June 18th, 2013, 11:52 AM | #1 |
Join Date: Jun 2013 Motorcycle(s): 2005 Ninja 250 Posts: 2
Front turn signal issues...
So, I'm sorry for my first post to be asking for help, but I don't know what else to do with my problem.
I recently bought an 05 ninja 250, for cheap. It has been down at least a few times. pretty much every fairing was busted in a few spots. Only had one turn signal(rear) needed a front tire and a battery, but did run, and didn't have a ton of miles. I got most of it fixed, and now I am working on turn signals... I am still waiting on parts for the rears, putting them in the side pods of the tail, and I bought some ebay china flushmounts for the front. They have 3 wires, red, black, and black/white. I figure the 3rd is for running lights, and they do have dual fil. bulbs. I wired the black/white into the red/blue stripe wire from the harness to the instrument cluster, and the black to the black/yellow(or whatever color that other wire is) and the red to the green for hot. When I start the bike, both lights light up....but one is on the brighter filament, and the other is on the dimmer filament...and the turn signal switch doesn't do anything.... Anyone got any advice? |
June 18th, 2013, 12:29 PM | #2 |
Join Date: May 2013 Motorcycle(s): 2003 Kawasaki Ninja 250 Posts: 154
Can you take the lamps out and turn them around?
My parents had a car that had turn signal lamps that had a bright filament and a less bright filament, and you could fit the lamps in backwards, leading to symptoms as you describe. |
June 27th, 2013, 07:07 PM | #3 |
Bump for more help.
June 27th, 2013, 09:23 PM | #4 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
Front right turn signal, black/yellow goes to black/yellow,
Grey goes to grey. The third wire would be your running light wire. Left front turn signal, black/yellow goes to black/yellow, Grey goes to green, the other wire would be your running light. Being after market lights the colours may be different, so you will have to try different combinations to find the correct setting. We don't have running lights in Australia, but my guess is that the running light will be the duller of the two, the turn signal will be the brighter fillament. Also, make sure you have both bulbs in, front and back, otherwise the flasher will nor work, the light will just stay on. Hope this helps. |
June 27th, 2013, 10:53 PM | #5 |
Certified looney toon
MOTM Jul '13, Jul '14
You have the same eBay lights as me.
This diagram really helped understand the bulb. http://mgaguru.com/mgtech/electric/et107a.htm Based on the pictures of endless experiments, I have mine wired like this: Red to green (turn signal) Black/white to black/yellow (ground) Black tapped into taillight wire (running light) To make it easier to disconnect when I remove the fairing, I went out and bought a three wire connector from the local hardware store, wired the male end to the flush mounts and the female end to the original stock wire with a third one to the tail light wire. Edit: after doing that, the lights blink REALLY FAST. I had to go get an electronic flasher to return it to a normal pulse. But since I eventually want to go to LEDs on the rear, I needed that anyway.
June 30th, 2013, 05:14 AM | #6 |
June 30th, 2013, 07:21 AM | #7 |
Thanks for the help. I got a little impatient, and just started switching wires around. I had the constant power and intermittent(signal) power wires mixed up. Switched those and it works fine.
That video is pretty nice. Those are the exact same design as my signals. I might have to remount mine, they look pretty ugly right now. I just drilled extra holes and tried to cover the recessed area from the old signals as best I could. I didn't have the stock signal base to use for a template to cover the front. I may have to trace it out and do something like that video. I did cut a big piece of aluminum plate to go inside the faring for a little support though. I'll see if I can get a pic up later. |
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal | 1LoneWolf | Items Wanted | 3 | July 8th, 2013 02:50 AM |
Turn Signal Issues | dsmisfits | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 19th, 2012 09:16 PM |
HELP ASAP please! - turn signal issues | SafetyPaws | 2008 - 2012 Ninja 250R Farkles | 31 | June 25th, 2012 07:05 PM |
2009 ninja turn signal issues | schultzy808 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 28th, 2012 08:06 PM |
Turn Signal Indicator Issues | menikmati | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 12th, 2011 08:17 PM |
