Old March 15th, 2013, 08:58 PM   #1
alex.bowles
Motorcycle(s): 2001 ninja ex250
problem with carburetor maybe?
hey guys i have been having some problems with my 2001 ninja ex250 and i hope you can help.. so it started with me filling up the gas and i then brought it home and did not turn off the peacock and i come out the next morning and about half the tank had leaked on to the ground so i took the carburetors off and cleaned them then put them back on and i started it and it came out the overflow on them so i talked to a buddy and he said it could be the float valves so i changed them and put a new gasket in them. then i started it and it ran fine so i drove it all day and at the end of the day it started acting really funny and now its bad my high range is good and my low is ok and my mid range is really bad it almost sounds like its being flooded and there is vary little power but when i give it more its like its catching up. so i have no idea i hope someone can help.
thanks guys.
alex.bowles is offline   Reply With Quote
Old March 15th, 2013, 09:25 PM   #2
check petcock valving?
Old March 15th, 2013, 10:03 PM   #3
alex.bowles
yes i did and thats all good
Old March 15th, 2013, 10:55 PM   #4
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
thanks guys.
these two type exactly like eachother and have such similar names yet claim to be different people?
"A" already tried this trick, can't you come up with something better alex?
and cmon, .bowles? obvious reference.
AFM #676
Supersports are for n00bs
Old March 15th, 2013, 11:24 PM   #5
Different people, no conspiracy here. We've got some pretty neat behind-the-scenes tools to pick up, well, tools.
Old March 15th, 2013, 11:27 PM   #6
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I think alex.s is smart enough to fake his IP, afterall, he posts a lot of videos about robots
AFM #676
Old March 15th, 2013, 11:30 PM   #7
**way** past simple IP comparisons, you'll just have to trust me.
Old March 15th, 2013, 11:36 PM   #8
Jiggles
Jiggles's Avatar
MOTM - Apr '13
AFM #676
Old March 16th, 2013, 12:05 AM   #9
Lychee
sail away
Lychee's Avatar
Your petcock could be leaking. you shouldn't have to turn it off at the end of the day because it only flows gas when a vacuum is applied. Well, when it works properly that is.
Old March 16th, 2013, 01:45 AM   #10
alex.bowles
so i know its not that i have 3 of them. it has to do with the carb. oh and i fixed the leaking it just running bad as i said
Old March 16th, 2013, 03:57 AM   #11
Welcome to the site, Alex !!!
............now its bad my high range is good and my low is ok and my mid range is really bad it almost sounds like its being flooded and there is vary little power but when i give it more its like its catching up...........
When you replace the valves that the floats push up, you should verify the proper level of fuel inside the bowls.
Also, one or both of the diaphragms and/or needles may not be working properly for some reason.
Old March 16th, 2013, 06:20 AM   #12
conrya5
conrya5's Avatar
Motorcycle(s): 2010 Metalic Island Blue Ninja 250r
Correct me if I am wrong, to measure the fuel levels you can simply use 1/4" OD clear tube.
conrya5 is offline   Reply With Quote
Old March 16th, 2013, 07:22 AM   #13
DaBlue1
DaBlue1's Avatar
....the next morning and about half the tank had leaked on to the ground
With that much gas on the ground, it is possible for some to leak past the piston rings.
Did you check your oil level/condition?
How is your air filter?
Old March 16th, 2013, 07:55 AM   #14
alex.bowles
yes i did gas did get in to the air box and so from there it went down in to the crank case. so i just had to change the oil
Old March 16th, 2013, 07:58 AM   #15
alex.bowles
ok so i just stick a tube on there and see how far it go's?
oh and thanks
Old March 16th, 2013, 08:04 AM   #16
alex.bowles
why would it run so well at the beginning and now bad could i have gotten something in the carb like maybe dirt?
Old March 16th, 2013, 08:21 AM   #17
alex.bowles
Okay just checked it today there's no leaking at all but the throttle response is horrible and then it goes normal when I get high rpm
Old March 16th, 2013, 12:12 PM   #18
you said it leaked a puddle on the ground. i dont know if the pregen petcock is also vacuum opened but on the newgen, you need vacuum (ie- running engine) for the the petcock to let extra fuel out. so if it leaked a bunch of fuel out wouldn't that mean that the petcock isn't all good? if the petcock is just an open drain line now, and the floats aren't 100%, it would make sense that the carbs would get flooded and it would be all rich and boggy and leak gas everywhere.
Old March 16th, 2013, 12:15 PM   #19
you dont need to fake anything when you can just use the real thing. trying to fake things is a mistake a lot of noobs make.
Old March 16th, 2013, 10:16 PM   #20
alex.bowles
so how would i test that?
Old March 16th, 2013, 10:53 PM   #21
zedzedR
zedzedR's Avatar
Motorcycle(s): '01 ZZR 250
Make sure the carb butterfly is properly adjusted
zedzedR is offline   Reply With Quote
Old March 17th, 2013, 01:59 AM   #22
disconnect the tank from the carb... does it leak a bunch of gas out the tube? it shouldn't.
Old March 17th, 2013, 06:33 AM   #23
n4mwd
n4mwd's Avatar
Just like Alex.s said, your petcock is bad.
If you ever get gas coming through it when the bike is off, then its bad. The fact that you have a puddle of gas on the floor proves that its bad.
Also, you should never turn your petcock OFF after riding. If it doesn't cut off automatically, then its bad. OFF is there so that people can drain the carbs for the winter by riding it out. People with newgens don't have an OFF and must drain their carbs manually when winterizing.
To test, turn off bike and remove both hoses. Make sure petcock is ON or RES. No gas should come out.
Then put a small length of fish tank or other tubing onto the small port and suck on it. Gas should come out of the big port but not the little one. If you get gas from the little one, or no gas comes out, then the petcock is bad.
Also, you will need to change the oil because it now has gas in it. It you run it like that, you will burn out your bearings and need a new engine.
My Ninja Blog
Old March 17th, 2013, 07:05 AM   #24
alex.bowles
Ok man I will check that. Could that also make it feel like its not getting gas
Old March 17th, 2013, 07:20 AM   #25
n4mwd
n4mwd's Avatar
If there is gas coming through the little hose, it will flood the engine and cause it to run badly. It might feel like its not getting enough gas.
When you disconnect the little hose, you should see NO gas, not even a drop in the little hose.
More than likely, your diaphragm is bad. Make sure you order the 88-07 kit or diaphragm. The 86-87 kits and the 08+ kits will not fit.
My Ninja Blog
Old March 17th, 2013, 08:25 AM   #26
alex.bowles
How can you tell if the diaphragm is bad
Old March 17th, 2013, 01:01 PM   #27
n4mwd
n4mwd's Avatar
If gas comes out when its ON or RES and there is no vacuum applied to the small port. Or ANY gas comes out of the small port at all. If any of those is true, then the diaphragm is bad. Its about $20 at the dealer. If that doesn't fix it then the whole petcock could be messed up somehow.
The petcock knob and the diaphragm are two separate subsystems. The knob controls the flow to the diaphragm, and the diaphragm controls the flow to the carbs. Its very common to have a knob that works fine and a diaphragm that leaks.
So you could have the situation where OFF stops the fuel flow. But the ON still leaks.
My Ninja Blog
Old March 18th, 2013, 09:33 AM   #28
alex.bowles
Ok so I got a tube on the and sucked and nothing came out on the on and off and RES. What should I do?
Old March 18th, 2013, 10:10 AM   #29
n4mwd
n4mwd's Avatar
Are you sure your tank isn't empty?
If there is fuel in there, you should be able to get gas out when sucking on the small port. At least out when on RES.
My Ninja Blog
Old March 18th, 2013, 10:47 AM   #30
quicklooker
Motorcycle(s): Ninja 250R '07
As a side note, I had an issue where I would leak a quarter of my gas on the floor through the "overflow" hose after fill up. The problem was that the little metal tube connecting to the inside of the fuel cap where fuel overspill goes was cracked/damaged resulting in the fuel to leak down to the level of the crack in this metal hose.
The metal hose is thin , runs right through the fuel to the beginning of the overflow hose and is liable to break if rusty or jarred hard enough like drops. The only way to fix it reliably was to replace the entire tank. This may be unrelated to your problem but figured this is good information.
quicklooker is offline   Reply With Quote
Old March 18th, 2013, 10:58 AM   #31
lgk
i think you connected the hoses wrong.
Old March 18th, 2013, 11:11 AM   #32
zedzedR
zedzedR's Avatar
Is the bike still leaking puddles on the ground? If it is only running rich and dribbling a few drops, make sure that your carbs are synchronized properly. You can either make a manometer to test it, or for a less accurate quick test, take your carbs out and ensure that both butterfly valves are at the same position.
Another simple fix could be that the drain bolt on your float bowl is not tightened enough.
Both of these things have happened to my bike before causing it to not run well at low rpm and to leak out some gas.
Old March 18th, 2013, 12:35 PM   #33
alex.bowles
There is no leaking gas anymore
Old March 18th, 2013, 12:37 PM   #34
n4mwd
n4mwd's Avatar
Then you really need to make it a priority to find out why it was leaking before. Could be the tank itself is punctured.
My Ninja Blog
Old March 18th, 2013, 12:39 PM   #35
quicklooker
Is there any gas left in the tank?
Old March 18th, 2013, 12:40 PM   #36
alex.bowles
I know why it was the gas valve
Old March 18th, 2013, 12:41 PM   #37
alex.bowles
Yes half tank
Old March 18th, 2013, 12:43 PM   #38
quicklooker
Yes half tank
Fill it up just a little bit. I suspect it's the same problem I had; a busted overflow tube inside the tank. If it immediately starts to leak after you fill it up a little bit I'll bet that's at least part of the issue if not the entire issue. Only put a little more in like maybe half a gallon (to minimize leaking hazardous fuel everywhere).
You shoulda seen my bike dumping a gallon of fuel everywhere I went after a fill up. It was embarrassing.
Old March 18th, 2013, 12:50 PM   #39
alex.bowles
Just did it im seeing nothing
Old March 18th, 2013, 12:56 PM   #40
quicklooker
*shrug*
So, in great detail , what did you do to fix it? It might be hard to figure out why it was leaking before if it's fixed now.
Problem with draining the carburetor! Please help! htsang07 2008 - 2012 Ninja 250R Tech Talk 14 September 5th, 2012 09:43 PM
Carburetor / Valve Problem? kingkang204 2008 - 2012 Ninja 250R Tech Talk 19 August 15th, 2012 06:50 PM
Carburetor Diaphragm kingkang204 Motorcycle-related 4 September 21st, 2011 07:20 PM
carburetor bolts james250ninja 2008 - 2012 Ninja 250R Tech Talk 3 September 2nd, 2011 01:53 PM
