Old January 17th, 2015, 11:13 AM   #1
randomwalk101
self wrencher
randomwalk101's Avatar
bike idle and throttle issue
I cleaned my pilot jets (it was clogged) and the bike is starting fine. However, if I crank on the throttle fast (open throttle), the idle drops down and bike dies. If I crank on the throttle slowly, then RPM/engine will rev up....but sometimes it won't go past 4k rpm...after about 5 mins of warm up then it'll go higher. Anyone knows what the issue may be? Thanks.
btw, it has a fresh tank of gas with all old gas flushed out. New fuel filter as well.
Old January 17th, 2015, 05:46 PM   #2
Originally Posted by randomwalk101 View Post
............ Anyone knows what the issue may be?..........
As the carbs and the feeding tube are the last things that you have worked on, I would verify that the diaphragms are pulling the needles up and that the feeding tube does not adopt an inverted U shape that traps air and restricts fuel flow.
Old January 17th, 2015, 08:53 PM   #3
Ghostt
Ghostt's Avatar
Agreed, make sure they are assembled correctly, did you remove the idle, main jets, and holders and clean as well? also check for vacuum leaks.
Random question, is the OEM airbox installed/hooked up while you were testing?
violente et ignorantia
ZX-2R BLOG
Old January 18th, 2015, 01:30 PM   #4
randomwalk101
self wrencher
thanks for the response. Apparently it fixed itself somehow...all good
Old January 18th, 2015, 03:44 PM   #5
You are welcome
Old January 18th, 2015, 04:53 PM   #6
Ghostt
Ghostt's Avatar
Np
ZX-2R BLOG
Poor idle and throttle issues chich 2008 - 2012 Ninja 250R Tech Talk 11 January 15th, 2014 07:39 AM
Idle issue djjontran 1986 - 2007 Ninja 250R Tech Talk 27 August 18th, 2013 09:00 AM
idle issue PEN25 1986 - 2007 Ninja 250R Tech Talk 10 June 30th, 2013 02:14 PM
Whats going on? - (won't idle without throttle) dlebe250 1986 - 2007 Ninja 250R Tech Talk 9 January 19th, 2011 11:16 AM
Throttle cable - high idle? austexjg 2008 - 2012 Ninja 250R Tech Talk 3 November 30th, 2010 09:41 AM
