Old May 30th, 2016, 07:32 PM   #1
wendyjboss
wendyjboss
wendyjboss's Avatar
Motorcycle(s): 2015 Honda CBR 500RF (On its way), 2004 Kawasaki Ninja 250 (sold)
Occasional 1st gear issue
Does anyone else experience difficulty getting into 1st gear on occasion?
I can shift well enough, but sometimes it doesn't want to shift down past 2nd. It's rare enough, but regular enough that I would like to understand if it is a peculiarity of the pre-gens, or something that needs to be fixed.
When it does this, refuses to downshift to 1st, it's like the gear shift feels stuck, it will not go to neutral. It will not go to 1st. I'm not sure what get's it going again, maybe clutching off and then on again. I just know sometimes it says "no"...
wendyjboss is offline   Reply With Quote
Old May 30th, 2016, 07:34 PM   #2
Are you moving at the time, or is the bike sitting stopped while you are trying to get it into first?
Old May 30th, 2016, 07:45 PM   #3
wendyjboss
wendyjboss
wendyjboss's Avatar
The bike is sitting stopped while I'm trying to get it into first.
Last futzed with by wendyjboss; May 30th, 2016 at 07:46 PM. Reason: mis-spelling
Old May 30th, 2016, 07:48 PM   #4
Once the bike is stopped, there are times where the gearbox is not lined up properly to drop into 1st gear easily. Do not stomp on the lever to try and force it in. It might work, but it just as likely may bend parts along the way. Instead, just rock the bike forward or back a few inches, and it will likely drop into first very easily.
Old May 30th, 2016, 07:55 PM   #5
wendyjboss
wendyjboss
wendyjboss's Avatar
Awesome. Thank you for that info. I am way more experienced this year on the bike, and now that little gear catching incident today made me start trying to force it. Then I stopped and said to myself, "now that is not going to help at all". I will definitely remember that trick.
Old May 30th, 2016, 08:01 PM   #6
Originally Posted by wendyjboss View Post
.......When it does this, refuses to downshift to 1st, it's like the gear shift feels stuck, it will not go to neutral. It will not go to 1st.....
It could also be a geometry problem with the external linkage.
This comes in two forms or a combination of both:
- The connecting rod is not as perpendicular as possible to the levers of the shifting shaft and shifting pedal.
- The back of the shifting pedal is hitting some solid point of the frame or footpeg, which limits its full stroke downwards.
Some lubrication of all moving joints always helps smoothing things out.
Old May 30th, 2016, 09:01 PM   #7
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
What may also help is ease out the clutch so that it starts to engage the friction zone. Once you feel the bike move slightly, squeeze the clutch again and you should be able to shift to N or 1st.
Riding it like I financed it.
Old May 31st, 2016, 01:35 AM   #8
yenome
Motorcycle(s): 09' Ninja 250R
I like you have the same issue and its always happens when i stop at a light and people are behind me. I found releasing the clutch to the friction zone causes it to notice its in gear. then i can down shift. on a side note hello to another masstonian im from Lynn north of boston
yenome is offline   Reply With Quote
Old May 31st, 2016, 08:34 PM   #9
wendyjboss
wendyjboss
wendyjboss's Avatar
I will most definitely check the linkage, and I am due to clean and lubricate the bike. Thanks for the suggestion!
Old May 31st, 2016, 08:42 PM   #10
wendyjboss
wendyjboss
wendyjboss's Avatar
I'll have to give that a try. Alex also gave me a tip that if I am at a stop, rolling the bike forward or back a bit will get the gear into position for the shift.
Wow! Lynn. Charlotte is a long way from Lynn. I am originally from PA. but have been here long enough to be official Massachusan.
Old June 1st, 2016, 03:20 AM   #11
yenome
yea i been in north carolina long enough to be adopted by the south lol.
Trackday Gear - 1st time Bigballsofpaint Motorcycle Gear 18 August 25th, 2013 05:40 AM
Stalling in 1st Gear at stops - HELP!!!!! kingskater 2008 - 2012 Ninja 250R Tech Talk 27 September 5th, 2012 08:39 AM
Why do people consider the Ninjette's 1st Gear as being useless? ajcadoo General Motorcycling Discussion 39 April 21st, 2012 11:48 PM
Finding 1st gear? Focus Mike 2008 - 2012 Ninja 250R Tech Talk 38 August 7th, 2009 01:11 PM
1st gear locking mista350z 2008 - 2012 Ninja 250R Tech Talk 25 August 5th, 2009 08:24 AM
