Old February 11th, 2014, 08:40 PM   #1
tanghonglai
Motorcycle(s): 2006 Ninja 250
Right front turn signal not working
Hi all,
I hope someone in the forum can help me out. My bike's right front turn signal isn't working anymore, and the turn signal indicator on the dash flashes really fast. The bulb isn't blown, and I don't think the fuse is either or else the left wouldn't still have been working. So what else should I check?
Thanks,
Tang
tanghonglai is offline   Reply With Quote
Old February 11th, 2014, 10:11 PM   #2
n4mwd
n4mwd's Avatar
The connectors are little bullet connectors that pull out really easy. They are right next to the radiator cap. Check those.
My Ninja Blog
Old February 12th, 2014, 06:09 AM   #3
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
what he said,
Connection issue, if the bullb is still good, the reason the turn signal indicator is blinking quickly is due to the lack of a load from the bulb.
Old February 12th, 2014, 06:25 AM   #4
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
That's what it's designed to do when a bulb burns out and the load drops. If you only visually inspected the bulb, try actually replacing it (or just swap sides to see if the problem moves with the bulb). It might be bad but still look good. If the bulb really is good, then check the connections as stated. The circuit appears broken to the flasher - just need to find where it's broken.
Old February 12th, 2014, 07:02 PM   #5
tanghonglai
Thank you all! It was indeed a connection problem.
Old February 15th, 2014, 01:52 AM   #6
RBN
RBN's Avatar
Motorcycle(s): Frankenstein
Incase anyone else comes across this thread looking for answers there's a bit on these that has caused problems on all my bikes that have this holder (albeit I do live an a very wet country so a lot of stuff rots like crazy).
The bullet connectors on mine have always been fine as has the connector that goes to the middle pin on the bulb. But it's where the wire connects to the metal part of the bulb holder that fails. It fails because all they did was to strip the end of the cable and fit it so it gets mashed between the plastic and metal parts of the bulb holder, there is no actual crimped/soldered connection.
To remedy this I have:
For a quick fix as I'm about to go for a ride:
Held the plastic part firmly in my left hand, then CAREFULLY used pliers to twist the metal bulb holder back and fourth a few times.
For a more permanent fix:
Held the plastic part fo the bulb holder in my left hand and then CAREFULLY used pliers to pull the metal part right out, it's just an interference fit but requires a strong pull to remove it. With it removed you will now be able to remove the wire that connects to it. Assuming both are rotten you can either fit a new wire or clean the rot off the old one with a knife blade, clean the bulb holder too. Then apply a little vaseline to the end of the wire and reassemble.
Hope that helps someone
RBN is offline   Reply With Quote
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal 1LoneWolf Items Wanted 3 July 8th, 2013 02:50 AM
Front turn signal issues... snowman7 1986 - 2007 Ninja 250R Tech Talk 6 June 30th, 2013 07:21 AM
Front right signal not working. 2010ninjablue 2008 - 2012 Ninja 250R Tech Talk 3 May 14th, 2012 03:50 PM
2008+ right front turn signal cuong-nutz Items Wanted 7 April 28th, 2011 09:50 AM
