April 12th, 2012, 07:07 PM | #1 |
Join Date: Jan 2012 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 347
I think my 2fiddy is in love with Mobile 1
So guys, as most of you know i just did a valve adjustment and what not. As well as that, i also changed the oil, and upgraded from Lucas semi synthetic to Mobile 1 Full Synthetic Motorcycle Oil. Definently worth the extra money in my opinion. It feels soooo much smoother. I know some of that is due to the valve adjustment, but another thing is it switches gears like butter.
Normally in the mornings, i would go out to the garage(anywhere from 40-60 degrees) and start my bike with the choke on, and the idle would hit 4-5000rpms. And id ride off like that. But normally when i put it in gear, it would lurch and make a loud clunking sound. As is normal for any bike im pretty sure when cold, and at a high idle(choke). Ive noticed that since ive switched to Mobile 1 that in the mornings when i put it in gear under the circumstances described above, you cant even tell! No noise, no lurching, nothing! The shifting is smoother, its harder to accidentally find false neutrals, etc... Definently going to stick with this oil for a while. Maybe even upgrade and try out Royal Purple next? Maybe not, its $17 a quart... Anyways, just thought id share! |
April 12th, 2012, 08:39 PM | #2 |
Join Date: Jun 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S Posts: 334
That's what I use as well. There's definitely a difference.
April 12th, 2012, 10:53 PM | #3 |
Jigglin' your Jiglets
MOTM - Apr '13
You should try ky jelly
April 13th, 2012, 12:04 AM | #4 |
learning stages
Join Date: May 2011 Motorcycle(s): black 09 kawasaki ninja 250 Posts: 284
im definitely gonna try that next.
April 13th, 2012, 12:16 AM | #5 |
2012 Ninja 250R Green
Join Date: Nov 2011 Motorcycle(s): 2012 Ninja 250R Green Posts: 76
KY would make it alot smoother wouldn't it? It's prolly $17 a quart too though.
April 13th, 2012, 04:11 AM | #6 |
Thanks for info.. will try that oil out in next change.
@Jiggles - why are 3/4ths of your total post(s) 1 liner off topic replies that have no use?? (PS- don't care about your answer, your on ignore list now.. sick of seeing your posts) |
April 13th, 2012, 05:34 AM | #7 | |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
Back on topic, i notice the same deference since switching to bel ray semi synthetic, but cant seem to find mobile 1 synth. Motorcycle oil around here. |
April 13th, 2012, 09:08 AM | #8 | |
MOTM - Apr '13
I like how you paged me to tell me you are blocking me, as if I give a ****
April 14th, 2012, 02:03 AM | #9 | |
Wet clutch + synthetic oil. |
[2fiddy.com] - Woot! 2Fiddy.com Giveaway! | Ninjette Newsbot | Motorcycling News | 0 | September 12th, 2008 08:41 AM |
[2fiddy.com] - Well, Someone needs to say it… | Ninjette Newsbot | Motorcycling News | 0 | August 11th, 2008 05:18 PM |
[2fiddy.com] - Time for another 2Fiddy Giveaway? Yup… | Ninjette Newsbot | Motorcycling News | 0 | July 31st, 2008 10:55 AM |
[2fiddy.com] - Yay! 2Fiddy.com 100th Post! | Ninjette Newsbot | Motorcycling News | 0 | July 14th, 2008 04:50 PM |
[2fiddy.com] - WOO-HOO! Another 2Fiddy.Com Giveaway!!! | Ninjette Newsbot | Motorcycling News | 0 | July 9th, 2008 09:19 PM |
