Old April 13th, 2012, 12:27 PM   #1
str8t six
never enough
str8t six's Avatar
Motorcycle(s): Blue 2010 ninja 250R
blacked out my exhaust
plasti dipped the chrome pieces on my exhaust. what do you think?
custom graphics, zero gravity DB
str8t six is offline   Reply With Quote
Old April 13th, 2012, 12:30 PM   #2
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
wondering how its gonna be when it gets hot...
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old April 13th, 2012, 12:32 PM   #3
str8t six
never enough
str8t six's Avatar
i was wondering that too. but i think it should hold up. i hope
Old April 13th, 2012, 12:36 PM   #4
massacremasses
Avid Kitteh Poster
they get pretty hot so idk... but good luck
Old April 13th, 2012, 12:38 PM   #5
str8t six
never enough
str8t six's Avatar
yeah if it doesnt hold up, ill just peel it off and use some flat black engine paint and repaint the muffler too.
Old April 13th, 2012, 12:39 PM   #6
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
High temp paint is all thats needed
Oh I see, plasti dip... not a great idea hahahaha
AFM #676
Supersports are for n00bs
Old April 13th, 2012, 12:41 PM   #7
realmess
Motorcycle(s): '09 ninja 250r
did the same thing to mine except i didn't plasti dip i used the rustolem spray paint that is supposed to be for high temperatures. in my case havnt had any problems
realmess is offline   Reply With Quote
Old April 13th, 2012, 12:52 PM   #8
str8t six
never enough
str8t six's Avatar
i used it to see if i liked it all black and i do
but now i wanna see if it holds up lol
Old April 13th, 2012, 12:54 PM   #9
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Curious to see if it melts. Otherwise it looks really great!
Old April 13th, 2012, 12:56 PM   #10
diablos991
diablos991's Avatar
Motorcycle(s): 2009 Ninja 250 (blue)
Can you smeeeeeeellllll what the ninja's cookin'?
diablos991 is offline   Reply With Quote
Old April 13th, 2012, 01:45 PM   #11
massacremasses
Avid Kitteh Poster
paint.
thats whats cookin...
Old April 13th, 2012, 01:57 PM   #12
diablos991
diablos991's Avatar
When it melts off, if you want to try again with high temp paint, I think it would look better to leave both tips chrome and just paint the inside section.
Old April 13th, 2012, 02:15 PM   #13
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Only thing that sucks is that not all of it will melt off
AFM #676
Old April 13th, 2012, 02:38 PM   #14
str8t six
never enough
str8t six's Avatar
ill let you guys know how it holds up
Old April 13th, 2012, 02:38 PM   #15
str8t six
never enough
str8t six's Avatar
but thats how it looked before
Old April 13th, 2012, 04:22 PM   #16
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Put the Area P back on.
Old April 13th, 2012, 07:03 PM   #17
Robinhood
Robinhood's Avatar
Motorcycle(s): 2008 Ninja 250, 2007 GSXR 600
Plasti Dip? Bad idea! Use a hi-temp paint, like some header paint. Keep in mind, chrome is hard to paint, it will likely scrape off fairly easily.
Robinhood is offline   Reply With Quote
Old April 13th, 2012, 10:09 PM   #18
I have Plasti-dip paint but I didn't consider it and bought the flat black hi-temp grill stuff.
Old April 13th, 2012, 10:41 PM   #19
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
sand chrome
hi temp primer
exhaust paint
VHT Barrel Spray Paint Gloss Black (SP905) and Satin Black (SP906) is custom formulated to restore motorcycle engines to their original factory appearance. It is extremely resistant to oil, petrol and solvents, and is heat resistant to 550ºF (287ºC). It virtually stops rust and corrosion while resisting chipping, cracking and fading.
or
VHT FlameProof Coating will renew and extend the life of any surface exposed to extremely high temperatures. This unique coating is a matte finish, ceramic base silicone widely used by the automotive industry on exhaust systems and the aerospace industry for jet engines, re-entry vehicles, the Stealth fighter, B-2 bomber and other high temperature applications.
VHT FlameProof Coating will withstand temperatures up to 1500ºF (815ºC) and is ideal for use on boilers, hot water pipes, exhaust systems, franklin stoves, heaters, barbecues, furnaces or wherever an extreme temperature coating is needed (* indicates colours that may fade at 1200ºF/648ºC). VHT Flameproof Coating only attains its unique properties after correct curing (refer to the instructions on the can).
Colours available: Flat White (SP101), Flat Black (SP102), Flat Grey (SP104), Flat Silver (SP106), *Flat Yellow (SP108), *Flat Red (SP109), *Flat Blue (SP110), *Flat Orange (SP114), Clear (SP115), Flat Aluminium (SP117), White Primer (SP118)
ninja250r81 is offline   Reply With Quote
Old April 21st, 2012, 01:16 PM   #20
squaregamer476
learning stages
squaregamer476's Avatar
Motorcycle(s): black 09 kawasaki ninja 250
couldve kept the tip part chrome. It would look like the current models. I did that recently with high heat paint. Kept the tip area chrome.
squaregamer476 is offline   Reply With Quote
Old April 22nd, 2012, 11:00 PM   #21
DailyRidden250R
DailyRidden250R's Avatar
Motorcycle(s): '09 250R No longer. '06 Mini
You like that plasti-dip stuff, don't you?
So what happened to it? Did it melt yet?
DailyRidden250R is offline   Reply With Quote
Old April 30th, 2012, 09:19 AM   #22
str8t six
never enough
str8t six's Avatar
haha! yeah i do! ive even coated the wheels on my truck with it! lol
i went for a ride yesterday for several hours and it has held up just fine. no peeling or flaking that ive noticed.
Old April 30th, 2012, 09:18 PM   #23
joshuajcrouch
Love the look. Going to paint mine flat black this weekend.
joshuajcrouch is offline   Reply With Quote
Old May 1st, 2012, 09:25 AM   #24
massacremasses
Avid Kitteh Poster
do it with hitemp paint....
Old May 1st, 2012, 08:24 PM   #25
str8t six
never enough
str8t six's Avatar
I would but this seems to work just fine for now.
Old May 2nd, 2012, 06:44 PM   #26
DailyRidden250R
If it works, it works! Glad that it is working out for you. Please do follow up long term!
Old May 3rd, 2012, 08:10 AM   #27
massacremasses
Avid Kitteh Poster
sorry I was responding to the guy who wanted to do it... whats done is already done.
Old May 3rd, 2012, 09:52 AM   #28
joshuajcrouch
Yeah thanks Justin. I have been reading up on paints to use. Supposedly VHT has a an exhaust paint that is good up to 2,000 degrees. Now I just need to call around to see if I can find it...
Old May 3rd, 2012, 09:57 AM   #29
massacremasses
Avid Kitteh Poster
whoa thats pretty hot, idk if that is necessary, but that stuff they have for grills and stuff would work Im sure. I would imagine it wouldn't get hotter then a grill. lol
Old May 4th, 2012, 11:17 AM   #30
abp1tsx
Motorcycle(s): 08 250r
Yep, works great. No need to prime. Just scrub the exhuast with some fine sandpaper, wipe down with some degreasing soap, and spray away. Gives a nice matte black finish and i can actually touch it after a ride without getting immediatly burned. Its good up to 1500 degrees, fairly durable, and is readily available anywhere.
abp1tsx is offline   Reply With Quote
Old January 18th, 2013, 02:58 PM   #31
sLick415
Sorry for bringing this back. But how's the plasti dip? Has it been holding up after all these months?
sLick415 is offline   Reply With Quote
Old January 26th, 2013, 10:40 PM   #32
Adrastos
Adrastos's Avatar
Motorcycle(s): Kawasaki Ninja 300
Plasti Dip is good up to 312°F. I have seen people plasti dipping their car exhaust tips and so far its held up well for 6 months... never really heard of a melting story.
Adrastos is offline   Reply With Quote
Old January 30th, 2013, 05:12 AM   #33
tubarney
For the muffler. High temp paint to 500F is recommended. For the headers 1200F is recommended.
Old January 30th, 2013, 06:02 AM   #34
MistahT
Motorcycle(s): 2012 FZ6R, 2006 Ninja 250, 1977 Suzuki GS550
To the last two posts.... Plasti-Dipping exhaust tips is probably alright because tips don't get as hot as the rest of the pipe, so that's probably why his muffler is ok. If you try to dip exhaust pipes or headers, you'd probably be in trouble.
Glad to see it's worked out! I've still got a bunch of dip sitting around and I don't like the polished mufflers on the pregen. I might dip and see if it holds up. If it doesn't, maybe time for a new exhaust Win-win
2012 Yamaha FZ6R (mine)
2004 Kawasaki Ninja 250 (wife)
2003 Kawasaki Ninja 250 Street Fighter project
MistahT is offline   Reply With Quote
Old January 30th, 2013, 04:32 PM   #35
sLick415
Let us know how it holds up!
Old January 31st, 2013, 09:28 AM   #36
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
I had the Leo stainless steel full system and it just stood out to much so I did this.
This is flat black powder coat with the $60 HF system. I have a much nicer pro level gun be shipped next week and when it arrives I'll be re-coating the can a slightly glossier flat, the stainless mounting strap as well as the two riveted straps that hold the can together will be a semi gloss gunmetal, and I debating on wether to leave the rivets black or orange to match my rotors.
Powder coat on the header has about 700 miles and shows zero change in color
Last futzed with by rojoracing53; January 31st, 2013 at 05:37 PM.
Old February 6th, 2013, 07:51 AM   #37
massacremasses
Avid Kitteh Poster
wuuut? do you not ride for long periods of time? Most powder cures at about 400 degrees. 400 or ever is like rebaking it everytime. I would imagine the header gets hotter than that. If its black maybe thats why the color hasnt changed but I wonder if the properties of it changed. If over baked it will get brittle....
Old February 6th, 2013, 08:28 AM   #38
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
To the best of my knowledge these little 250 motors don't put out as much heat as say an R-1 so the exhaust runs cooler. My commute is only 30mins but I have at least 1000mile since I coated it and during that time I did two 250 mile canyon rides. I know the headers where they connect to the engine get hotter then the rest of the pipe so its most likely to change first if at all. I just got in a high temp powder designed to withstand 1000degs and cures at 450, this is what I'll be using on the headers.
The can dosent get nearly as hot as the headers so normal temp powder should work just fine.
Also some paints even though they cure at a set temperature will be able to withstand twice as much after they cool and completly cure. The heat acts as an activator to combine the chemicals that when combined can take the heat.
Old February 6th, 2013, 08:39 AM   #39
massacremasses
Avid Kitteh Poster
Yeah I know the can you can do with a normal coating.
but ok using a high temp powder I imagine would work. Ive never used that before. I should look into getting some I guess. I am only allowed to get good stuff if I use our 5k powder coating machine.. lol
Old February 6th, 2013, 09:04 AM   #40
psych0hans
psych0hans's Avatar
I powder coated my entire exhaust black, including headers and midpipe... Will post a review once I put it to some use...
FS: Area-P solo exhaust bracket for Ninja 300 w/stock exhaust c-dog Motorcycle-related 2 September 12th, 2014 10:48 AM
Blacked out windscreen- WHY JH PiNoY General Motorcycling Discussion 21 July 1st, 2013 08:42 PM
First Little mod - Blacked Out windscreen Legend 2008 - 2012 Ninja 250R Farkles 11 July 25th, 2012 04:23 PM
[topix.net] - Victory Motorcycles High Ball is a blacked-out menace Ninjette Newsbot Motorcycling News 0 January 22nd, 2011 07:00 PM
New Member! And his Blacked out 09! norm_52 Pictures 12 July 2nd, 2009 10:49 PM
