January 3rd, 2014, 03:48 AM | #1 |
Join Date: Nov 2013 Motorcycle(s): 2003 Kawasaki Ninja EX250r Posts: 32
fuel line under seat keeps rupturing on my 03 250
So my left-side fuel line keeps getting pinched and breaking right at the tank under the seat. Has anyone found a solution to this? Or am I the only one who has a leg that smells like a gas station?
January 3rd, 2014, 06:47 AM | #2 |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
Is the line an actual fuel line or did someone at some point put another kind of hose on there?
Does the hose feel flexible or is it stiff? What kind of clamp do you have holding the hose to the petcock? It is not a common problem AFIK though. |
January 3rd, 2014, 07:02 AM | #3 |
If you still have any OEM rubber hoses that carry fuel or fuel vapors, they should have been replaced a long time ago, given the age of your bike.
Good grade fuel line is hard to pinch and rupture. You should get some 1/4" fuel line (at any auto parts store) and replace all your fuel lines and make sure they are routed properly and not being pinched anywhere. If it is being pinched, it's improperly installed or your seat is the problem. |
January 3rd, 2014, 09:57 AM | #4 | |
January 3rd, 2014, 10:18 AM | #6 |
Ms. Personality
/\ about 8 hours and the sticky dissolves, not the fiber/plastic/miracle tape
January 3rd, 2014, 10:21 AM | #7 |
It will get you through a track day.
January 3rd, 2014, 10:30 AM | #8 |
thats a good thing to know in case you bust a fuel line in the middle of nowhere
January 3rd, 2014, 05:11 PM | #9 |
The far left or #1 line, oddly (and this worries me now) i dont have one in that #2 spot as in your photo...
what i guess keeps happening is if i sit too far forward on the seat it puts pressure against the line and pinches it between the nipple and the body of the seat and rips it.. i have an extra long line there so i usually just check it from time to time and when i smell gas i stop, pull off the hose, clip an inch off and re-attach it. works for now but id like to find a way to maybe protect it from being ripped at all. maybe carve out that part of the seat body? or some sort of hard protector/bumper/bushing thing that keeps the pressure from the seat body off of it? |
January 3rd, 2014, 05:22 PM | #10 |
as far as i can tell its actual fuel line, and the hoses were all replaced within the last 6 months if i remember correctly. either way if you look at them they are clearly not original hoses. ill go take some pics and post em.
January 3rd, 2014, 05:23 PM | #11 | |
January 3rd, 2014, 05:25 PM | #12 | |
If not, your tank cap has no drain for rain water. That is what the attached picture shows. Check the forward supports of your seat on the frame, you may be able to lift the seat by building up some those points.
January 3rd, 2014, 05:47 PM | #13 |
Okay so here are the pics of the lines. i didnt know thats what that #2 spot was for, ill check but im sure its fine since ive had the bike out in the rain and it didnt run like it had watered down gas in it after. ill double check still anyway. prolly just doesnt have the hose there.
January 3rd, 2014, 06:07 PM | #14 |
If you don't correct the pressure of the seat on the tank, it could develop a leak from the tank over time.
This article explains the whole CA emissions system: http://faq.ninja250.org/wiki/Hose_ro...ine_fuel_tanks
January 3rd, 2014, 06:12 PM | #15 |
Yep that's an excellent point and I've now put a small roll in my toolkit just in case.
"Revenge is so very, very sweet" |
January 4th, 2014, 06:14 AM | #16 | |
January 4th, 2014, 11:21 AM | #17 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Bugger raby butter jumpers
Rubber baby buggy bumpers
Fuel line came loose from somewhere? | Kurgan | 2008 - 2012 Ninja 250R Tech Talk | 9 | November 22nd, 2014 08:46 PM |
[motorcyclistonline] - The Future of Fuel Economy | Drawing the Line | Ninjette Newsbot | Motorcycling News | 0 | February 5th, 2013 04:10 PM |
Fuel in Vacuum line | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 23rd, 2011 03:29 PM |
[motorcyclistonline] - Corn Ethanol as Fuel | Drawing the Line | Ninjette Newsbot | Motorcycling News | 0 | February 17th, 2011 09:50 PM |
Evap line full of fuel | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 10 | June 18th, 2010 07:44 PM |
