Old June 7th, 2020, 01:12 AM   #1
claires-dad
Motorcycle(s): 2001 250r
Hi, new to motorcycles, please forgive my ignorance
Hi, I'm Steve from the Boston MA area. I always wanted to learn how to ride, so I'm scheduled for a class in a couple of weeks and I've picked up a 2001 250r to play with. It hadn't been running for a few years when I bought it, so I'm trying to fix it enough to be safe and reliable.
I started taking parts off to try to get things going. The carbs are on their way back from ducatiman. I've installed a new battery and replaced the broken handlebars and throttle cables. I'm waiting for new brake lines, choke cable, clutch cable, and horn to arrive. I put in new spark plugs, and will replace the oil/oil filter/coolant when I can pick up new fluids. I'll put in new brake fluid when I replace the brake hoses, and probably brake pads too at the same time.
I've got the fairings off now, and I'll see if I can repair cracks and replace missing chunks well enough to mount the turn signals. I probably won't get too carried away with how they look, as long as they're solid enough while I'm learning how to ride.
One question for now - with the fairings removed, everything looks pretty dirty. The bike has a little over 14K miles, so I don't expect it to look like new, but I was wondering if there's a good way to clean off the parts that are normally out of sight. I have some Maxima BioWash around, but I didn't want to spray the bike with a hose if that's a bad idea (especially the wiring connectors). I'd appreciate any suggestions on how to clean it up, or with anything else I should check/replace. Thanks!
claires-dad is offline   Reply With Quote
Old June 7th, 2020, 01:28 AM   #2
akima
Nooblet
akima's Avatar
MOTM - Oct '13
claires-dad! Glad you found us...
Old June 7th, 2020, 05:11 PM   #3
Greetings & Salutations Steve!!!
I've found S100 Cycle Cleaner to work best out of variety of products I've tried. Follow instructions on bottle (spray on, hose off). Amazing how grime just flows right off.
Wiring connectors are exposed with no weather-proofing seals, so water can be concern. Most of them have rubber hood over connector. But don't worry about it if you dry out connectors afterwards with hairdryer. Won't be 1st time that bike's been wet.
Someone posted recently on using old cut-up license-plates to fill in hole in fairing for turn-signals. I've used CF and Bondo to fill that hole. Then you can use any aftermarket stalk or flush-mount signals you want.
Last futzed with by DannoXYZ; June 7th, 2020 at 10:20 PM.
Old June 8th, 2020, 07:09 PM   #4
claires-dad
Thanks - I 3D-printed a new turn signal base, and it looks like it should fit OK if I can put together something for it to bolt onto. I'll see if I can find an old license plate in my parts pile.
Old June 8th, 2020, 07:45 PM   #5
Nifty. I'm a fan of 3-D extrusion printing.
Old June 9th, 2020, 06:14 AM   #6
VaFish
VaFish's Avatar
MOTM - Jan '16
Harbor Freight has a plastic welding kit for $17 that works pretty well. It's basically a soldering iron with a flat tip. You will need to get more filler rods.
https://www.harborfreight.com/80-wat...kit-60662.html
Old June 9th, 2020, 09:04 AM   #7
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Boston Rocks!
Old June 9th, 2020, 09:30 AM   #8
Kuya EZ
Kuya EZ's Avatar
Motorcycle(s): 2012 Kawasaki Ninja 250 / 2004 Yamaha YZF-R6 / 2006 Yamaha R6 (track bike) / 2014 Ducati 1199s
Welcome and good luck with your build
Kuya EZ is offline   Reply With Quote
Old June 9th, 2020, 10:53 AM   #9
Ceeloo Yello
Motorcycle(s): 250
Welcome
Old June 9th, 2020, 06:26 PM   #10
claires-dad
Thanks for the welcome messages. VaFish, I'll have to pick up one of those Harbor Freight plastic welders - looks like it should work well.
Old June 15th, 2020, 12:33 AM   #11
claires-dad
I picked up the plastic welder at HF. Because it's a "welder" they don't accept the 20%-off coupon, but the guy let me slide. In the meantime, I cleaned and coated the fuel tank with the KBS kit, so I'll have to wait a week before I can use it. My carbs came back from ducatiman looking great! The choke and clutch cables are installed, and new brake lines and pads should be coming this week.
I also have a piece of black vinyl cut to size so I can recover the seat, which is a bit worn and chewed up.
Should be a fun week of activity. My "learn to ride" class is coming up this weekend, which I've been looking forward to for a while.
Old June 16th, 2020, 05:42 AM   #12
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome.
When reinstalling plastics, add a little grease to the rubber grommets. It will make it easier to remove next time and help prevent the tabs from breaking.
Old June 16th, 2020, 09:17 AM   #13
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old June 16th, 2020, 02:11 PM   #14
claires-dad
Thanks, and thanks for the tips.
I pushed the bike out of the garage today and washed it off. It looks better - I didn't go nuts on it, but got as much grime and dirt as I could get without searching for a toothbrush. It's probably clean enough to reinstall the carbs and start moving forward.
Old June 19th, 2020, 01:10 AM   #15
claires-dad
Still waiting for the brake lines to arrive and the tank sealer to finish drying. In the meantime, I changed the oil and filter (although "change" is not accurate, as there was no oil other than whatever was in the filter) and drained/flushed/refilled the coolant.
One issue that came up was with the clutch. It doesn't want to disengage. I tried bumping the starter with the bike in first gear while squeezing the clutch lever and the bike jumped forward. The new cable seems OK; I tried putting the old cable back on and got the same result. My guess is that the clutch plates are stuck (or rusted) together from sitting without oil and not being used for a few years. A YouTube video suggested adding oil and then putting a clamp on the clutch lever to squeeze it for a couple of days, and then try to start the bike. Aside from that, I can drain the new oil and remove the clutch plates to get them apart (or replace them as long as I'm in there), but is there anything else I should try? Thanks.
Old June 23rd, 2020, 08:32 PM   #16
claires-dad
The "clamp on the clutch lever" didn't do too much. I was hoping that maybe once I got the bike running and let it warm up, the warm oil would free the clutch plates. That's what happened. It's been over a week since coating the gas tank so I reinstalled it and added fresh gas with some Seafoam. After a little cranking, the bike started up for the first time in years (thanks, Ducatiman!) and seemed to run OK. I didn't try riding it, as I want to replace the brake lines/pads/fluid before doing that.
I've got a slight coolant leak coming from the drain bolt in the block. I didn't want to overtighten it because I'm nervous about stripping the threads. If I found the right drain bolt in the parts diagrams there's supposed to be a washer between the bolt head and the block - I'll try taking the bolt out and adding a washer without losing too much coolant in the process.
Getting closer!
Old June 23rd, 2020, 10:23 PM   #17
That's not regular washer, but crush-washer. It deforms to seal both sides. Someone may have installed regular steel washer instead.
As for clutch cable, have you adjusted both ends to tighten cable? So there's very little free-play when you squeeze-lever? Any movement starts pulling cable right away?
Old June 23rd, 2020, 11:32 PM   #18
claires-dad
Thanks - it looked like a plain washer in the parts diagram but I might have misidentified the bolt. I ordered an assortment of crush washers so I won't have to keep ordering them one at a time as I come across them.
The clutch cable seems to be adjusted OK - only 2-3mm free play before the arm starts moving.
Old June 24th, 2020, 03:08 AM   #19
One possibility is clutch's 1st disk is not indexed properly. There's a dot on disc that needs to be lined up in proper rotation.
Old November 9th, 2020, 06:35 PM   #20
Snake
Snake's Avatar
I’m a little late but ....hello and welcome !
Parts availability for older bikes, also forgive me for mentioning honda Aldent General Motorcycling Discussion 21 November 28th, 2017 08:34 PM
Terrifying act of ignorance ZeroGravity360 General Motorcycling Discussion 23 June 9th, 2016 12:58 PM
[superbikeplanet.com] - Eric Bostrom: Ignorance is Bliss & God Protects the Innocent Ninjette Newsbot Motorcycling News 0 May 15th, 2015 03:20 PM
[topix.net] - Empire Motorcycles announces the launch of Suzuki Motorcycles in Oman Ninjette Newsbot Motorcycling News 0 November 23rd, 2011 06:30 AM
[superbikeplanet.com] - DMG Superbike: I Know This Sounds Cocky, But Forgive Me ... Ninjette Newsbot Motorcycling News 0 December 2nd, 2009 03:30 PM
