Old October 28th, 2019, 03:27 PM   #1
dodgerdad
dodgerdad's Avatar
Question Charging system problem?
I installed my new aftermarket speedo cluster and it works great however shortly after starting the engine the screen goes completely blank (but still backlit). If I turn off the ignition and switch it back on, the cluster comes back to life. Yesterday I decided to check it out.
Wiring is all good with solid solder/shrink-wrap connections. I tested the voltage to the unit and it was only getting 11.56v w/engine off and 10.94v w/engine on. I disconnected the headlight (dual h4 35w headlights) and the power went to 13.28v at idle. Could it be the dual headlight is drawing too much voltage from the charging system? (I have no other accessory/gizmos hooked up.) I relayed the problem to the manufacturer and they agree it's a symptom of insufficient voltage to the unit.
Also, my battery measured 12.74v at idle WITH the headlights and 13.70v withOUT them. I ran the bike at idle for a few minutes and when I turned off the ignition my battery measured 13.30v. 5 minutes later it was at 12.84v and 24 hours later it's at 12.65v.
All these battery numbers are telling me the battery is good but either the stator is not keeping up or the headlights are truly sucking up too much juice. I don't suspect a rectifier problem.
Does this make sense? If so, what's the best way to measure the voltage coming out of the stator?
Old October 28th, 2019, 04:55 PM   #2
SibSerge
How old is the battery?
Did you try to boost it from a car and see if you observe the same behaviour? Dis you try to charge it with a charger?
I find 4-5 year old batteries start doing funky stuff so I just replace them when they are that old. 35W light would draw 3amps which is quite a lot fpr a small 6ah battery. You will notice it
Old October 28th, 2019, 05:58 PM   #3
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
You may want to look into a MOSFET R/R upgrade while you're at it. Due to the design differences, they're more efficient, which translates into higher output at idle, steadier output through the whole range, and less waste heat produced (which in turn means more life out of the R/R). The stocker can fail open or closed - one way just doesn't generate enough power, the other way puts out too much and fries your battery.
Most of the Shindengen MOSFET R/Rs have (fairly expensive) Furukawa connectors. You can replace the stock harness connector, buy a PnP adapter, or rig it up with generic female terminals (losing its waterproof seal in the process). Or the FH016 R/R off the '07-'08 ZX6R has wire pigtails instead, so can install any plug you want (e.g. the OEM Ninjette connector).
Old October 28th, 2019, 06:28 PM   #4
dodgerdad
dodgerdad's Avatar
My battery had worn down from starting it and shutting off repeatedly so I put it on the charger and charged it 100% before doing the tests above.
The battery is 13 months old.
Old October 28th, 2019, 07:22 PM   #5
SibSerge
That's not old for a battery. the cluster might also be sensitive to fluctuations of the system voltage. Try measuring the voltage when you load is all connected but switch your voltmeter into AC mode. Check how big those fluctuations are. If you have an access to an oscilloscope it's even better. The higher the current draw the higher the fluctuations are. The alternator can keep up with the draw , the rectifier can but the filter might be small for this load.
If you see bulbs flickering then it's an indication the voltage fluctuates. The bulbs in general do not care , you just see it as a flicker, with higher RPMs and thus the frequency of the flicker your eye will not even register it. But if the cluster contains electronics it could be a big deal.
This can be addressed by adding a polarity sensitive capacitor in proximity to the cluster. It will be able to maintain the voltage level needed for the cluster unit.
Old October 28th, 2019, 08:07 PM   #6
What's the battery voltage with everything on as usual, and you rev the engine to something like 3,000-4,000 rpm?
Old October 31st, 2019, 03:25 PM   #7
dodgerdad
dodgerdad's Avatar
I have the battery at full charge and installed an voltage capacitor/filter and it seems to have cleared up the problem (with no headlights connected). I cycled it on and off many times and no failure. Voltage going to cluster is at 13.13v.
Thanks for your input!
Old October 31st, 2019, 03:26 PM   #8
dodgerdad
dodgerdad's Avatar
It's around 13.84v at 4k (no headlights).
Old October 31st, 2019, 03:30 PM   #9
dodgerdad
dodgerdad's Avatar
Final numbers & question
So with my battery charged up it measures:
12.54v with dual headlights on (and seems to run a bit rough)
13.90v with no headlights
13.89 with stock (single) headlight
My questions is, does my charging system appear to be healthy? If so, I'll likely replace my dual headlight set-up with a single.
Old October 31st, 2019, 04:11 PM   #10
Yeah, system doesn’t have much overhead in stock trim. Even with more efficient RR, stator’s output is still limited.
To reduce load, go to Philips X-treme Ultinon bulb. It’s only one designed to replace filament bulb in reflector assembly without causing glare into oncoming traffic’s eyes.
Old October 31st, 2019, 06:32 PM   #11
dodgerdad
dodgerdad's Avatar
Hadn't heard of them, looked them up and they are steep! I think I'm gonna take the bike out for a test ride (headlights disconnected) then if all goes well I'll just shop for a single headlight assembly.
Old October 31st, 2019, 08:46 PM   #12
SibSerge
I am glad it worked!
Charging system inspection after battery died TylerLew89 1986 - 2007 Ninja 250R Tech Talk 4 July 5th, 2016 06:34 PM
Ninja Charging System fits my GS1000!! kxpower? The Ex-Ninjetters Lair 3 March 16th, 2016 06:42 PM
Intermittent charging system failure ugh!!! kxpower? 1986 - 2007 Ninja 250R Tech Talk 10 October 8th, 2014 06:18 AM
Charging Problem Nstoltz 1986 - 2007 Ninja 250R Tech Talk 7 May 19th, 2012 01:06 PM
alternator/battery/charging related problem mrkyo 2008 - 2012 Ninja 250R Tech Talk 6 May 2nd, 2010 05:41 AM
