Old May 9th, 2021, 10:55 AM   #1
PJW
Motorcycle(s): 2005 Kawasaki 250 ZZR
Banging noise - Clutch?
2005 ZZR 250, it starts, idles, runs well but there is a terrible banging noise especially at idle. It gets quieter when the clutch is pulled in and when the engine revs, but at idle with the clutch out it is unpleasant
Video link:https://www.youtube.com/watch?v=JmmMDovN1GA
I think I need to replace the clutch but I am open to any ideas you might have.
Edit: OK, so it seems the clutch basket it the likely culprit and I have options like upgrading to a newer gen clutch basket, or finding a good used one. Opinions?
Last futzed with by PJW; May 9th, 2021 at 11:56 AM. Reason: found more info
PJW is offline   Reply With Quote
Old May 10th, 2021, 05:59 AM   #2
SibSerge
If the noise goes away when the clutch is under load then its likely the basket. Just upgrade to the new gen. I doubt you can find a “good used one” as they stopped using them in the new gen and oldest new gen is 13 years old. The problem in these baskets is the rubber bushings and finding a good rubber thats was sitting in an oil bath flr 13 years is nearly impossible. I have 6000km on my converted clutch and it runs great
Old May 11th, 2021, 03:12 PM   #3
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Change the clutch to a new gen type. You will need the whole clutch, oil pump drive gear, inner & outer basket plus all plates, springs & bolts/washers, plus the central push rod.
You can use a 300 slipper clutch if you change the same parts & use the 300 clutch cover.
Have fun.
Old May 19th, 2021, 07:02 PM   #4
PJW
I have the clutch out of 2010 and it looks great except the big gear on the back of the old one isn't there on the new one? Is that the oil pump drive? And if so did the guy who sold it to me just forget to give it to me or do I need to transplant it from the old one?
Have fun.
Old May 19th, 2021, 07:36 PM   #5
SibSerge
Its a separate item, it slides over into place and then the basket will look just like the old one. They often sell them separately on ebay. Why would you package them if you can fetch few more $ for it
Old May 19th, 2021, 07:41 PM   #6
PJW
Thanks, that's what I was hoping. The guy I bought it from has it, so I'll get ahold of him and ask for it.
Old May 20th, 2021, 09:23 AM   #7
Mohawk
Mohawk's Avatar
That gear ring is a very snug fit on the splines, it has to be aligned perfectly to slip on.
Old May 20th, 2021, 09:40 AM   #8
PJW
So no hammer? But I need the one from the new clutch, right?
And do you mind if I ask another question? The rod that needs a 2mm washer assumes I am using the old rod, correct? If I use the new one I shouldn't need the spacer?
Edit: Great Success! Using the rod from the new clutch I didn't need a spacer. Once I got the order of the parts figured out from diagrams it slid in and voila. It started up, no awful thumping noise, and then I rode it around the block. It feels much nicer.
Last futzed with by PJW; May 20th, 2021 at 05:36 PM.
Noise with Clutch Out Kennylxix 1986 - 2007 Ninja 250R Tech Talk 27 November 9th, 2018 07:51 PM
Clacking Noise While Riding | Clutch Now Disengaged tunatrout General Motorcycling Discussion 7 September 27th, 2018 02:52 PM
Growling noise while going slow with clutch in Sarge1992 1986 - 2007 Ninja 250R Tech Talk 17 December 28th, 2015 07:52 PM
[motorcycle.com] - Halbert, Baker In Bar-Banging Dirt Track Battle Video Ninjette Newsbot Motorcycling News 0 February 28th, 2014 10:20 PM
Weird noise transmission/clutch? help Choter 2008 - 2012 Ninja 250R Tech Talk 2 January 11th, 2011 07:52 PM
