Old November 22nd, 2019, 11:16 AM   #1
JRay
Motorcycle(s): 2008 Ninja 250
Approximate width between the 2 frame bars where the tail light sits
Hey guys
I have a 2008 that the po tried to convert into a streetfighter. Iam attempting to get it back to original. They cut the frame just past the battery box area. I have fabricated the side frame posts - however Iam trying to get the approx width where the 2 cross backers connect on the top.
I will try to posts pictures so you can see what I currently have.
Thx in advance
JRay is offline   Reply With Quote
Old November 22nd, 2019, 11:16 AM   #2
JRay
* cross brackets. Not backers. Sorry
Old November 22nd, 2019, 11:40 AM   #3
JRay
I posted a couple of photos in my album. Having troubles getting them over here....sorry
Old November 23rd, 2019, 04:30 PM   #4
OMG! This has got to be THE UGLIEST tail-end conversion I have ever seen!!! Whoever did that should be severely BEATEN within millimeter of their life!!! Such horrible destruction of nice bike! You should send them bill for repair work!
Old November 23rd, 2019, 04:34 PM   #5
I've done this restoration many, many times; reverting hacked-up frames from aborted projects. You're doing it in wrong direction and will end up with nothing lining up. Then you'll have to chop off your work and start over again. You need to start from end-result first, then work backwards.
Very first step is to locate tail-light bracket in 3D-space in final location so it will line up with bodywork and fender when everything's completed. You'll need jig to hold tail-light in place while you build everything around it. Luckily, you can use new OEM fender as jig. It has most-important measurement of 4 holes to locate tail-light bracket.
Be sure to add couple washers to simulate bodywork and firmly bolt fender in place so it's rigidly attached. Then use straight-edge strapped to horizontal frame-tube to run its top edge as reference to back. Adjust rear of fender & tail-light bracket vertically so it's in final location. Can use sticks of wood shoved between tyre and fender to maintain vertical alignment.
Then make those little triangular brackets that hold tail-light bracket and fender in place. Bolt all pieces together. When that's done... THEN you fit frame-tubing in place. Don't forget 13.5-degree bend of tubing from frame to tail.
Don't attach new tubing to frame with just butt-welding, it'll break off over time due to vibration and load. You'll want to insert 40mm-long sleeve with same OD as ID of cut-off frame-tubing. Drill hole about 10mm from end of frame-tubing so you can tack-weld sleeve in place. Then you'll really have strong joint with re-attached tubing.
Old November 23rd, 2019, 04:40 PM   #6
With numbers of Ninja 250s being destroyed to do these projects, I'm sure you can get cut-off rear-end to weld back on your bike. Place an ad here, in other forums (racers), and on-line everywhere. I bet someone's got that piece lurking in back of garage somewhere.
EDIT: found one! Here, buy this frame. I'm sure he'll take $50-70 for frame and $10 for fender. I'll run up there to get it. Chop off rear-end and send it to you! Someone else can have forks/triples, rear-swingarm and brakes for pre-gen 17" wheel conversion!
Bottom triple clamp sits too high in frame. Zombarian 1986 - 2007 Ninja 250R Tech Talk 10 May 25th, 2018 05:58 AM
Rear tire width RichmondKawi 1986 - 2007 Ninja 250R Farkles 15 July 5th, 2017 09:04 AM
Seat height and width archaeofreak General Motorcycling Discussion 23 July 4th, 2017 11:07 PM
08-12 front and rear rim width Kangxi 2008 - 2012 Ninja 250R Tech Talk 8 December 17th, 2012 03:23 PM
Address is Approximate gfloyd2002 Videos 14 November 29th, 2011 12:03 PM
