Old June 7th, 2011, 07:27 AM   #1
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
k&n drop in filter question
just curious to those who have bought the drop in filter, is it worth the $40-50 or better to keep the stock foam one in? bike is completely stock other then snorkel removed and shimmed.. thanks for the help
greatwhiteninja is offline   Reply With Quote
Old June 7th, 2011, 07:41 AM   #2
TXJ
Cranky Old Fart
TXJ's Avatar
Motorcycle(s): 08 DRZ400SM
It's worth it if you plan to keep your bike for a long time. It's much more convenient than buying a new filter all the time. Just clean it, grease it and throw it back in. Unless you're doing serious upgrades don't buy one strictly for the hope of more power. Buy it because it is a added convenience and a high quality product.
TXJ is offline   Reply With Quote
Old June 7th, 2011, 10:56 AM   #3
DaBlue1
DaBlue1's Avatar
Also consider a high performance foam filter that is also cleanable and last longer than the stock filter.
http://www.ninja250forum.com/index.p...6&topic=3515.0
File Type: png Pipercross Air Filter (2).JPG_thumb.png (712.1 KB, 9 views)
Old June 7th, 2011, 01:56 PM   #4
HMB-ninja
Motorcycle(s): 08 Ninja 250R(red) 09 Ninja 650R(red) 08 PGO Buddy 150(Pamplona)
I don't have mine yet but I did order a K&N, like TXJ said I have always used K&N for the fact that they are high quality and reusable, the slightly better performance and increase in mpg (in my cars) is a bonus. Plus I was browsing amazon for the Factory Pro jet kit and I found the K&N drop in for ~$13 in their new warehouse depo? If I understand correctly, its stuff that people order and for some reason send back (wrong size? Or part#?) so I could not pas up the deal.
Also as a side note: I never open up/looked at the stock filter until after I ordered the K&N, but it looks a lot like some of the other aftermarket foam filters and it was heavily oiled so I would think you could wash and reoil the factory filter in the same way you would the other reusable aftermarket ones right?
HMB-ninja is offline   Reply With Quote
Old June 7th, 2011, 02:34 PM   #5
DaBlue1
DaBlue1's Avatar
Originally Posted by HMB-ninja View Post
...Also as a side note: I never open up/looked at the stock filter until after I ordered the K&N, but it looks a lot like some of the other aftermarket foam filters and it was heavily oiled so I would think you could wash and reoil the factory filter in the same way you would the other reusable aftermarket ones right?
The stock air filter can be cleaned and re-oiled then reused, however it does have a service life. Kawasaki recommends replacement at 2 years. One of the things I noticed was how over time the stock filter became compressed and stay that way. Compression can cause the micro pores / holes to become smaller and have possibly less air flow. Also a lack maintenance can make the filter become dry a brittle. Two of the aftermarket foam drop in type filters are less compressible and breath better. The stock filter can be rolled up into a little ball, the Pipercross filter I have, can not, it also has a special filter additive and cleaner, not an oil additive.
Old June 7th, 2011, 07:06 PM   #6
kaiserz
There's a limit to s2pdty
kaiserz's Avatar
13 dollars? link please (:
Old June 7th, 2011, 07:39 PM   #7
HMB-ninja
Kaiserz, just looked up the filter # on amazon and it was there posted just under the new ones listed as "used" it said 1 available.
Old June 7th, 2011, 08:44 PM   #8
Boom King
So, where's the reverse?
Boom King's Avatar
You won't notice any performance difference from stock with the K&N filter. The stock foam filter also probably does a better job of keeping dust, dirt and other unwanted particles out of your engine compared to the gauze type design of the K&N although the K&N will let more air through. Again, any performance gains from this is negligible. The K&N also does not fit perfectly like the OEM filter. It seems to stick out a bit. You have to really push and hold the cover while you screw it back on.
Old June 7th, 2011, 09:54 PM   #9
n_aditya
n_aditya's Avatar
Motorcycle(s): 2010 Ninja 250R (for the weekend's) and the Suzuki Fiero for office commute.
...... I have always used K&N for the fact that they are high quality and reusable, the slightly better performance and increase in mpg (in my cars) is a bonus.
I have a K&N stock replacement filter in my ninja and i feel the bike is slightly quicker - a very small increase in throttle response. Also i used to get around 25-27 kilometers per liter of gasoline (kmpl) and now it has dropped to 23kmpl. Maybe because i am wringing the throttle more than before. Been using this for a little over 2500 kms.
Earlier with the foam filter the bike used to reach around 140kmph really quick and after that it was a gradual climb. With the K&N it reaches 155kmph pretty fast and then the climb is slow. I may be wrong and this may just be psychological.
+1 on all of the above points.
I've been concerned about the amount of dust filtered out by the K&N and other such aftermarket filters. There are many discussions on why K&N is good and also why its not. A lot of people claim that K&N and other such filters let dust to pass through which can harm the engine in the long run.
Do you think i should go back to the stock foam filter?
n_aditya is offline   Reply With Quote
Old June 7th, 2011, 10:53 PM   #10
Boom King
Boom King's Avatar
It's your call. On normal street riding, I doubt any decrease in filtering effectiveness of the K&N is going to make that much of a difference but I'm just going on gut feeling here. If you live in a dusty area or ride on dirt roads and such, I'd probably go with the stock foam or another high quality after market foam filter. For what's it worth, the general consensus for the filter of choice for owners of the Kawasaki Teryx is a foam filter. These are recreational off-road 4x4s that live in sandy and dusty environments. Uni filters seem to have a good rep among that community and they make a foam filter for our Ninja as well:
http://www.unifilter.com/online%20ca...tkawasaki.html
http://www.motorcycle-superstore.com...50R-Parts.aspx
Old June 8th, 2011, 07:49 AM   #11
DaBlue1
DaBlue1's Avatar
...I've been concerned about the amount of dust filtered out by the K&N and other such aftermarket filters. There are many discussions on why K&N is good and also why its not. A lot of people claim that K&N and other such filters let dust to pass through which can harm the engine in the long run.
The best thing to do is research. There are a couple of foam air filter replacements for the 250 Ninja. Foam filters are the best when riding in sandy, dirty, dusty & wet conditions. If the were not, they would not use them in those type of conditions. Uni-filter was one that was mentioned and Pipercross was the other.
The Pipercross filter carries a very good pedigree and they also have stats as to their effectiveness. One of their claims is that "Pipercross air filters consistently outperform paper and cotton-gauze rivals to supply air to the engine - even when dirty! This is thanks to the multilaminate construction used in every Pipercross performance air filter. Layers of varying porosity foam all work together to trap different sized particles."
Fairly new to the States, they have the highest reputation overseas. Pipercross is also an Official partner for the 250 & 600 Ninja Trophy http://blog.pipercross.net/?p=304
and in partnership with Kawasaki Racing
http://www.pipercross.net/motorcycle/products.asp
http://www.calsportbike.com/px/
Old June 8th, 2011, 08:20 AM   #12
kaiserz
kaiserz's Avatar
I'ma look into this, thanks blue.
Old June 8th, 2011, 06:36 PM   #13
greatwhiteninja
Ridin Dirty
thanks for the input guys.. im mainly looking to do it for increased power, maybe the best bet is just removing the airbox all together and doing the dual pod k&n, cause im sure thats what ill end up doing in the long run, might as well just do it and be done with it. unless theres not a huge difference from going that route to a good quality high flow filter?
Old June 8th, 2011, 07:19 PM   #14
NathanUc
B-Town Ninja
NathanUc's Avatar
Motorcycle(s): Black 2013 Ninja ZX6R ABS
JFC makes a solid air filter as well. I think it's around $45-50 and comparable to the K&N from what I hear.
Downgraded to a 2013 636. Previous owner of a 2010 250r
My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja
NathanUc is offline   Reply With Quote
Old June 8th, 2011, 11:52 PM   #15
ratlab
ratlab
ratlab's Avatar
Motorcycle(s): gsxr1000,R3x2,RC390,FZ07,XR100
if your looking for performance then bmc is the best
ratlab is offline   Reply With Quote
question drop in filter or shimming vmax 2008 - 2012 Ninja 250R Tech Talk 1 August 22nd, 2013 07:14 AM
08-12 Ninja 250 K&N drop in filter drunyon Motorcycle-related 4 December 17th, 2012 06:35 PM
K&N drop in air filter Zyconic17 Motorcycle-related 1 October 2nd, 2012 12:21 PM
air filter question gsxrninja250 2008 - 2012 Ninja 250R Tech Talk 4 September 4th, 2011 07:33 PM
K&N Drop In Filter Available for 08/09 Bikes kkim 2008 - 2012 Ninja 250R Tech Talk 34 March 21st, 2009 11:16 AM
