Old November 7th, 2016, 03:30 PM   #1
acook3323
Motorcycle(s): 2005 ninja 250
Exclamation Camshaft issue
Has anyone had a camshaft snap in half on them. My bike only has 6600 miles on it and it's broken! Is it possible for these to be defective?
acook3323 is offline   Reply With Quote
Old November 7th, 2016, 03:38 PM   #2
You just proved that it's possible. Sorry to hear about it, but unless you find something that caused it to lock up or something, it was just a defective part. I don't know your specifics, but it might be possible to get some help from Kawasaki.
Old November 7th, 2016, 05:00 PM   #3
Originally Posted by acook3323 View Post
.........My bike only has 6600 miles on it and it's broken!.........
Pictures of the broken section?
Old November 7th, 2016, 06:51 PM   #4
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
I suppose it could break if one or more of the cam bearing caps was loose. The bolts might have backed out and became loose or (like mine was) the previous owner had over torqued one of the cam cap bolts and broke it....then just left it and put the cam cover back on. Luckily I found it before anything else broke.
Old November 7th, 2016, 07:52 PM   #5
acook3323
Old November 7th, 2016, 07:57 PM   #6
acook3323
I talked to a buddy of mine at a machine shop and he said by the looks of the break that it was most likely cracked during heat treatment and that it finally just gave out which is a lot better for me than a valve causing it to break
Old November 10th, 2016, 04:59 PM   #7
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Wow! That's really messed up
Old November 10th, 2016, 05:39 PM   #8
Z1R rider
Z1R rider's Avatar
@acook3323
was one of the cam caps loose or miss matched (reassembled in a none stock location) so that it had too much clearance or too tight at the bearing? I know, hard to tell what a PO might have done.
Old November 10th, 2016, 05:44 PM   #9
acook3323
I took the cam itself to a machine shop and they believe that it was a defective part that already had a crack in it and just gave out.
Old November 10th, 2016, 05:53 PM   #10
You can usually tell if that's the case because part of the cracked surface looks different from the rest.
Old November 10th, 2016, 09:52 PM   #11
https://en.wikipedia.org/wiki/Fatigue_(material)
http://www.totalmateria.com/page.asp...ite=kts&NM=299
Old November 11th, 2016, 03:44 AM   #12
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Yes that can happen from a manufacture or user damaage. Cams are very hard & made from a brittle material, so dropping them can cause cracks adjascent to where the profile changes or machining has taken place as those areas concentrate the shock loads.
Cam bearing caps if removed should always be put back on the shell half they came from, if not then the cam can set up a flex which can cause a shear in the same high stress points. But with such low mileage, I would hazard a guess that the part was defective.
Did it cause any other damage ? Valves, pistons etc ? If not you were lucky. I would approach Kawasaki, they may supply parts at cost as a good will gesture. But if not other damage was done, just get a second hand cam & off you go.
Last futzed with by Mohawk; November 12th, 2016 at 01:48 AM.
Old November 12th, 2016, 12:22 PM   #13
Reading your other related thread, I realized the following:
You should take any new camshaft and the cylinder head back to that shop.
Assuming the new camshaft is OK, if they find out that one or more of the journals are worn (the internal diameter/shape is greater than the specification's limit), you will suffer a similar failure again.
The reason is that the shaft should be supported by three journals, which support the cyclic bending forces produced by opening and closing the valves and by the rotating masses of the cams.
The material of the shaft is very hard to resist friction but very fragile to resist bending.
If the gap between journal and cam grows too big, proper lubrication does not happen anymore (the protective film cannot sustain itself); resulting a shaft that is scraping soft aluminum from the journal, making bigger in diameter and/or out of round.
Once that has happened, the shaft is supported and preventing from bending too much only by two journals.
Yes, the amount of deflection may be imperceptible, but fatigue (please, see above link) happens due to amount of deflection as much as due to number of cycles of deflections.
Any of those shafts can spin as much as 6000 times per minute or 100 times per second, when the tachometer is marking 12000 rpm.
Old November 20th, 2016, 09:02 PM   #14
Petrolh34d
Motorcycle(s): 2004 ninja ex250, 1996 Honda cbr900rr
Highly likely that it was cast defectively from the factory
Petrolh34d is offline   Reply With Quote
Camshaft bearing juliusmichaelhonrada 1986 - 2007 Ninja 250R Tech Talk 4 August 18th, 2016 12:44 AM
Camshaft questions 86,87 vs 88+ Rollingmenace 1986 - 2007 Ninja 250R Tech Talk 5 May 20th, 2014 11:49 AM
Camshaft Issue jpatt87 2008 - 2012 Ninja 250R Tech Talk 42 March 25th, 2014 02:49 PM
camshaft profiles micoulisninja 2008 - 2012 Ninja 250R Tech Talk 30 February 12th, 2014 04:01 AM
Intake Camshaft jpatt87 Items Wanted 14 January 19th, 2012 08:55 AM
