Old April 28th, 2018, 05:07 PM   #1
Darksik
Darksik's Avatar
[NOOB] Good Air Filter and fender eliminator
Hi guys maybe this could be a noob question, but somebody could tell me about a good and cheap air filter, because i think my bike have the stock air filter and the bike have 10k miles.
If the air filter is on ebay is better, because here in mexico many stores don't sale pieces for the ninja, and the kawasaki store they sold me the air filter in $50-$60.
I hope somebody can help me
Last futzed with by Darksik; April 29th, 2018 at 12:24 AM.
Old April 29th, 2018, 06:27 AM   #2
Do you have service manual? Factory filter should be washed yearly and re-oiled. It will easily last 40-50k miles. Although it will wear more with age than miles. If yours is crumbling from lack of oil, get one of these.
https://www.ebay.com/itm/High-Flow-A...-/122797732844
I got one of those for my race bike and use K&N filter oil from spray can.
Old April 29th, 2018, 11:53 AM   #3
Darksik
Darksik's Avatar
But I noticed that i don't see anything through the air filter when put at the sun, or that is not a problem?
Old April 29th, 2018, 12:56 PM   #4
Should not be able to see light through it. That might be test that shows bad filter.
Did you wash filter? Did a lot of dirt come out?
Old April 29th, 2018, 03:35 PM   #5
Darksik
Darksik's Avatar
When i check the air filter only got dirt, fuzz and smells like oil
Old April 30th, 2018, 06:01 AM   #6
Might be time for washing filter.
Old April 30th, 2018, 12:35 PM   #7
ninjala
Motorcycle(s): 2008 Ninja 250
You don't need to buy additional air filter. The stock air filter lasts forever if you carefully wash it every 6k.
You can wash it with liquid dish soup and rinse with water. after dry in the air (overnight) or by fan or heat gun (no heat!), then oil the filer with motor oil SAE 30.
ninjala is offline   Reply With Quote
Old April 30th, 2018, 09:34 PM   #8
Darksik
Darksik's Avatar
But where do you use the oil? Also i only have 20w-50 mineral oil, could i use that oil
Old April 30th, 2018, 10:00 PM   #9
Pour a little oil on filter and rub it around. Squeeze filter into small ball shape to spread oil.
That's why i like spray oil, easy to get even layer of oil.
https://www.amazon.com/dp/B00029WYDK/
Old May 1st, 2018, 05:40 AM   #10
MLR
MLR's Avatar
You want proper foam air filter oil, it comes in a spray can and lasts for ages because you only lightly spray it, to much oil can cause issues and is a waste.
I have a UNIFILTER on my 250R, $15 AU on Ebay IIRC.
Some of the "high flow" filters are rubbish at filtering anything smaller than a duck.
Old May 1st, 2018, 06:14 AM   #11
Yes, but ducklings come in different particle sizes!!!
Old May 1st, 2018, 02:08 PM   #12
MLR
MLR's Avatar
The 3rd from the left looks about 80 micronducks, that is the size I was referring to.
Couldn't find a good how-to video for a pregen Ninja 250 fender eliminator, so I made Cra1g 1986 - 2007 Ninja 250R Farkles 16 December 2nd, 2016 09:34 AM
Anyone know an air filter I can replace the OEM filter with? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 5 July 22nd, 2012 09:34 AM
Is this a good buy? (Exhaust + Fender Eliminator) AeroXtasy Items Wanted 4 February 6th, 2012 05:34 PM
