Old March 25th, 2011, 02:34 PM   #1
02ninjaeastbay
Motorcycle(s): 2002 Ninja 250
Unhappy PLEASE HELP possible tranny issues?
I was riding along and the bike started becoming really sluggish, eventually it cleared up and revved and idled fine. Then I stop and fuel up, and shift into first and the bike immediately dies. I tried many different rpm's with the same result. It doesnt gradually die, it instantly dies. Anyone else had this issue, please help or im walking in the rain.
02ninjaeastbay is offline   Reply With Quote
Old March 25th, 2011, 02:46 PM   #2
bluepoof
bluepoof's Avatar
Motorcycle(s): 2007 Ninja 250, 2002 Yamaha XT225
So, the immediate problem you're having is that the bike is on and idling fine in neutral, you shift into first, and it immediately cuts out?
The easiest thing to check is that your sidestand is fully up -- if it's down, the bike will die when you shift into first.
www.bluepoof.com
bluepoof is offline   Reply With Quote
Old March 25th, 2011, 02:48 PM   #3
Is the bike jerking forward as you put it into first, or does it die immediately in place with no jerk at all?
If it just dies immediately, it sounds like an electrical problem, and a likely culprit is a faulty sidestand switch. Another option is the clutch switch, (less likely), and least likely, is a flaky kill switch itself.
If it's just doing weird unexplainable electrical things, yet the switches seem good, another possibility is simply an old and failing battery.
EDIT: good catch Carolyn, the switch might not be faulty at all if the sidestand is accidentally left down...
Old March 25th, 2011, 02:49 PM   #4
02ninjaeastbay
it dies immediately with no movement at all.
Old March 25th, 2011, 02:51 PM   #5
02ninjaeastbay
someone told me the tranny might be locked. does that happen? is that a possiblity?
Old March 25th, 2011, 02:58 PM   #6
Indy250r
Indy250r's Avatar
Motorcycle(s): 2011 KTM 990 ADV
That sounds like a faulty kickstand switch, as mentioned above.
Indy250r is offline   Reply With Quote
Old March 25th, 2011, 02:58 PM   #7
sowega
sowega's Avatar
Motorcycle(s): 899, 748, 250, 250, 70
Is it a pre- or post-op tranny?
sowega is offline   Reply With Quote
Old March 25th, 2011, 03:10 PM   #8
Cab305
Cab305's Avatar
Motorcycle(s): Blue 10 250r
If it's pre.... does it still count as a tranny or just a cross dresser?
Cab305 is offline   Reply With Quote
Old March 25th, 2011, 04:34 PM   #9
bluepoof
bluepoof's Avatar
Check the simple things first. I wouldn't even start thinking about a transmission problem until I'd 100% absolutely positively ruled out (a) the sidestand not being fully up and, then, (b) the sidestand switch malfunctioning in some way.
Setting aside the general rule of the simplest explanation often being the correct one -- mechanical issues, like a transmission issue, are usually fairly "violent". You would feel the bike buck or lug or otherwise physically respond to the transmission locking. Electrical issues are usually fairly smooth and binary. The fact that your bike dies immediately with no movement at all makes me think it's electrical, not mechanical.
www.bluepoof.com
Old March 25th, 2011, 04:51 PM   #10
"A"
vampire
Motorcycle(s): 2 many 2 list
Question
Does the bike idle and run while it is on the centerstand?
How about when you put it in first gear (or any other gear) while it's parked and engine running on the centerstand?
Make sure that sidestand is fully retracted.
"A" is offline   Reply With Quote
Old March 25th, 2011, 05:39 PM   #11
02ninjaeastbay
this all happened when i was on my way to work, so I will go outside on my break and try all your suggestions out and give you an update. Thanks!
And a question to you carolyn or alex, how do I rule out the sidestand switch? voltmeter? idk. sorry im such a newbie.
Old March 25th, 2011, 06:19 PM   #12
02ninjaeastbay
Exclamation
ok update: i got it to start up and run around the block with no issues, then it died when i slowed down and parked. now whenever i give it any throttle it bogs down and dies. what does that sound like?
Old March 25th, 2011, 06:43 PM   #13
"A"
vampire
Question
What is the idle rpm?
Mine is set around 1500-1700 rpm.. I usually leave the choke on for good 5 min. before riding off... engine would idle near 4k rpm with choke.
Old March 25th, 2011, 06:53 PM   #14
02ninjaeastbay
i havent gotten it to stay on long enough to see what my idle rpm's are right now. it dies before that. about 5-6k is what its doin with the choke on though.,
Old March 25th, 2011, 06:55 PM   #15
"A"
vampire
Can you tell if both cylinders are getting spark?
Old March 25th, 2011, 07:05 PM   #16
02ninjaeastbay
yeah they are both turning over and running.
Old March 25th, 2011, 07:36 PM   #17
wvninja
wvninja's Avatar
Motorcycle(s): 2009 Honda CBR600RR
Did the pre-gens have issues with vapor lock inside the gas tank?
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja
wvninja is offline   Reply With Quote
Old March 25th, 2011, 07:47 PM   #18
"A"
vampire
But are both headers hot?
Old March 25th, 2011, 07:50 PM   #19
yes.
Old March 25th, 2011, 08:05 PM   #20
02ninjaeastbay
ya both headers are hot. and what is this vapor lock? sorry im new to riding.
Old March 25th, 2011, 08:33 PM   #21
try popping the cover to the gas tank when you are having running issues and see if that alleviates the problem.
from your earlier symptoms, though, it sounded like a sidestand switch to me.
Old March 25th, 2011, 08:40 PM   #22
Don.Copely
Racer-X
Don.Copely's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r
Just don't hang with trannys, the problem should go away
2009 Candy Thunder Blue 250r/Don.Copely
Don.Copely is offline   Reply With Quote
Old March 25th, 2011, 08:54 PM   #23
02ninjaeastbay
Oh my god forum, If figured it out and it was being out of gas. i switched to the reserve and it seems to be alright. BUT i still have a question, i contacted the previous owner and he told me put a jet kit in it put on pods deleted the airbox etc etc. I only had 135 miles on the tank, is that insanely bad? are the mods extensive enough to account for such poor gas mileage?
Old March 25th, 2011, 09:45 PM   #24
there's no way that trannys don't hang.
you should be getting close to 200 miles before having to switch to reserve. fill up the tank (to the top), reset the trip meter to 0000 and then see how long it takes before the bike needs to be switched to reserve. Don't forget to put the petcock back to the ON position or you won't have a reserve to go to next time.
Old March 25th, 2011, 10:57 PM   #25
bluepoof
bluepoof's Avatar
I've done that more times than I want to admit.
www.bluepoof.com
Old April 15th, 2011, 02:51 PM   #26
sowega
sowega's Avatar
Doh! Almost as embarrassing as hanging out with trannies.
Old April 16th, 2011, 07:49 AM   #27
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Been there, done that. (the fuel thing)
"I'm the one that's got to die when it's time for me to die, so let me live my life, the way I want to" - Jimi Hendrix
Cancer
JeffM is offline   Reply With Quote
[superbikeplanet.com] - "Seamless Tranny" Not Keywords To A Really Vulgar Casual Enco Ninjette Newsbot Motorcycling News 0 September 11th, 2013 03:20 PM
First motorcycle, first manual tranny IF13 Riding Skills 19 July 18th, 2013 12:48 PM
Tranny parts j98sprint Free stuff! 9 May 11th, 2013 08:44 PM
Replaced Tranny, now it won't shift? OneWheelPeel 1986 - 2007 Ninja 250R Tech Talk 7 December 25th, 2012 05:05 PM
Tranny or clutch? cuz 2008 - 2012 Ninja 250R Tech Talk 10 September 30th, 2012 04:13 PM
