Old June 20th, 2023, 03:46 PM   #1
MotoRob
Motorcycle(s): '94 Ninja zx6e, 2013 WR450f, 2007 Ninja 250r
Starter Gear Case Rub
Hi Everyone,
I recently picked up a 2007 250 for cheap to fix for my wife to learn to ride.
The po had an issue with the starter, replaced the starter, then gave up and sold it.
I got it and pulled the rotor/flywheel and found the starter gear had sheared from the hub where it is welded together. Also the sprags were damaged, so I got a part out rotor/starter clutch/starter gear.
When I bolted the rotor assembly to the crank the starter gear rubs a protrusion on the case behind the gear. I also noticed some minor in out play in the crank, no up down or left right play.
So now I'm considering clearanceing the protrusion with a file, but before I go any further I thought I would ask if anyone else had encountered this. Is the axial play in the crank normal or a serious problem? I looked in the manual and I think 0.4mm of thrust play is the upper limit but I haven't measured it on the engine yet.
Thanks!
MotoRob is offline   Reply With Quote
Old June 20th, 2023, 05:59 PM   #2
Greetings & Salutations Robert!!!
Are you really having axial play at crank?
Please post photo of this protrusion that starter-gear is rubbing on. Seems very odd...
Old June 20th, 2023, 07:54 PM   #3
The spec for axial play is 16 thousandths of an inch, which you should be able to feel. Measuring what you actually have is a good idea, of course.
Old June 21st, 2023, 12:39 PM   #4
MotoRob
There is the part of the case rubbing the starter gear, here in a bit I will track down a dial gauge and measure the play but it feels pretty minimal, at least less than I remember.
Thanks so much for the replies, this seems like a great community!
Starter seemingly misaligned with gear SS310 1986 - 2007 Ninja 250R Tech Talk 3 March 22nd, 2023 05:46 AM
2010 Ninja 250 starter gear holder broken and flywheel gear broken BikeRider General Motorcycling Discussion 11 March 5th, 2019 06:50 PM
DIY Starter Gear Repair DannoXYZ 2008 - 2012 Ninja 250R Tech Talk 8 August 1st, 2017 02:56 PM
starter idle gear akcalhoun 2008 - 2012 Ninja 250R Tech Talk 6 June 30th, 2013 07:42 AM
Hello starter oneway gear question jibberish71 1986 - 2007 Ninja 250R Tech Talk 8 May 7th, 2011 02:32 PM
