November 11th, 2013, 09:31 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): 2008 ninja 250 Posts: 271
shimming question
Hi I took the snorkel off & changed the original air filter, (14,000miles)
So Ian getting the infamous midrange bog, Top end runs great. My question is what do you use for washers to shim stock carb settings? How many washers did your use? Iam trying to get a feel for where to start at. Btw I love the sound with the snorkel out, but the midrange bogs a little too,much, eg maintenance throttle in the corners. Thanks |
November 12th, 2013, 06:59 AM | #2 |
dirty boy
MOTM - Apr '14
Check out the (New Gen DIY) stick thread at the top of the New Gen tech talk page. In that sticky there is a few Do It Yourself (DIY) write ups that will help you out.
P.S. I Don't know for certain cuz I have never done it, but I am pretty sure if you remove the snorkel you will definitely need to adjust needle height (shim) and maybe even change the main jet but I am not 100% on that
November 12th, 2013, 08:40 AM | #3 |
ok
Thanks
November 12th, 2013, 12:16 PM | #4 | |
You can use 3 mm or SAE #4 washers. If you can't find 3 mm washers at your local hardware store, they carry them at Radio Shack and most RC Hobby stores |
November 16th, 2013, 12:22 PM | #5 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
Yeah, I got a packet of assorted washers at radio shack, the ones I used were the 2nd smallest ones. With the snorkel out I think I was using 3 washers under each needle.
question drop in filter or shimming | vmax | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 22nd, 2013 07:14 AM |
question about shimming those needles | fizzer914 | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 11th, 2012 03:12 AM |
Exhaust/Shimming/FI question.. | jack_bm | 2008 - 2012 Ninja 250R Tech Talk | 17 | March 20th, 2012 02:07 AM |
Question about the washers to use when shimming the needles | Kitdog | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 30th, 2010 12:38 PM |
Shimming the needles question | Tubesock | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 15th, 2009 12:17 PM |
