Old May 1st, 2010, 01:46 PM   #1
Zim
Motorcycle(s): '04 EX250F
Can't fit calipers over disc with new pads
I bought a set of EBC FA141 pads for the rear caliper but the new pads appear to be too thick to fit over the disc (there isn't enough gap between them). I pushed the big pad out as far as possible on the stems and the pistons are all the way in but it's not even close, I need 1-3mm more clearance to get them on. I'd grind them down but the EBC packaging says specifically not to do that because of asbestos.
Any advice? This is really frustrating.
Zim is offline   Reply With Quote
Old May 1st, 2010, 03:00 PM   #2
you should be able to push the pistons in the calipers in so they are flush with the inside edge of the calipers. are they pushed in that far right now?
Old May 1st, 2010, 03:13 PM   #3
iceman.kcmo
Motorcycle(s): 94 Ex250
x2
make sure to take the little plastic peices out before you push them in. I almost broke one doing that.
iceman.kcmo is offline   Reply With Quote
Old May 1st, 2010, 06:30 PM   #4
Zim
I showed them to a neighbor and he stuck a flathead screwdriver into the gap and slowly twisted it sideways and magically the pads sunk down another few mm. Turned out the pistons weren't driven all of the way in. Neat trick and now I know how to get them flush.
Old May 25th, 2010, 05:09 PM   #5
Thrak
Motorcycle(s): Lots
for future people searching, before you push the pistons back in take the cap and diaphragm off the fluid resivoir
it'll be easier to push them in, and easier on the caliper seals too
Last futzed with by Thrak; May 25th, 2010 at 06:18 PM.
Thrak is offline   Reply With Quote
Old May 25th, 2010, 05:31 PM   #6
Banzai
Psychic war veteran
Banzai's Avatar
Originally Posted by Thrak View Post
for future people searching, before you push the pistons back in take the cap and diaphragm of the fluid resivoir
...and don't push TOO hard, or you'll jet brake fluid all over! Further, monitor the fluid level, as it's easy to overflow it while pushing the pistons back in, too.
Been there, done that....BOTH of the above!
Old May 25th, 2010, 06:15 PM   #7
Grn99Kawi
Grn99Kawi's Avatar
Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold)
Don't take this the wrong way.. but next time you tackle something on the bike either get a service manual, get some experience with an experienced person watching, or do both (best to do both). You don't want to learn on something like brakes... it could mean your life.
I have been working on cars for a long time and even still I have a service manual...
2000 Honda CBR600F4 Silver and Red
1999 Kawi Racing Green Ninja 250 sold
Grn99Kawi is offline   Reply With Quote
Old May 25th, 2010, 08:17 PM   #8
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
A c-clamp works well too.
Rear caliper wont fit on disk with new brake pads Twisthem488 2008 - 2012 Ninja 250R Tech Talk 8 March 14th, 2014 12:39 AM
