Old May 7th, 2009, 10:28 AM   #1
conchwanab
conchwanab's Avatar
Motorcycle(s): 2008 ninja 250
hard to start
Has anyone had a hard time getting the ninjette to start after having the handlebars in the locked possision?I went for a ride today locked the bars when I parked it, and then went to unlock the bars and the bike would cycle but not fire.I relocked the bars then went to the start position and it fired right up.Ca'nt figure out if I have an ignition switch goin or just a fluke.
conchwanab is offline   Reply With Quote
Old May 7th, 2009, 10:30 AM   #2
I think it may be a fluke. Locking the bars doesn't do anything electrically, and if the motor spins at all then the ignition switch is live. Are you using any choke to start the motor?
Old May 7th, 2009, 11:05 AM   #3
conchwanab
conchwanab's Avatar
I just use the choke on cold mornings.Anything over forty degrees and the bike usually warms up just fine.
Old May 7th, 2009, 12:55 PM   #4
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
maybe you have a loose wire that was pinned by the locked steering? and when you relocked it you fixed it... just throwing out an idea. Cause like Alex said, there shouldn't be any effect on starting.
Nemy is offline   Reply With Quote
Old May 7th, 2009, 02:30 PM   #5
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
I have never had an issue with starting after locking it, but it takes a little more cranking than normal to start after a hard ride in the high RPMs (over the twisties etc)
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Hard to start sometimes? SwagenGTI 2008 - 2012 Ninja 250R Tech Talk 3 May 7th, 2013 08:38 PM
Hard to start Sfor6285 2008 - 2012 Ninja 250R Tech Talk 11 August 28th, 2011 09:43 AM
Hard start in Hot Weather Lou 2008 - 2012 Ninja 250R Tech Talk 17 July 13th, 2011 01:33 PM
[roadracingworld.com] - Rossi Ready To Start 'Hard Work' On Friday At Indianapolis Mo Ninjette Newsbot Motorcycling News 0 August 27th, 2009 04:20 PM
Hard to start after sitting in 100 deg heat all day voodoomaster 2008 - 2012 Ninja 250R Tech Talk 6 August 5th, 2009 05:09 PM
