Old October 20th, 2012, 02:47 PM   #1
Redsvt
Coolant Leak ??
I am going to clean this off and see if it comes back. Where could this coolant be coming from??? Bike is 2012 250R 4800 miles on it. Could this be a serious issue......
Redsvt is offline   Reply With Quote
Old October 20th, 2012, 03:20 PM   #2
KELPHYN
KELPHYN's Avatar
Clean it all up, start the bike, let it run till it's up to temperature. then inspect all the hose connections, thermostat housing gasket and where temperature sensor screws in, coolant tank connections and where the coolant hose connects to the top of the engine. Looks pretty dry, sure it's not just spilled coolant from topping up the coolant tank?
Old October 20th, 2012, 04:43 PM   #3
Check the cap of the radiator as well.
Old October 20th, 2012, 08:24 PM   #4
Redsvt
Problem solved, seems both ends of the hose that attaches to the thermostat and cap were leaking at each end. One of the screws was stripped so I tightend it with a pair of pliers. Seems whoever assemble that part stripped the screw.
Oil and coolant leak SwagenGTI 2008 - 2012 Ninja 250R Tech Talk 6 November 16th, 2014 11:49 PM
Coolant leak ttassinari48 1986 - 2007 Ninja 250R Tech Talk 4 December 23rd, 2012 11:59 AM
coolant leak 93etgocart 1986 - 2007 Ninja 250R Tech Talk 4 July 5th, 2012 11:21 AM
Coolant Leak? CaliGirl 2008 - 2012 Ninja 250R Tech Talk 12 July 11th, 2009 12:54 AM
Coolant Leak Rawr 2008 - 2012 Ninja 250R Tech Talk 12 May 11th, 2009 12:07 AM
