Old June 2nd, 2010, 11:44 PM   #1
03slime250
Motorcycle(s): 2003 ninja 250
she dont like a dead battery
got off work tonight and went to start her and just got clicking and flickering......got it push started in the parking lot and it did not like running off the alternator by itself.......guages were everywhere, lights were flickerin, acted like it was outta gas....good thing i only had a few miles to go.......just a tip, turning on my brights made it "driveable"
03slime250 is offline   Reply With Quote
Old June 3rd, 2010, 12:11 AM   #2
your battery may well be toast if it's been a few years since it's been changed, but check to see if the battery terminals are tight before deciding that you need a new one.
I was under the impression that the alternator could put out enough juice to power the bike once it was running, so you might have another issue.
Old June 3rd, 2010, 12:35 AM   #3
03slime250
yep, was a loose battery connection
from what i read on ninja250, its not like a car, ours puts out juice in spurts and the battery stabilizes it and our system doesnt like the spurts
http://faq.ninja250.org/wiki/Why_you...eeds_a_battery
Old June 3rd, 2010, 12:42 AM   #4
that's with a dead battery or at least one that's much lower than what it's supposed to be. Batteries usually give you some indication that they are on their way out beforehand and with yours just up and quitting, it sounded like something else besides a bad battery.
glad it was something simple.
Old June 3rd, 2010, 06:52 AM   #5
mrlmd
mrlmd's Avatar
A warning here - if anyone gets a new AGM battery for their bike, it MUST be charged up fully BEFORE FIRST USE or it's capacity will be severely reduced and will fail very early, like maybe after only a few starts of the bike. Regardless of what any battery dealer or seller tells you, that it's ready to go out of the box when you get it, it MUST BE CHARGED UP FIRST. Don't just rely on a voltage test that says 12.6V or so at rest. If you don't charge it first, you will be back at that dealer getting another one pretty quick.
Old June 3rd, 2010, 07:49 AM   #6
I've run mine totally dead on a current-gen and had a lot of trouble with thegauges after pop-starting it. Like the tach would fly up to max at anything under 4K RPM and the bike would barely run at stoplights. Weird.
Possible dead battery roc0487 2008 - 2012 Ninja 250R Tech Talk 22 April 14th, 2015 01:37 PM
Electrical Issue - Dead Battery? k24_cm7 2008 - 2012 Ninja 250R Tech Talk 8 March 17th, 2012 12:25 AM
battery dead? ProdigyRacingLA 2008 - 2012 Ninja 250R Tech Talk 17 March 14th, 2012 08:42 PM
Battery dead, I have an old charger.... Kurgan 2008 - 2012 Ninja 250R Tech Talk 5 January 5th, 2012 10:11 AM
Less than 4k mi. on '09 ninjette . Battery already dead 00v_Lucky 2008 - 2012 Ninja 250R Tech Talk 10 June 17th, 2009 06:21 AM
