Old January 26th, 2020, 03:29 PM   #1
01UkAtO
Motorcycle(s): Kawasaki GPX250r
carb boots
I am trying to find replacement carb boots for my 04 gpx 250 but cannot find anything. I can found allot of 88-95 and 07+, Just wondering if the 95 would fit. Im assuming the newer ones would have changed to much.
01UkAtO is offline   Reply With Quote
Old January 26th, 2020, 05:45 PM   #2
59096
59096's Avatar
Motorcycle(s): GPX250 1989 model and 1990 model
They are the same 87 to 07. Don’t know about +07? Just make sure you put them on the correct way around. They have “carb” stamped on one end if I remember correctly which must face the carb. Putting them on the wrong way around will have a small negative effect on performance.
Perpetua Culpa Alterna Vagus
Last futzed with by 59096; January 26th, 2020 at 05:47 PM. Reason: Add more info
59096 is offline   Reply With Quote
Old January 26th, 2020, 11:21 PM   #3
Depending on market, ‘86-87 was 1st-gen and used boots #16065-1141
Pre-gen models ‘88-07 should use part#16065-1156 and can be found here:
https://www.bikebandit.com/oem-parts...5-1156/b781826
New-gen ‘08-12 boots are shorter and won’t work.
Old January 26th, 2020, 11:35 PM   #4
59096
59096's Avatar
That’s right - the first gen had 32mm carbs I think. After that they went to 30mm so I guess the boots were a different size starting 88.
Old January 27th, 2020, 10:38 AM   #5
01UkAtO
What about the airbox side boots?
Old January 27th, 2020, 11:31 AM   #6
Yup, same thing. All pre-gen ‘88-07 used same air-ducts.
https://www.bikebandit.com/oem-parts...3-1307/b775148
Old January 27th, 2020, 01:46 PM   #7
01UkAtO
I was able to find some replacement boots. Thanks for all the help guys.
Old January 28th, 2020, 02:19 AM   #8
Intake to Carb Boots Thatdudeguybro 2008 - 2012 Ninja 250R Tech Talk 7 May 5th, 2017 10:07 AM
Gas Tank Removal; Carb Boots aweesner 1986 - 2007 Ninja 250R Tech Talk 1 September 6th, 2011 06:53 AM
