Old August 20th, 2014, 04:35 PM   #1
Josh_kcco
Josh_kcco's Avatar
Motorcycle(s): '04 Ninja 250R
Evap Removal..
i found threads on threads of this but i have one question.
do i cap off the T hose on the carbs?
Josh_kcco is offline   Reply With Quote
Old August 31st, 2014, 08:28 PM   #2
bump for more info
Old September 2nd, 2014, 03:24 PM   #3
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I'm not familiar with the specifics of this, but in general, if you remove something hooked to a vacuum line, you need to cap off that line. It'll screw with the vacuum level and/or suck bad stuff in if you leave it open.
If it's a T going from one vac port to two items, you could also just use a single line to connect the remaining item to the vac port, to clean things up a bit.
Has anyone completely removed their Evap Canister? Nemesis 2008 - 2012 Ninja 250R Tech Talk 22 June 18th, 2020 09:22 AM
08+ Ninja 250 CA model Gas tank port questions (Evap System Removal) abhijitz 2008 - 2012 Ninja 250R Tech Talk 2 April 3rd, 2012 09:59 PM
Airbox removal + Kleen air removal? MikeBudd 2008 - 2012 Ninja 250R Tech Talk 6 February 16th, 2012 04:57 PM
Evap line full of fuel headshrink 2008 - 2012 Ninja 250R Tech Talk 10 June 18th, 2010 07:44 PM
