Old March 25th, 2012, 03:51 PM   #1
Luvninja
Luvninja's Avatar
Motorcycle(s): 05 Ninja 250
another question on replacing shocks
Ok, so I've read quite a bit on shocks and just about everyone says to replace them (on a pregen) with better ones. So many of the shocks raise the tail right? But I have my bike lowered a bit 'cause I'm so dang short, so would replacing the shock & spring benefit me and could I still lower it or not? This might be a stupid question, but I know NOTHING on this subject. Also, if it would benefit me to change it, what kind would you recommend, from a ninja500?
I've modded my bike cosmetically but would like to make it handle better now. Any suggestions are welcomed
Luvninja is offline   Reply With Quote
Old March 25th, 2012, 05:35 PM   #2
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
I've replaced the shock on my '89 with one from a 2009. The main benefit is the adjustable preload to compensate for passenger weight or heavy luggage. Otherwise, the technology is similar, i.e. stone age. And it raises the seat 3/8" or so which sounds like what you don't want.
GeorgeRYoung is offline   Reply With Quote
Old March 25th, 2012, 06:28 PM   #3
greg737
Motorcycle(s): -
I put a Hagon shock on my 2005.
Great quality, fits the bike perfectly, no change in ride height, adjustable pre-load, damping and rebound. Just north of $400 if I remember correctly, worth every penny.
Old March 25th, 2012, 10:52 PM   #4
If you get adjustable dogbones from Soupy's performance, you can install whatever length shock you want (within reason) and keep the same ride height you need.
I would stay away from the ex500 shock. it's actually softer unless you crank the preload up, then it's really stiff
replacing front wheel bearing question mikedabike64 2008 - 2012 Ninja 250R Tech Talk 3 May 31st, 2014 05:20 PM
best shocks? juanpak87 1986 - 2007 Ninja 250R Tech Talk 35 August 25th, 2013 10:01 AM
Question about replacing Fork Springs? MKlein3004 Ninjettes At Speed 12 October 2nd, 2012 06:30 PM
[topix.net] - From Twin-Tube Single Shocks to Single-Tube Twin Shocks: Ohlins... Ninjette Newsbot Motorcycling News 0 June 5th, 2012 04:30 AM
question about replacing brake pads ReDnEcK 1986 - 2007 Ninja 250R Tech Talk 3 August 21st, 2010 06:12 AM
