November 4th, 2016, 05:32 PM | #1 |
Help with hose
2003 ex250f. Just changed plugs. Was putting fairings back on and saw two hoses that I don't think go together but I want to be sure. One is the fuel overflow from the carb but I have no idea what the other is. I've attached a pic from the left side. Any help would be awesome.
November 4th, 2016, 05:45 PM | #2 |
The S shaped hose is the crankcase breather hose, it attaches to the bottom of the airbox
November 4th, 2016, 05:58 PM | #3 |
So no reason to connect those two then?
November 4th, 2016, 07:27 PM | #4 |
No, the carb vent line needs to open to let the fuel into carbs, and in case they overflow, some people just remove the hose, others leave it hanging.
The crankcase breather hose connects to the bottom of the airbox, I'm assuming that it's there.
November 4th, 2016, 08:35 PM | #5 |
No the person before me installed pod filters.
November 5th, 2016, 12:12 AM | #6 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
he said hoes
November 20th, 2016, 09:05 PM | #7 |
Join Date: Aug 2016 Motorcycle(s): 2004 ninja ex250, 1996 Honda cbr900rr Posts: 31
carb hose assembly: where's this hose go? | chibit89 | 2008 - 2012 Ninja 250R Tech Talk | 7 | September 28th, 2016 08:06 AM |
Where does this hose go? | eric78 | 1986 - 2007 Ninja 250R Tech Talk | 3 | May 11th, 2014 06:40 PM |
what is this hose? | 91satanslegend | 1986 - 2007 Ninja 250R Tech Talk | 13 | November 4th, 2011 11:28 AM |
Name this hose | WAGESLAVEesc | 1986 - 2007 Ninja 250R Tech Talk | 10 | August 18th, 2011 09:47 PM |
What is this hose? | caps | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 30th, 2011 04:58 PM |
