Old October 26th, 2016, 09:20 AM   #1
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Crankcase opening dimensions needed ?
Hi Guys,
Does anyone have a 250 crankcase minus its block at the moment that they could measure for me ?
I need the width of the cylinder base openings left the right & front to back, I assume both sides are the same.
Plus I need the web thickness between the holes.
if anyone happens to have a 250 piston complete with rings & wrist pin that they could weigh accurately it would be appreciated. I have found a note somewhere that they are around 167grams complete, just need that confirmed.
Thanks
Chris.
Last futzed with by Mohawk; October 26th, 2016 at 10:33 AM.
Old October 26th, 2016, 12:53 PM   #2
garth285
KAWASAKI GURU
garth285's Avatar
will any measurements from a 08-12 engine help you?
Old October 26th, 2016, 02:48 PM   #3
Mohawk
Mohawk's Avatar
I believe the crank cases are the same on the pre-gen & next-gen, so yes that should be fine. Thanks
Old October 29th, 2016, 03:23 PM   #4
Mohawk
Mohawk's Avatar
Bum, any joy with the Tahoe measure ?
Old November 20th, 2016, 09:17 PM   #5
Petrolh34d
Motorcycle(s): 2004 ninja ex250, 1996 Honda cbr900rr
I'll see if I can be of assistance
Petrolh34d is offline   Reply With Quote
Old November 21st, 2016, 12:30 AM   #6
Mohawk
Mohawk's Avatar
Many thanks Petrolh34d.
Old November 25th, 2016, 08:13 AM   #7
Mohawk
Mohawk's Avatar
BUMP
Old December 6th, 2016, 11:27 AM   #8
bruce71198
bruce71198's Avatar
Originally Posted by Mohawk View Post
BUMP
Do you still need these ?
Old December 6th, 2016, 12:43 PM   #9
Mohawk
Mohawk's Avatar
yes please
Old December 9th, 2016, 10:03 AM   #10
Mohawk
Mohawk's Avatar
Come on you teasers, someone must have one in bits. Also need the thickness of the bridge between crankcases.
Old December 17th, 2016, 02:56 AM   #11
Mohawk
Mohawk's Avatar
Bump
Old December 17th, 2016, 01:21 PM   #12
bruce71198
bruce71198's Avatar
Bump
[IMG][/IMG]
[IMG][/IMG]
I'll weigh a piston assembly and post later.
Old December 17th, 2016, 02:01 PM   #13
bruce71198
bruce71198's Avatar
[IMG][/IMG]
That's the piston, pin, circlips and rings.
Old December 18th, 2016, 01:19 AM   #14
Mohawk
Mohawk's Avatar
Hi Bruce, thanks for those, much appreciated.
Old December 20th, 2016, 10:51 AM   #15
Mohawk
Mohawk's Avatar
So as I suspected, my new big bore liners will need a little metal removed from the left & rights sides where the liner cutouts are, but loads of room front to rear.
Thanks for the complete pisyon weight too. My big bore ones will weight 180 grams complete, (132gm bare), so 20 grams up on stock, but still lighter than the JE (139gm bare) or Wiseco (152gm bare) versions, which appear to work with stock rods.
Anyone know how deep the cylinder cut outs are in the side walls of the crankcase ? By that I mean from the top gasket face to the bottom of the scolloped area.
Old December 22nd, 2016, 09:52 AM   #16
Mohawk
Mohawk's Avatar
Just an avatar test
Old December 23rd, 2016, 11:11 AM   #17
bruce71198
bruce71198's Avatar
how big are you boring this engine?
Old December 23rd, 2016, 12:50 PM   #18
Mohawk
Mohawk's Avatar
66mm for 282cc using ZZR600 liners but having had them fitted to a spare block, then discovered the 250 liner is narrower at the bottom.
So thanks to your help, I now know I need to widen the cutouts slightly left to right, but they are fine front to rear. Then I remembered that the new liners are 3mm taller than the 250's so need to know if I need to trim the length !
Old December 25th, 2016, 12:07 AM   #19
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Your avatar pic looks just like your profile pic.
Old December 27th, 2016, 05:24 PM   #20
bruce71198
bruce71198's Avatar
I widened the cases with a die grinder and carbide bit. It was relatively easy and didn't take to long. 3mm should clear the crank, if not clearance it with the die grinder.
Front master cylinder piston dimensions? ds650rida 1986 - 2007 Ninja 250R Tech Talk 3 May 4th, 2014 04:35 PM
CVK32 Carb dimensions The_big_dill 1986 - 2007 Ninja 250R Tech Talk 7 May 31st, 2013 01:34 PM
brake banjo bolt dimensions? smokinsingle 2008 - 2012 Ninja 250R Tech Talk 3 February 29th, 2012 09:50 PM
Dimensions GateKeeper 2008 - 2012 Ninja 250R Tech Talk 7 October 28th, 2011 01:48 PM
Race Body Work number dimensions Broom Ninjettes At Speed 6 January 28th, 2009 09:47 AM
