Old January 2nd, 2020, 06:32 PM   #1
Darksik
Darksik's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R, 99' Suzuki Katana 600 (RIP)
Spark plug coil BROKEN?!?
Hello group I need your help urgently, I was changing the spark plugs and when trying to remove wire, it broke but you only see that the rubber was broken, attached images, is it still useful or do I need to buy another one?
Also i checked inside the coil had this green thing, that is how need to be or i need to remove that green thing?
[URL=https://app.photobucket.com/u/ari95style/p/adbc74da-0ef4-4041-bb5f-1078311f786d][/URL
Can i put any replacement or I need a OEM?
Please help!.
Darksik is offline   Reply With Quote
Old February 9th, 2020, 11:55 AM   #2
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
https://www.ninjette.org/forums/showthread.php?t=218866
I ask just broke the wire going to the coils, just happened to me yesterday, found this post
Old February 9th, 2020, 03:37 PM   #3
Be sure to pull plug wires in-line with spark-plug axis. That would be angled up towards front rather than vertically. Sometimes, it's easier and safer to drain and remove radiator so you can reach in from front and pul! plug wires off towards front.
Here's great info on repairing plug wires.
https://www.ninjette.org/forums/show...postcount=8059
Old February 10th, 2020, 04:53 PM   #4
nocturncal
nocturncal's Avatar
This might be a dumb question, but if I wanted to replace the wires for the coil, could I use 8AWG THHN copper electrical wire?
Coil wire for cylinder #2 has got some corrosion going on inside, snipped the wire till no more corrosion (about an inch).
Old February 10th, 2020, 06:53 PM   #5
If you're talking about red/black or red/green ground & trigger wires for coil, 8awg is way overkill. Use something that's similar to original size.
If you're talking about high-tension spark-plug wires, 8awg won't work. Spark-plug wires typically have thin carbon-fibre "wire" in centre with thick insulation on outside that can withstand +50k-volts. I usually buy it in bulk for bike & auto projects:
https://www.summitracing.com/parts/tay-35271
I may have spare plug-wire somewhere, let me check and get back to you.
Help! Broken Spark Plug... justanotherone1 1986 - 2007 Ninja 250R Tech Talk 10 September 23rd, 2019 05:05 AM
coil and plug wire help gantt 2008 - 2012 Ninja 250R Tech Talk 7 March 5th, 2015 07:50 AM
top of spark plug stuck in coil Nova46 2008 - 2012 Ninja 250R Tech Talk 18 June 10th, 2014 07:00 PM
Broken Spark plug? Yasko General Motorcycling Discussion 8 June 8th, 2011 08:39 PM
Change to Coil over plug Choter 2008 - 2012 Ninja 250R Tech Talk 7 January 7th, 2011 11:03 AM
