Old November 22nd, 2019, 09:14 PM   #1
aeromantis
Motorcycle(s): Ninja 250r
Revs fluctuating when in gear and and standing still.
Hello, I have an '09 Ninja 250R EFI.
Whenever I stop, in gear whether it be first or second, with the clutch in, the revs will fluctuate rapidly between 1.9k and 2k.
This'll stop the moment I put it into neutral, or pull off.
Any insight is appreciated!
Thanks.
aeromantis is offline   Reply With Quote
Old November 24th, 2019, 10:23 AM   #2
Hi and welcome to Ninjette!
I think this indicates sticky clutch? Try tightening cable 1/2 turn (lengthen housing). Unscrew adjuster at lever-perch by 1/2 turn.
Old November 24th, 2019, 07:22 PM   #3
Does seem odd that it would change when in-gear or neutral unless the clutch needed adjustment as Danno noted, but the mixture may be on the edge of being too lean or there could be a small vacuum leak.
Have you made any adjustments to the idle mixture screws?
Check the clamps on the manifold between the carb and head to make sure they are snug. Also look for small cracks in the rubber.
EDIT - I missed the part about the F.I. - so no idle mixture adjustments...
I would consider the fuel - how old is it? How long have you had the issue? Does it do it when hot, cold, or both?
Make sure the fuel is fresh and run a strong fuel system cleaner like Chevron Techron Concentrate now and once per season.
Check a Service Manual for the TPS setting and set it.
Last futzed with by jkv45; November 25th, 2019 at 08:15 AM.
Old November 24th, 2019, 08:38 PM   #4
aeromantis
Thanks, I'll give this a try at some point when I have time.
Old November 24th, 2019, 08:50 PM   #5
ducatiman
ducatiman's Avatar
Thanks.
My new FI Honda may be designed to perform similar. YOU tell me whether the following scenario is same as yours.
Bike in gear, clutch lever fully pulled in ...normal idle RPM....RPM's rise a few hundred RPM only when clutch is nearly released, almost but not quite where grab occurs.....but at a point where the lever is actuating the clutch switch.
Its been described on a forum (the poster mentioned it being described in your UK Bike magazine) as a "throttle assist", works in conjunction with the lever mounted clutch safety switch to raise RPM to lessen the chance of stalling while easing clutch engagement.
RPM rise does not occur pulling/releasing clutch while in neutral. RPM rise occurs only in gear and RPM can be modulated with clutch pull via activating the switch at its certain point of engagement with clutch lever. So its programmed into the ECU by design.
That all make sense? This all sound like your scenario?
Gotta check my Honda manuals for further detail.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old November 24th, 2019, 09:39 PM   #6
aeromantis
Unfortunately not, this is a new issue that cropped up fairly recently. It doesn't matter how much clutch is applied, it'll keep fluctuating until it reaches the biting point.
Old November 25th, 2019, 08:14 AM   #7
Edited my previous post and added a couple suggestions.
Old November 25th, 2019, 11:02 AM   #8
MrAtom
MOTM - July '15
@ducatiman I have no experience with EFI bikes, so I've never heard of that feature. That is really cool!
Old November 25th, 2019, 11:15 AM   #9
Latest SV650 has that feature as well.
Old November 25th, 2019, 11:32 AM   #10
MrAtom
MOTM - July '15
Good to know. SV650 is on my radar for when I finally purchase a brand new motorcycle, anyway
Old November 25th, 2019, 06:57 PM   #11
ducatiman
ducatiman's Avatar
Suzuki evidently calling it "low RPM assist".
Custom Carb Service
[cyclenews.com] - Webb All The Way At Last Dog Standing Ninjette Newsbot Motorcycling News 0 June 15th, 2015 05:30 PM
[topix.net] - Ewan McGregor revs up the ante as he models biker gear as the face of B Ninjette Newsbot Motorcycling News 0 August 4th, 2012 11:10 AM
[sportrider - latest stories] - The Last Desmo Standing Ninjette Newsbot Motorcycling News 0 April 12th, 2010 11:20 PM
[superbikeplanet.com] - Still Standing Ninjette Newsbot Motorcycling News 0 May 2nd, 2009 01:50 PM
[2fiddy.com] - No Standing on Motorcycles Ninjette Newsbot Motorcycling News 0 June 30th, 2008 09:25 AM
