,000 lbs bike has 5/4 more momentum than a 4,000 lbs bike, if both are moving at the same speed and decelerating at the same rate.
http://www.engineeringtoolbox.com/fr...nts-d_778.html
Rolling or skidding, the force resisting the forward movement at the contact patch is 90% or 70% of the weight that goes vertically to ground through the front contact patch.
Hit the magic 40 yesterday FrugalNinja250 General Motorcycling Discussion 20 August 15th, 2012 12:01 PM
Can't Go Past 30mph lotusseven 1986 - 2007 Ninja 250R Tech Talk 4 February 27th, 2011 10:04 PM
[visordown.com] - Highways Agency man banned for 50mph wheelie in 30mph limit Ninjette Newsbot Motorcycling News 0 October 14th, 2010 02:50 AM
blue magic blue magic New Members 12 June 14th, 2010 11:50 AM
[visordown.com] - Driver clocked at 105mph in 30mph zone Ninjette Newsbot Motorcycling News 0 January 13th, 2010 07:33 AM
