April 3rd, 2012, 03:40 PM | #1 |
Join Date: Nov 2011 Motorcycle(s): 2011 red ninja 250r Posts: 94
Need help on carb tune
I really need help on this. I've read all articles on faq.ninja250.org anout carb tune and watching this forum drom shadows, so I brave myself to tune up my carb. I used to let other guys to do the bike maintenance, but I wish I can do it myself.
Sorry, I havent got time to take pics but this is what i did. I use sportisi jet kit. I got my airbox desnorkeled and its inner mesh removed, and also a full system exhaust installed. My last good setting Set the pilot jet to size 40 (standard is 38), set the main jet to size 100 (standard is 98). I also use sportisi needle. Set up the clip in second from the top of needle, then a plastic washer on top of it, then a clip to lock the washer. There is also a small rubber washer on top of needle that I attached between the needle and the plastic piston. This set up was what I found from the previous bike work done by mechanic. Got the mixture screw set at 2 1/4 turn, and synced. I also set up the throttle cable so It doesn't need to be twisted too much for full throttle. Set up the idle engine speed at 1K. I believe I ve done it right and the bike shows good idle. But when I try it for a test ride, I notice during throttle blip the RPM comes down slower than before. When I close the throttle and the RPM stuck at 2-3K when I pull the clutch, and normalize as I let go the clutch, giving engine load. At first it pulls great at full throtle without sign of too lean or too rich, then I feel the mixture starts enrich on down to mid RPM, as I found it hard to pull from low RPM after full throttle several times. Where is my mistake? Any help is appreciated. |
April 3rd, 2012, 05:06 PM | #2 |
Look for any vacuum leak between carbs and engine; that may be the reason for idle slow return.
If weakness at middle continues, drop the needle some. How did you "set up the throttle cable so It doesn't need to be twisted too much for full throttle"?
April 4th, 2012, 03:51 PM | #3 | |
Regarding for the throttle cable set up, I just try to minimalize free play of the throttle cable edge on the carb. Alternatively, you can try quick throttle mod. Details are here http://www.kawiforums.com/2005-2006-...e-mod-pvc.html |
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
Valve adjustment, carb clean, carb sync? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 29th, 2014 09:42 PM |
Best stock carb tune | ktp1598 | 1986 - 2007 Ninja 250R Tech Talk | 6 | March 11th, 2014 08:45 PM |
area p tune | jaybo | 2013 - 2017 Ninja 300 Tech Talk | 8 | March 27th, 2013 09:53 AM |
tune up | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 7 | May 17th, 2010 11:57 PM |
