Old July 1st, 2014, 04:14 PM   #1
tuscani451
Motorcycle(s): R6, Kawi 250
Removing the carb-without removing airbox?
I looked at the DIY section but didnt do a extensive search. Is there anyway to remove the carbs without going through the hell of removing the stock airbox? I am sorry if this has been covered before. I looked at the Airbox removal thread decided to drink beer instead.
Thanks
Leif
tuscani451 is offline   Reply With Quote
Old July 1st, 2014, 04:17 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
You don't have to remove the air box to remove the carbs. You have to remove all the bolts holding the airbox and shove it back to make just a little room to squeeze the carbs out. It's a PITA any way you look at it so just go back to drinking beer
Old July 1st, 2014, 04:35 PM   #3
its like 2 allen head screws holding the airbox in position, one on the side and one on the bracket held in by 4 hex head screws, plus the clamps on the tubes. then you just slide it back
Old July 1st, 2014, 04:43 PM   #4
xorbe
xorbe's Avatar
Somewhere I thought there was an FAQ about splitting the airbox from the battery tray or something for easier access later, but I can't find it atm to confirm.
Edit: aha, http://faq.ninja250.org/wiki/Battery...r_carb_removal
Old July 1st, 2014, 05:07 PM   #5
cuong-nutz
cuong-nutz's Avatar
made this just for you
https://www.ninjette.org/forums/showthread.php?p=890054
HalfFast Racing Team
Old July 1st, 2014, 05:14 PM   #6
tuscani451
Y'all are awesome, thanks, let me finish this beer and i'll get back to work. thanks again I really love this forum.
Old July 1st, 2014, 05:39 PM   #7
Box is split from the factory on this model.
Old July 2nd, 2014, 08:33 AM   #8
xorbe
xorbe's Avatar
Ah whoops, I'm in the '08+ subforum, was browsing via View New Posts, my bad.
Old July 6th, 2014, 02:07 AM   #9
Animoto
Motorcycle(s): '12 Ninja 250
I feel the need to post because it took me a day and half to figure out how to remove carbs from the air box. If the 4 hex key doesn't work try a 3 1/2 . Took me a day to figure out I needed that lol how sad
Animoto is offline   Reply With Quote
Old July 6th, 2014, 04:25 AM   #10
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Would it be split for my ninja? (2012)?
Be careful. Remember you are
invisible
Old July 6th, 2014, 05:11 AM   #11
Yep. The battery box is bolted to the frame and undertail with the same bolts that the side panel uses (two are under the battery box). Removing the battery box is a cinch so it isn't in the way of the carbs and air box at all like it was on the F bike.
Removing Mirror Bracket (with removing all the fairings) killermase 2008 - 2012 Ninja 250R Tech Talk 11 May 21st, 2012 11:16 PM
Removing Carb, Need Help ASAP! EliteNinja 2008 - 2012 Ninja 250R Tech Talk 2 March 31st, 2012 04:07 PM
Removing ignition NathanUc 2008 - 2012 Ninja 250R Tech Talk 1 March 26th, 2012 11:38 AM
Removing Stickers forevertwowheels General Motorcycling Discussion 6 April 14th, 2011 10:02 PM
removing silencer? bbbrandy19 General Motorcycling Discussion 38 March 24th, 2011 09:15 PM
