September 23rd, 2009, 11:32 AM | #1 |
Join Date: Sep 2009 Motorcycle(s): 2003 Ninja 250 Posts: 5
Clutch Sticks
I know it's a fairly common 'feature' of our bikes, but mine does it really badly. I can barely break the clutch loose without the help of the engine and 3000+ RPM. FWIW I have mobile 1 10w40 synthetic in it, and the bike has 4k miles.
How do I fix it? I took the clutch apart, cleaned it, and put it back together but it didn't help. Do I have to replace the clutch discs? Thanks |
September 23rd, 2009, 01:25 PM | #2 |
how many miles since the last oil change and did you use a MC specific oil?
what's the ambient temp when you're having this problem? I assume once you "break" it free, it's good until the next cold start up? |
September 23rd, 2009, 02:30 PM | #3 |
i bought the bike at 2300 miles, and changed the oil at 3k miles. Its a little over 4k now. It has had the problem since I got it, and i heard synthetic would help, so I changed to mobile 1 10w40 synthetic (which is not energy conserving, so it should be good for MC use). In the past few weeks its been getting worse. Once it breaks free, it won't do it again until the next cold start (as soon as a couple hours) it does it at ambient temps from 50-95 (the only temps we've had)
September 23rd, 2009, 05:29 PM | #4 |
welcome to ninjette Alan! Did you notice anything funny about the oil when you changed it the first time?
September 23rd, 2009, 07:09 PM | #5 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Assuming you've checked at the end of the DIY for clutch cable replacement (how to adjust the cable http://www.ninjette.org/forums/showthread.php?t=16000) it's sounding like internal.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
September 23rd, 2009, 08:20 PM | #6 |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
My bike has a lot of trouble with this too. What I've found that fixes it (I think I read this on the other site ) is to hold in the clutch lever for about 10 to 15 seconds while it's running when you first start it. If that doesn't work, try a little longer. If it still doesn't work, I can't help you.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
September 23rd, 2009, 08:48 PM | #7 |
Join Date: Jun 2009 Motorcycle(s): '97 Ninjette, '06 Ninja 650R Posts: 49
If the clutch cable is adjusted, I would start suspecting that oil. Even non-energy conserving car oils contain things like moly, which may not be the greatest thing in a wet clutch system.
This is mostly anecdotal, but all of what I have read comes out against mobil 1 synthetics for wet clutch use. Most of what I read, however, suggests that the clutch will start slipping, not stick. Just to be on the safe side, and because it is so easy, try changing the oil again and put in a decent moto oil (Motul 10W40 Syn for example), to rule this out as the problem. I would suggest draining the current stuff, dumping about half a quart of the moto oil through the system to flush, and then refilling with the moto oil. Then see if the problem persists. Good Luck. -Kyle
Not all those who wander are lost... -J.R.R. Tolkien |
September 23rd, 2009, 09:04 PM | #8 |
it was doing it before the synthetic went it, I used synthetic to try and cure the problem, which didn't work. If replacing the clutch discs will fix the problem, i'd do that, but I'd hate to put $50 into it and not fix the problem.
BTW: this forum is WAY better than the "riders club" |
Upshifting sticks | ryan.chin | 2008 - 2012 Ninja 250R Tech Talk | 18 | August 12th, 2012 08:14 PM |
[crash.net - MotoGP] - Aspar sticks with Ducati for 2011 | Ninjette Newsbot | Motorcycling News | 0 | August 27th, 2010 01:40 PM |
[superbikeplanet.com] - Soup Sticks A Recorder In Mladin's Face For The Last Time | Ninjette Newsbot | Motorcycling News | 0 | September 6th, 2009 11:10 AM |
[topix.net] - Lorenzo Sticks with Yamaha for 2010 MotoGP | Ninjette Newsbot | Motorcycling News | 0 | August 26th, 2009 12:30 PM |
[crash.net - MotoGP] - Fiat sticks with Yamaha. | Ninjette Newsbot | Motorcycling News | 0 | November 4th, 2008 03:10 PM |
