September 24th, 2009, 03:33 PM | #1 |
Youtube & 4um Rebuilder
Join Date: Sep 2009 Motorcycle(s): 2008 ebony Kawasaki Ninja 250r Posts: 41
2008 ninja 250r turn signals rear - front
Ok..... so i was looking on ebay and i am now wondering if anyone knows if the rear turn signals will fit and work where the front ones do...can anyone verify that?
September 24th, 2009, 09:17 PM | #2 |
Join Date: Sep 2009 Motorcycle(s): 09 Kawasaki Ninja 250R Posts: 2
Yes oem are interchangeable. Right front with left rear and left front with right rear.
September 24th, 2009, 09:51 PM | #3 |
now if you look at the part numbers... the rear has a difference of 1 letter...what could the difference be?
September 25th, 2009, 05:25 AM | #4 |
Pedal Power
Join Date: Jun 2009 Motorcycle(s): 2008 Ninja EX250R Posts: 401
I have mine all interchanged and they all work the same and fit the same. Not sure why there would be 1 letter different...maybe to get people to buy new instead of using one from a different corner
Using Pedal Power |
September 25th, 2009, 09:55 AM | #5 |
Join Date: Mar 2009 Motorcycle(s): 2009 Ninja 250R SE Green Posts: 217
the connector colour should be different, and I believe the wire length is aswell. so that you don't have to much or to little wire.
October 16th, 2009, 10:59 PM | #6 |
worked out great..have the rear set on the front...the connection is just perfect i didn't have blinkers to compare them too but there wasn't much loose wire it not...
take a look at what i have done so far at http://www.youtube.com/view_play_lis...ry=jorgecornet
NON PLVS VLTRA - Infinite Greatness http://www.youtube.com/user/jorgecor...62DD10A1F13699 |
October 17th, 2009, 01:35 AM | #7 |
Great video series. I especially liked your Bob Ross impression when you were cleaning the gasket from the drain plug housing. Keep up the good work
October 17th, 2009, 06:33 AM | #8 |
Pedal Power
One thing I did notice between the turn signals is the drain hole in the middle of the housing where the lens meets the housing...... Make sure the hole is pointing down other wise you will get water in the housingPosted via Mobile Device
October 18th, 2009, 07:14 PM | #9 |
Join Date: Feb 2009 Motorcycle(s): 2009 Ninja 250R Posts: 81
yea the fronts are the exact same as the rear
the difference in part numbers is just for right and left side
Woodcraft~Area P~Zero Gravity~Dynojet~DDM Custom Paint by- ME |
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
Rear turn signals don't blink, front turn signals don't turn on | andyuc88 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 23rd, 2012 02:47 PM |
Front/Rear turn signals | C L | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 8th, 2011 08:23 AM |
I need front turn signals + parts for 2008 250r | jorgecornet | Items Wanted | 6 | September 24th, 2009 01:16 PM |
