Old April 30th, 2018, 07:39 AM   #1
The Red Scourge
The Red Scourge's Avatar
Motorcycle(s): '76 Yamaha RD400, '71 Kawasaki G3SS, '88 Honda CBR400RR, '90 Yamaha FZR400/600 hybrid
1st Gear Bogging and Possible Wheel Bearing Issues
Hey folks. Haven’t posted in quite a while. After sitting for about a year I cleaned the carbs on my ‘08 250. It runs well now, except when starting in 1st gear the engine bogs pretty hard. If I let out the clutch super slow, it will get going. Is this possibly an issue with the mixture setting? I set it to what is listed in the FSM. I think it was 2-1/2 turns out for the left and 1-3/4 turns out for the right. I’ve never done it like that before, but it is the service manual. Any suggestions?
Also, while lubing the chain with the bike on a rear stand I noticed some play in the rear sprocket. If I grab it, it’ll rotate about 1/2 an inch either way without the wheel moving. If I grab the wheel at the top and bottom, there’s no play side to side. Is this possible wheel bearings needing replacement or maybe the axle isn’t torqued correctly? Thanks!
"When in doubt, gas it!"
The Red Scourge is offline   Reply With Quote
Old April 30th, 2018, 08:40 AM   #2
Does 1st take off better with choke ON? or OFF?
Rear hub is missing the cush-drive rubbers.
Old April 30th, 2018, 08:42 AM   #3
The Red Scourge
I’ll have to check the choke vs. off choke when I get home. Thanks!
Old April 30th, 2018, 11:12 AM   #4
How old is the gas? Is the air filter clean? Have the carbs been synced lately?
If that's all OK, you may need to try again on the carb cleaning. Did you remove all the jets and clean the passages? The Pilot Jets have small cross-drilled holes that easily plug. At times, replacing the jets with new is the best/only solution - and not a bad idea in general.
The other issue is excessive play in the cush drive. Here's the solution - https://faq.ninja250.org/wiki/How_to...the_cush_drive
does this look like a new front wheel bearing and seal BIGFL General Motorcycling Discussion 6 July 15th, 2015 01:33 AM
Wheel bearing quality broken neck 2008 - 2012 Ninja 250R Tech Talk 15 January 18th, 2014 07:34 PM
Wheel Bearing?! RiderOnTheStorm 2008 - 2012 Ninja 250R Tech Talk 3 May 20th, 2012 07:12 PM
starting/bogging issues ninjaflav 2008 - 2012 Ninja 250R Tech Talk 3 August 5th, 2011 04:12 PM
09 Ninjette wheel bearing removal Swaggeringpagan 2008 - 2012 Ninja 250R Tech Talk 6 September 3rd, 2010 04:29 PM
