Old February 3rd, 2012, 12:17 PM   #161
hackeron
Motorcycle(s): Ninja 250r (2009)
+1!! we cut that stupid **** off cause its ****!
Is there any other solution for reducing wrist strain? - one that doesn't cause binding?
http://www.fuelly.com/driver/hackeron/ninja-250r
hackeron is offline   Reply With Quote
Old February 3rd, 2012, 12:26 PM   #162
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Yes,....never ride your bike.
Old February 3rd, 2012, 12:48 PM   #163
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
or massive amounts of blow
Rexbo is offline   Reply With Quote
Old February 3rd, 2012, 12:49 PM   #164
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
To be fair my issues were not related to the mod at all - simply the grip, and I wish I had my mod back... Though I used PVC pipe, not a zip-tie, for a more "direct fit"
Old February 3rd, 2012, 01:03 PM   #165
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
You're gay. Okay, it was the mod & the grip. You happy?
Old February 3rd, 2012, 02:14 PM   #166
maybe try not putting your wrist in an awkward position? if you are going to be leaving your throttle in one position for a long time, reposition your hand so its comfortable. yes yes i know the msf says not to. they tell you not to because idiots forget they have their hand repositioned then go to slam on the brakes because they werent paying attention and are now getting cut off and dont actually let off the throttle all the way and just wash their front out. just dont do that and you'll be fine.
Old February 3rd, 2012, 02:16 PM   #167
i donno man, road-head on a bike might be a tricky maneuver
Old February 3rd, 2012, 02:23 PM   #168
Trailerboy531
You told me I was happy and then you asked.. I'm confused!
Still not sharing a tent with you though...
Old February 3rd, 2012, 03:54 PM   #169
there's a pedo-RV for a reason, maxipad. the reason is so cheeks can have gay anal sex with you and none of us have to listen.
Old February 3rd, 2012, 06:17 PM   #170
Trailerboy531
...Is that where his nickname came from?
Old February 3rd, 2012, 07:06 PM   #171
i'm gonna go with yes and say it has absolutely nothing to do with his last name.
Old February 7th, 2012, 05:20 PM   #172
icbm
icbm's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2006 Suzuki Hayabusa GSX1300R, 2004 Kawasaki ZRX1200R, 1985 Kawasaki 750 Turbo
For as cheap as the R6 or R1 throttle tube w/grip, this is the best way to go.
The R1 will go on with no issues at all. The R6 may need some dremeling in some areas and some adjustments in the cable as well. I have the R1 mod as I have done this mod on all my bikes. You will get a little less than 1/8" difference where it stops. The R6 I believe double that. I think the R6 may be best for the little Ninja especially for racing but maintaining a steady cruise will be more difficult. I may actually order one up since they are even cheaper than the R1.
Stock
R1
icbm is offline   Reply With Quote
Old February 7th, 2012, 08:28 PM   #173
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
Because when I attempted this some time last year I immediately experienced cable binding issues. Trailerboy experienced the same thing on his bike @ a trackday event last month. Granted he didn't have any issues prior but you may eventually experience this. Hopefully not during emergency situations.
I'm not a big fan of simple DIY homemade mods--I'm a direct fit kinda guy.
i NEVER had any issues idk man maybe god doesn't want u going to fast
THE GOOD LIFE
Old March 27th, 2012, 07:44 PM   #174
Dimsum_The
After doing this mod I noticed a lot of binding by removing the push/return throttle cable I was able to remove virtually all of the binding. Are there any major disadvantages to removing this cable?
Dimsum_The is offline   Reply With Quote
Old March 28th, 2012, 12:40 AM   #175
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
It's basically there a a backup in case the throttle assembly on your carbs fails and doesn't snap shut on its own. This would be most likely to happen at WOT in which case you'd be stuck there, so it's a good idea to have that cable installed. I'd go back and see what you did wrong that's causing the binding and fix it.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old March 28th, 2012, 12:44 AM   #176
CynicalC
CynicalC's Avatar
Originally Posted by trixter View Post
(particularly with a slightly burred worn cable) and then bind.
If your throttle cable has ANY burrs, kinks, broken strands or any other obvious signs of wear, it should be replaced.
Old March 28th, 2012, 02:56 AM   #177
cuong-nutz
cuong-nutz's Avatar
I guess I should around to doing this free mod. Friends are laughing at me breaking my throttle tube trying to keep up.
HalfFast Racing Team
Old March 28th, 2012, 06:55 AM   #178
well it won't really give you more throttle, just less twist to get to WOT
the convenient side effect is that a) right when you make the mod, you're still turning the throttle the same amount which means your bike feels peppy-er, and b) it helps a lot with fine-tuning your throttle control by forcing you to get used to making tiny inputs (helps with the transition to a larger bike)
Old March 28th, 2012, 03:13 PM   #179
cuong-nutz
cuong-nutz's Avatar
Yeah I totally know but the whole "twisting my wrist and shifting" won't look as bad
Old March 28th, 2012, 08:50 PM   #180
gilmorec61
gilmorec61's Avatar
This definently didnt work as well as i thought it would for me...:/
gilmorec61 is offline   Reply With Quote
Old March 28th, 2012, 08:58 PM   #181
cuong-nutz
cuong-nutz's Avatar
How so?
Old March 30th, 2012, 12:38 PM   #182
CynicalC
CynicalC's Avatar
I can only imagine that your expectations were unrealistically high, or you did something wrong.
Old March 30th, 2012, 12:54 PM   #183
^^ +1
dude it's just a way to get WOT without having to re-grip...
if it's sticking, lube it
Old March 30th, 2012, 12:57 PM   #184
Old March 30th, 2012, 01:01 PM   #185
that's actually something my prof showed me in class at the beginning of the year!
sad part is, that's actually the method of fixing things that my dad and I both share...
Old June 25th, 2012, 04:06 PM   #186
Monkeytofu
I told you bro
Monkeytofu's Avatar
Motorcycle(s): 1996 Ninja 250r
About to do this mod, I figured I'd use some heat shrink tubing around the zip tie to add slightly more thickness and make the zip tie smooth. You guys think there would be any possible issues besides the usual binding problems people have seen here?
Some tests, the red tubing I have is a bit thicker and if I wanted more thickness I could put red over white and shrink it that way so I can get more thickness while keeping the shape.
Monkeytofu is offline   Reply With Quote
Old July 3rd, 2012, 10:06 PM   #187
Monkeytofu
I told you bro
Monkeytofu's Avatar
Did this yesterday. The tubing doesn't hold up very well so I went ahead and did it with 1 zip tie. Works beautiful!
Old July 4th, 2012, 08:21 PM   #188
sil3nt
Motorcycle(s): 1988 GPX 250
I have been trying to get this to work. The cable tie rubs against the part with the holes in it that guides the cable in this photo
http://www.ninjette.org/forums/attac...5&d=1249856202
This appears to be the only part that is binding. Decided to give up. Not sure if a new throttle tube will make any difference as I would surely have the same clearance issues.
My bike is from the first year of production '88 so maybe there are some differences. I know the colour of the throttle tube is black on my bike and the piece that guides the cable is white. It is also rather loose in the casing. Is it meant to move around?
I might try and get a video if no one can understand what I mean.
sil3nt is offline   Reply With Quote
Old July 5th, 2012, 12:35 AM   #189
Monkeytofu
I told you bro
Monkeytofu's Avatar
the construction looks exactly like my 1996 model and I didn't have any issues with catching. What kind of zip tie are you using? It could be you're using one that's too thick. Mine was about 1mm in thickness and it works flawlessly. It also looks like your ziptie may be too close to the hole the cable goes through; try sanding that down some more and see what happens.
Also, just as a note: please be careful after doing this mod. The change is significant enough to require relearning a lot about the bike's handling and output. At least if you're a beginner like me :x
Old July 5th, 2012, 02:49 AM   #190
sil3nt
The image I used was from the first post. I haven't taken any myself yet.
I have had the bike for 3 years now and it is for my girlfriend to ride. After getting a service she wasn't happy with how far you have to twist the throttle to get the bike going as it was much shorter beforehand.
Old July 5th, 2012, 05:17 AM   #191
psych0hans
psych0hans's Avatar
Can this mod be done on a new gen bike as well?
Old July 5th, 2012, 11:15 AM   #192
Monkeytofu
I told you bro
Monkeytofu's Avatar
Yes, it's exactly the same process I think.
http://www.youtube.com/watch?v=MBg8Bp14u5k
Video of someone doing it on the newgen, but he doesn't use a zip tie. Same process.
Old September 28th, 2012, 10:31 AM   #193
psych0hans
psych0hans's Avatar
I finally got this mod done. Made a difference, but not as much as I was expecting. My throttle was binding due to the serration on the zip tie, so I had to shave it till it was smooth. May be that's what made it thinner, hence not as quick as I was expecting. I might go in for a second zit tie after shaving the serration, to see if it makes things better... Unless any of you guys can give me a better idea? I'm in no place to afford buying after market tubes, so please don't recommend that.
Old September 28th, 2012, 10:34 AM   #194
make your own tube and housing
Old September 28th, 2012, 10:40 AM   #195
Monkeytofu
I told you bro
Monkeytofu's Avatar
Try using another zip tie and lubing your cables as well. The only catching I encountered was when I accidentally put the zip tie on edge and it made it wider. I had success with some multicolored zip ties at the dollar store.
If you're always going WOT with the bike you won't notice much of a difference I think. I'm a miser when it comes to the throttle so the difference was quote pronounced for me.
Old September 28th, 2012, 10:57 AM   #196
psych0hans
psych0hans's Avatar
The kind of advice I was looking for Thanks. I'll see what I can do. Probably not too soon though. In a couple of weeks. And I'll have the service center do it, so they can lube my cables at the same time.
Old September 28th, 2012, 12:54 PM   #197
icbm
icbm's Avatar
I really think you guys should use the throttle tube from an Yamaha R1 or even an R6. So much easier to deal with and will always work flawlessly. R6 tube probably the best for the Ninjette. I currently use the R1 on my 08 Ninjette and it was better but I think the R6 would be best assuming you have enough cable adjustment. I use the R1 on both my ZRX and Hayabusa and that is best for street riding on those bikes. My Ninjette bike is completely apart so I haven't had a chance to try the R6 tube. I tried the R6 on my old Kawi 750 Turbo but the Turbo has a really small one and I don't have enough cable to make it work. I think I will look into a custom cable to use this throttle on this bike as I primarily drag race this bike. I'll post picks up soon showing the Ninjette stock tube, 750 Turbo tube, R1 tube and the R6 tube.
Old September 28th, 2012, 12:56 PM   #198
psych0hans
psych0hans's Avatar
Originally Posted by icbm View Post
I really think you guys should use the throttle tube from an Yamaha R1 or even an R6. So much easier to deal with and will always work flawlessly. R6 tube probably the best for the Ninjette. I currently use the R1 and it was better but I think the R6 would be best assuming you have enough cable adjustment. My bike is completely apart so I haven't had a chance to try it. I tried the R6 on my old Kawi 750 Turbo but the Turbo has a really small one and I don't have enough cable to make it work. I think I will look into a custom cable to use this throttle on this bike as I primarily drag race this bike. I'll post picks up soon showing the Ninjette stock tube, 750 Turbo tube, R1 tube and the R6 tube.
That would be BRILLIANT!!!
p.s. is THIS what you are talking about?
Old September 28th, 2012, 01:02 PM   #199
icbm
icbm's Avatar
This what you are talking about?
Yes.
Old September 29th, 2012, 07:33 PM   #200
icbm
icbm's Avatar
Here are some pics:
Left to right:
Stock Kawasaki 750 Turbo
Stock Kawasaki 2008 Ninja 250R
Stock Yamaha 2006 R6
DIY How to Lube and Adjust the 250R Clutch Cable and How to Add 10 HP w/ one Mod!!! kkim 2008 - 2012 Ninja 250R Tech Talk 51 October 11th, 2014 06:42 PM
Throttle went while riding -> need new throttle cable? AndrewMack 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2013 06:17 PM
Adjusting Throttle Cable - Barrel adjusters and Throttle body adjusters are maxed out theob 2008 - 2012 Ninja 250R Tech Talk 10 July 19th, 2012 05:01 PM
(zip tie mod + u-turn) x me being an idiot = no good Monkeytofu !%@*#$%!)@#&!%@ I crashed! 1 July 4th, 2012 07:59 PM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
