Old April 18th, 2018, 10:40 AM   #1
[motorcycle.com] - Riding The New Bridgestone Battlax R11 DOT Race Tire
Building a new motorcycle tire is not easy. As the only two contact points your motorcycle has to the ground, there’s a lot of responsibility involved. In the case of a racing tire, the demands become that much greater; not only does the tire need to remain consistent throughout its life, but it also needs to be better than its predecessor. Sure, this can be said about practically any motorcycle tire, but with racing tires there’s an actual gauge to measure old and new: the stopwatch.
Hence was the challenge Bridgestone faced when developing its latest DOT racing tire, the Battlax R11. The successor to the popular R10, Bridgestone engineers couldn’t sacrifice the performance of the R10, but knew improvements had to be made. Here, B-Stone decided to focus on a few key areas: improved corner entry, better grip while braking and accelerating, and more consistent performance throughout the life of the tire.
More than just black, round, and sticky, Bridgestone developed the Battlax R11 to carry on where the Battlax R10 left off.
Tire Tech
To do this, Bridgestone utilized its proprietary Ultimat Eye technology first developed for its Formula One and MotoGP racing programs. Ultimat Eye is basically a tire dyno able to replicate the loads, forces, and stresses on tires in real time. The data collected allows B-Stone engineers to optimize the tire to the design specifications, which, in this case, is better performance on entry and tread rigidity mid-corner.
To get slightly more technical, Ultimat Eye allowed Bridgestone to better see and understand the abrasion angle occuring on a tire under usage (generally speaking, it’s parallel under acceleration/braking, edging closer to perpendicular the further you lean over), and it helped define the deformation of the tire under braking and cornering. As a result, the grooves of the R11 were designed and positioned according to these forces. This lets the grooves maintain maximum rigidity while cornering, while at the same time providing optimum deformation for quicker warm-up times. Lastly, it allows the maximum contact patch under acceleration.
Tread grooves are required per the DOT for a road-legal tire, and the forces on the R11 grooves get distributed evenly due to their direction, which ensures tread rigidity when cornering. Bridgestone says this offers more stability when accelerating and when the bike is leaned over.
Moving past the grooves and into the construction of the R11, Bridgestone made some tweaks to its Variable Mono Spiral Belt (V-MSB) construction. On the front tire, the belts are further apart on the shoulders and closer together in the center. With the goal of faster corner entry in mind, this new spacing puts higher, more evenly distributed, pressure on the contact patch while cornering. From the rider’s perspective, this translates to more front end feel and confidence, and confidence is key when chasing lap times.
Tweaks to the V-MSB construction are made on the rear tire also, with belts close together on the extreme edges and middle of the tire, and further apart on the shoulders. This provides stability at full lean, and max contact patch (read: drive) once the bike is picked up off the side and acceleration begins. Bridgestone also claims more consistent performance over the life of the tire. However, due to the additional forces acting on the rear tire, Bridgestone utilizes an additional belt layer, called the GP Belt, on top of the V-MSB – a procedure also done on the V02 full racing slick.
A major selling point for the Battlax R11: the tires will be available in sizes to suit all production sportbike racing classes, which means riders on small-displacement motorcycles like the Yamaha YZF-R3 can find DOT race rubber.
According to Bridgestone, the result of all this hard work was a difference of 1.5 seconds. That’s how much faster Bridgestone’s test rider lapped the Oschersleben track aboard a Honda CBR600RR wearing R11 tires compared to the R10. As any of you who follow racing know, 1.5 seconds is a massive amount of time.
Lastly, while not exactly a technological talking point, Bridgestone’s fourth goal is worth mentioning: providing a full size-run to satisfy all classes of sportbike racing, from entry-level small displacement machines, to fire-breathing superbikes. With the growing popularity of small-displacement racing throughout the world, Bridgestone is capitalizing on this by offering its premier DOT race tire to fit virtually every sportbike on the market. Fronts will be available in both 110/70 and 120/70-17, while rears will vary from 140/70-17 to 200/55-17. Two compounds will be available – soft and medium – with 120/70-17, 190/55-17, and 200/55-17 available in both compounds. The rest will only be available in medium.
Talk Is Cheap
From where I was sitting – which was Yamaha’s full lineup of R-World sportbikes: the R3, R6, R1, and R1M – my measure of a race tire is how quickly it warms up, its stability under braking, confidence at full lean, and predictability on the gas at corner exit. Yamaha and B-Stone staff kept the bikes on tire warmers throughout our two days of riding around the excellent Utah Motorsports Campus (aka Miller Motorsports Park), so gauging warm-up times was difficult, but judging from the times I came in and didn’t put the bike back on warmers, getting back up to speed again took the better part of a lap. From a completely cold tire, two laps should be plenty to get up to proper operating temps (depending on ambient weather conditions, of course).
Despite the modest power it makes, the Yamaha YZF-R3 can still upset the stock tires. Such is not the case with the Bridgestone R11. Grip is superb, and since there isn’t enough power to spin the rear, you can go full throttle immediately after the corner is finished.
Braking stability is important, as lots of time can be clawed back under brakes, and here is where the R11 really shines. No matter the bike, from R3 to R1, the R11 felt incredibly composed under braking, offering tons of stability especially when trailbraking. So much so that I dared myself to go deeper and deeper on the brakes, ready to receive any sort of protest from the tire as a sign the limit was approaching. It never came.
While on the side of the tire, the R11’s grip was never in question; full lean on any of the Yamahas was never met with any sort of spooks or scares, and feedback was excellent. The profile of the tire requires slightly more effort from the rider to flop from side to side, but it’s hard to be definitive, having not ridden on the previous R10 tire in a long time.
As far as grip on acceleration is concerned, the R11 took the abuse of a ham-fisted R1 rider (me) like a champ, my attempts to induce a gnarly slide only succeeding once before the Yamaha’s traction control kicked in and prevented me from looking like a big idiot. Otherwise, the R11 simply hooked up and drove forward. As I piled more laps on an R6, the tire would squirm with a slight wiggle or bobble as more laps were put on – communicating beautifully how much (or how little) I was punishing it.
Jumping from an R3 to an R1M takes some getting used to, but the confidence delivered by the R11 tires remains the same.
Ultimately, I had to call it quits before the tire did. Two days of riding took its toll on me, but it says a lot about the tires that not a single motorcycle fell down. None of the assembled journos even complained about any close calls.
As a fan of the previous R10 tire, news of a successor obviously got me excited. Needless to say, the excitement was thoroughly justified. The R11 is a hell of a tire, whether you’re competing or simply a trackday junkie. With excellent levels of feel, traction, and feedback, it delivers everything I’m looking for in a track tire. It’s difficult to say how it stacks up against the competition without riding them back-to-back, but from a price perspective the Battlax R11 is definitely attractive. MSRP starts at $125.24 for 110/70-17 front, up to $231.84 for 200/55-17 rears. Combine that with B-Stone’s competitive contingency for racers, and it’s hard to go wrong.
Visit Bridgestone.com for more information.
The post Riding The New Bridgestone Battlax R11 DOT Race Tire appeared first on Motorcycle.com.
Click here for full story...
[cyclenews.com] - Bridgestone Battlax S20 or T30 Tire Promo Ninjette Newsbot Motorcycling News 0 September 12th, 2014 01:00 PM
[motorcycle-usa.com] - Bridgestone Battlax S20 Tire Review Ninjette Newsbot Motorcycling News 0 September 13th, 2013 04:40 PM
[motorcycle-usa.com] - Bridgestone Battlax R10 Race Tire Review Ninjette Newsbot Motorcycling News 0 August 2nd, 2013 08:20 PM
Bridgestone Battlax BT-016 Rear Tire 150/60 ZR17 100$ krolinked Motorcycle-related 0 January 7th, 2013 06:39 PM
Bridgestone Battlax Tire Question conrya5 1986 - 2007 Ninja 250R Tech Talk 11 September 22nd, 2012 06:02 PM
