Old January 2nd, 2020, 06:12 PM   #1
Darksik
Darksik's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R, 99' Suzuki Katana 600 (RIP)
plzz help fuel hose connected to carb???
Hello group, here again give annoying with my 2010 250r
I was changing spark plugs, when disassembling the gas tank I realized that this carburetor hose was connected to the tank, so it must be connected or it must not be connected?
Darksik is offline   Reply With Quote
Old January 2nd, 2020, 06:50 PM   #2
That is drain hose in case fuel-level sender leaks. Other end of hose should follow carb vent-hose and go down to shock area.
Old January 2nd, 2020, 07:38 PM   #3
Darksik
Darksik's Avatar
So i have to disconnect the fuel hose from the carb?
Old January 3rd, 2020, 01:05 PM   #4
No. Nothing connects to carbs from that tank hose.
You need new hose if you don’t have it.
Connect to nipple under fuel-level sender.
Shove other end down between carb-inlet boots and follow carb vent hose to shock area
Last futzed with by DannoXYZ; January 3rd, 2020 at 11:44 PM.
06 250 carb hose routing bowlbug 1986 - 2007 Ninja 250R Tech Talk 5 September 11th, 2018 05:44 PM
carb hose assembly: where's this hose go? chibit89 2008 - 2012 Ninja 250R Tech Talk 7 September 28th, 2016 08:06 AM
Carb Hose Routing jschatte 1986 - 2007 Ninja 250R Tech Talk 6 July 8th, 2014 08:30 AM
Carb hose sizes? Hero Danny 1986 - 2007 Ninja 250R Tech Talk 2 May 31st, 2014 07:11 AM
Where does the other end of this carb hose go? indr 2008 - 2012 Ninja 250R Tech Talk 2 May 13th, 2013 05:45 AM
