Old December 8th, 2013, 02:17 AM   #1
algs26
Motorcycle(s): ex300, gave up looking for a 250
Exclamation brake caliper interference recall
I found out on another forum that there's another recall for brake caliper interference on the rear clamp that's welded to the swing arm. ABS bikes also have an issue with the ABS sensor bracket. My VIN tested positive.
http://www.kawasaki.com/site/kawasak...MS/MC13-05.pdf
algs26 is offline   Reply With Quote
Old December 8th, 2013, 02:42 AM   #2
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
@algs26 you finally got a bike? Time to update your user profile
Old December 8th, 2013, 12:52 PM   #3
algs26
Happy now?
Nobody else noticed so I never bothered.
Old December 8th, 2013, 01:17 PM   #4
tfkrocks
tfkrocks's Avatar
Originally Posted by algs26 View Post
Happy now?
You're supposed to announce it to everyone and spam pictures of it everywhere haha
Old December 8th, 2013, 02:00 PM   #5
they are like children. you're supposed to mail out annoying photos and call people in high pitched squeals to inform them about your precious delight
Old December 8th, 2013, 04:52 PM   #6
algs26
I took a look and the caliper is pretty close to the brake line bracket/guide.
Old December 8th, 2013, 06:21 PM   #7
Loadthis
Loadthis's Avatar
Motorcycle(s): '13 Ninja 300
Looking at my bike, there is no contact at all between brake lines, guides, or components. Everything is free and clear.
Am I required to take my bike in in order to retain my warranty?
Reason i ask is because when I had the ECU recall work done, I was without a bike for nearly 3 weeks. Also, (and the worst part) the local dealer elected to perform an oil change without my permission. They put Dino oil in after I'd been running synthetic for nearly 1500 miles. I had also just done my own oil change. They tried to charge me $110 for the oil change at which point I told them to F off. The bike came back filthy to boot.
Anyway, I'm reluctant to take my bike to the local dealer. Nearest alternate is about a two hour drive.
Thanks in advance.
Loadthis is offline   Reply With Quote
Old December 8th, 2013, 09:21 PM   #8
tfkrocks
tfkrocks's Avatar
@Loadthis Go call the dealership that's further away. It might be worth your while if you don't have to leave your bike with them. My dealership didn't have to keep my bike while ordering the parts. They just asked me if I wanted them to order it and then I just had to bring in my bike when the parts came in. Since it's pertaining to the brakes, it's probably to err on the side of caution too.
Old December 9th, 2013, 07:13 AM   #9
Loadthis
Loadthis's Avatar
Yeah I probably should do that. I'll be in Lubbock on Thursday so I may be just to trailer it down for the inspection. The weather has been too crappy to ride lately otherwise I'd take a road trip. Im not set up for sub-freezing rides.
Reading the recall notice it looks like just a visual inspection and adjustment as needed. I wonder if the local Honda dealer can do Kawasaki recall work??
Old December 9th, 2013, 11:05 AM   #10
tfkrocks
tfkrocks's Avatar
If it's just inspection and adjustment, then you should be fine taking it to the local dealership. Based on what other people have noticed with this recall, it's probably just manually bending the brake line bracket away from the caliper lol.
Old December 9th, 2013, 03:59 PM   #11
Lychee
sail away
Lychee's Avatar
Sounds Serious. Better have that "VIN" checked out.
Old December 9th, 2013, 04:25 PM   #12
allanoue
allanoue's Avatar
MOTM - Sep '14
Just got a letter from Kawi asking me to have the dealer inspect and if necessary adjust my caliper "at no charge". The danger is the brake pad may were faster on he outside then the inside.
Old December 17th, 2013, 10:47 AM   #13
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
Been off board lately...any thread opened on this ? Got letter from Kawi...guys on 300 board are all aware of it. I looked at my hose guides and nothing touches caliper ?
Old December 17th, 2013, 01:34 PM   #14
allanoue
allanoue's Avatar
MOTM - Sep '14
http://www.ninjette.org/forums/showthread.php?t=161600
Old December 17th, 2013, 01:46 PM   #15
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Old December 21st, 2013, 08:18 AM   #16
allanoue
allanoue's Avatar
MOTM - Sep '14
I took it in this morning. Done and out in 15 minutes.
Old December 21st, 2013, 11:01 AM   #17
JohnnyBravo
I got the letter... May take it in today
Old December 31st, 2013, 03:40 PM   #18
Got mine done today, took just a minute or two. I think it takes longer for the ABS bikes as they have to replace a part, but for the non ABS all they really do is use a hand tool to bend the hose guide further away from the brake caliper, and then re-measure the gap to make sure there is enough clearance. Easy-peasy.
Old January 1st, 2014, 10:25 AM   #19
if you bend the mount yourself can you charge kawi a service fee?
Old January 1st, 2014, 10:36 AM   #20
Worth a shot!
Old January 1st, 2014, 03:25 PM   #21
ally99
Ninja chick
ally99's Avatar
MOTM - Dec '13, Feb '15
I got the letter too. Guess I'd better take my bike in. I hope it's quick for me too. I never got a letter about the ECU recall. Does that mean the dealer most likely took care of it since I just bought my bike? Seems like they'd have to fix any known recalls before selling a bike, but I know assuming such isn't a wise idea. So I come to the experts and ask you guys!
Postwhores are COOL! ~Allyson
Old January 1st, 2014, 03:30 PM   #22
allanoue
allanoue's Avatar
MOTM - Sep '14
If it were me, after checking like you did, I would not give it one more thought.
Has it stalled again?
Old January 1st, 2014, 04:15 PM   #23
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
good to know, I haven't taken it in yet since last time I was without a bike for 1.5 weeks of warm sunshine.
Old January 1st, 2014, 04:23 PM   #24
allanoue
allanoue's Avatar
MOTM - Sep '14
Where did you take it? Don's in Hellam Pa (not that far for you) took about 30 minutes for my ECU
Old January 1st, 2014, 04:26 PM   #25
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I took it to Pete's cycle in baltimore where I got it, and the ECU was fine the problem was with the ABS unit that they had, somehow they had gotten a faulty replacement from kawasaki. Unfortunately they didn't lend/rent me a bike from their used section for the week (all of those bikes are still there waiting to be sold (they have a 2008 cbr600rr with 5xxx miles going for almost $500 more than a 2013 cbr600rr O_o)
Old January 1st, 2014, 06:17 PM   #26
ally99
Ninja chick
ally99's Avatar
Nope, it hasn't, but I haven't railed it like I want to. After this oil change, we're gonna have some fun.
Old January 1st, 2014, 06:34 PM   #27
allanoue
allanoue's Avatar
MOTM - Sep '14
I think the stalling happened more to noobs so that will just make it less likely to stall
Old January 1st, 2014, 06:40 PM   #28
ally99
Ninja chick
ally99's Avatar
It's like an Italian tune-up with every ride.
Old January 2nd, 2014, 04:30 AM   #29
treecat
Motorcycle(s): r6
has someone got a photo of the replacement abs bracket?
treecat is offline   Reply With Quote
Old January 4th, 2014, 10:06 PM   #30
algs26
Took a pic while I was at the dealer. Unfortunately, I don't know what to look for since I don't have abs. I don't even know if this bike has had the recall work done.
Old January 5th, 2014, 04:34 AM   #31
treecat
Motorcycle(s): r6
thanks
Old January 6th, 2014, 01:00 AM   #32
Midnight_tinkerer
Motorcycle(s): GPX250, ZZR250, CT90
The part that gets replaced is the little bracket that holds the ABS wire. It sits between the two main bolts that hold the caliper to the forkleg. The original one was too close to the caliper, and as the pads wore down a bit, the caliper would slide outwards on its pins and hit the bracket, which would then cause more pressure to be applied to the outer pad, generally interfering with normal brake operation.
Midnight_tinkerer is offline   Reply With Quote
Old January 6th, 2014, 07:00 AM   #33
For the non-abs bike, this was for the rear caliper. Was the abs recall one for the front caliper as well?
Old January 6th, 2014, 09:53 AM   #34
tfkrocks
tfkrocks's Avatar
Yep. Required a bracket replacement.
Old January 6th, 2014, 10:39 AM   #35
Makes sense.
Old January 6th, 2014, 12:06 PM   #36
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
Unless you have abs don't bother taking it in. It's easy to bend the bracket out. You won't void your warranty.
Xtina is offline   Reply With Quote
Old January 6th, 2014, 05:25 PM   #37
JBinSD
Motorcycle(s): '13 Ninja 300, '99 SV650 tracked
Funny thing about this is that I posted months ago about my rear brake failure, couldn't figure out why it wasn't working (at all), but I never used my rear brake anyway. I was concerned about passing tech for race weekends, but they didn't seem to catch it either.
Finally got pissed enough and took it to stealer, who grinded off the brakeline guides. I think I paid $40 for them to diagnose and remedy it, but I guess it shoulda been free. the brakeline guides on my bike were already up against the rear caliper, and a lowside didn't help matters. Always better to just get rid of unwanted stuff, anyway. . . .
JBinSD is offline   Reply With Quote
Old January 6th, 2014, 05:34 PM   #38
I took a look at that thread, and I'm wondering if it really is the same problem. With the caliper not being able to move freely, it can cause uneven wear on the outside brake pad. Moving that bracket a few mm outwards keeps the caliper from touching it as it moves around, allowing the brake pad wear to be more even on both sides of the disk.
I don't see how that has anything to do with the brake system itself losing pressure and causing a soft pedal. What did ultimately fix the problem for you, was it rerouting the brake lines to make sure they weren't kinked and the curved parts were gentle?
Old January 6th, 2014, 08:59 PM   #39
JBinSD
My problem was that in place, the calipers was pressed against the brake - hose guide, which did not allow expansion/contraction of the whole caliper body. I replaced the brake lines with shorter S'S and grinder off the hose guides so the calipers could expand and contract freely, and haven't had a problem since (although I still don't use my back brake).
Old January 6th, 2014, 09:02 PM   #40
Makes sense - sounds like it must have been snugged up there pretty tight against the caliper to be causing such issues.
Brake caliper rebuild help agentbad 1986 - 2007 Ninja 250R Tech Talk 3 April 6th, 2014 10:24 AM
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 1 May 30th, 2013 08:13 PM
Rear Brake Caliper Help blap6798 2008 - 2012 Ninja 250R Tech Talk 4 April 2nd, 2012 07:25 PM
Brake caliper pistons JamesNZ 2008 - 2012 Ninja 250R Tech Talk 19 January 22nd, 2012 09:47 PM
Brake Caliper and paint. Penguin250 2008 - 2012 Ninja 250R Farkles 11 June 26th, 2011 05:19 PM
