Old February 4th, 2012, 02:17 AM   #1
KawiKid860
KawiKid860's Avatar
Is full choke on a cold engine bad???
Just wondering if its harmful to my bikes engine to have the choke set at 4k rpms when I first start the bike? Usually if its really cold and/or has been sitting for a long time it takes full choke to get it to start up and itll go to 2500 rpms then after a short while will move up to around 4k, at this point I'm busy putting my gear on and what not so I can't always go to the bike and reduce choke. Is 4k rpms gonna hurt the engine? Or does it really need to be revved high for cold revving to cause damage?
Old February 4th, 2012, 07:03 AM   #2
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
It's best to adjust the choke to keep the RPMs under 2,500. Generally if you hang around the bike for a minute and adjust the choke as needed you'll get a nice stable idle while you go put on gear.
Old February 4th, 2012, 08:58 AM   #3
koenigcitizen
Russian Ninja :)
koenigcitizen's Avatar
Motorcycle(s): 2012 Triumph Street Triple R, 2009 Yamaha FZ6, 2010 Kawi 250r (sold)
When I start the cold bike this time of the year, I give it full choke. RPMs only go to about 2000 at first. In 20 sec or so, I leave it at about half choke, and ride off. By the time, I get to the first traffic light, my choke is off.
2009 Fazer (2009 Yamaha FZ6), 2012 Triumph Street Triple R
koenigcitizen is offline   Reply With Quote
Old February 4th, 2012, 10:48 AM   #4
bluesinorbit
bluesinorbit's Avatar
I can't speak from a mechanical point of view but I would go by the manual and keep it under 2,500rpm. During my first month or so, I did exactly what you did; start the bike and leave the choke on at 2500. I left to get gear and whatnot. I came back and the bike was roaring at 4-5k. I could smell something burning and that scared me, and I haven't done that since. If you need to be away, adjust the choke from the start so that even at near full warm-up five minutes later, the rpm wouldn't get above 2500. It may take a bit longer to warm up than choking at a higher rpm, but you know the bike is safe even if you get a call/whatever and come back to the bike in 5-10 minutes.
bluesinorbit is offline   Reply With Quote
Old February 4th, 2012, 11:45 AM   #5
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
Why not put on your gear first, crank the choke full on and ride away. It's the recommended way after all.
Here's a link that I found extremely helpful and I live by it>> http://faq.ninja250.org/wiki/Warming_up_your_engine
EthioKnight is offline   Reply With Quote
Old February 4th, 2012, 11:57 AM   #6
koenigcitizen
Russian Ninja :)
+1. This is how I do it
Old February 4th, 2012, 12:42 PM   #7
KawiKid860
KawiKid860's Avatar
wow I'll definitely switch to that method. usually just start up on choke throw on gear flip off choke and go. usually keep it around 2500 but been a few occasions where it goes to 4k, hope I haven't caused any damage or lost compression or anything
Significantly more power with full choke? Boogab 1986 - 2007 Ninja 250R Tech Talk 5 March 4th, 2013 02:13 PM
Engine Stalls Without Choke Samer 2008 - 2012 Ninja 250R Tech Talk 11 September 1st, 2012 11:32 AM
Bike only runs on full choke!! UjaasG35 2008 - 2012 Ninja 250R Tech Talk 13 May 15th, 2012 06:49 PM
What RPM with full choke? CmichRider 1986 - 2007 Ninja 250R Tech Talk 9 October 1st, 2011 08:33 AM
Help with cold start (without choke) d16soda 1986 - 2007 Ninja 250R Tech Talk 4 August 31st, 2011 01:17 PM
