Old June 28th, 2011, 11:50 PM   #1
02ninjaeastbay
Motorcycle(s): 2002 Ninja 250
Bike won't start-Had to leave it at work!
So its rainy here today, and i got off work and went to start it and it wouldn't even crank over. Tried to jump it to no avail. Anyone have any ideas? Starter, etc.? The bike just hit 18k miles. Let me know what you think and I will head back up to work and try them tomorrow. THANKS!
EDIT: And by the way, all the lights light up fine, etc etc. And it did get wet today, but it wasn't sitting in the rain.
02ninjaeastbay is offline   Reply With Quote
Old June 28th, 2011, 11:55 PM   #2
just make sure the car you jump off of is off otherwise you can fry your regulator. they're not built to regulate the amount of power a car alternator puts out... ask me how i know
sounds like something got shorted. perhaps the power somewhere or maybe something simple like a kickstand switch? check how much power your battery has. if it's full check to see if your sidestand switch is shorted. if they're good check the cdi to make sure its not drenched in water
Old June 29th, 2011, 12:14 AM   #3
how old is the battery?
Old June 29th, 2011, 05:15 AM   #4
Cuongism
Cuongism's Avatar
Engine isn't turning but do you hear it clicking? If not at all, maybe someone flipped your killswitch?
Old June 29th, 2011, 06:41 AM   #5
darrell85
darrell85
darrell85's Avatar
Motorcycle(s): 2001 250 ninja
+1 for kill switch. i also was at work and mine did the same thing, messed with the battery cables etc. no luck. turns out one of the other riders at work flipped my kill switch. since i never use the kill switch, it never occured to me that it could be the problem.
darrell85 is offline   Reply With Quote
Old June 29th, 2011, 06:44 AM   #6
ricochet08
ricochet08's Avatar
Motorcycle(s): 2007 ninja ex500, 2010 Ninja 250r, 2004 zzr600, 2003 CBR600rr, 2013 Ninja 300...in that order :D
+1
friend of mine (he rides also) flipped the switch on me and i didn't even think of checking. I was stumped. Then i remembered the big red button and I was on my way
Edit: Dang it Darrell, i started this reply 10 mins ago but i got a call at work and didn't hit submit! :P
ricochet08 is offline   Reply With Quote
Old June 29th, 2011, 07:18 AM   #7
money
money's Avatar
Motorcycle(s): 2011 Ninja 250r
Not to derail, but what do you guys who don't use the kill switch do to turn off the bike? Do you just turn the key?
MTGATT
money is offline   Reply With Quote
Old June 29th, 2011, 07:35 AM   #8
road_rascal
Motorcycle(s): ___
On the 250 I just use the key. On my Wing if I'm backed down an incline to park I use the kill switch since I have to hold the brake lever.
road_rascal is offline   Reply With Quote
Old June 29th, 2011, 08:35 AM   #9
darrell85
darrell85
darrell85's Avatar
yes, i just use the key. the only time i have ever used the kill switch is when i needed the lights on after i stopped.
Old June 30th, 2011, 05:27 AM   #10
02ninjaeastbay
So it wasn't the kill switch, I still use it sometimes. I went back to work today and it started right up! Maybe something was wet and it dried out. Anyone have any idea on what could easily get wet then dry out, so I can avoid this problem again? And thanks for all the responses.
Old June 30th, 2011, 06:59 AM   #11
Bosgarage57
Bosgarage57's Avatar
Motorcycle(s): 06 Buell Uly, 05 VStar 1100
I ALWAYS park in 1st gear, so when I come to a stop I use the kill switch, then flip it back on, then turn key off. Its just a habit of mine, so when you're ready to go just put key in, turn and start.
Bosgarage57 is offline   Reply With Quote
Old June 30th, 2011, 08:53 AM   #12
kickstand sensor. the clutch sensor is the only other (iirc) disconnect path, but open on clutch is disconnect, so a short wouldn't keep it from starting. kickstand i believe is the only one with a closed disconnect. a short would make it think you're trying to start with the kickstand down. good way to diagnose next time it happens is to kick it into neutral and try starting it.
to the other topic in this thread, my park proceedure: roll up looking like a badass, park backwards to make a quick getaway, kill it with the kickstand, flip the kill switch off, turn the keys and lock the steering, take my helmet off so everyone can see my beautiful mug... until they see it and realize how hideously ugly and un-badass i am walk away in shame as all the ladies point and laugh
bike won't start. tried everything rabies 1986 - 2007 Ninja 250R Tech Talk 17 September 22nd, 2013 04:46 AM
Bike won't start Z300 2008 - 2012 Ninja 250R Tech Talk 21 August 26th, 2012 09:05 PM
Bike won't start. Need help please. mychelle 2008 - 2012 Ninja 250R Tech Talk 29 November 5th, 2010 10:36 AM
Bike down...won't start Lurkable 2008 - 2012 Ninja 250R Tech Talk 17 November 23rd, 2009 02:49 PM
