September 19th, 2011, 11:00 PM | #1 |
Chain/sprocket replacement question (I forgot)
At 26K miles, I need to replace my chain.... again. This will be my 3rd. I replaced it myself last time with no issues, but there is one thing I forgot, and want to double-check before ordering a new chain. I am running a 15T counter-sprocket... do I still use the 106 link chain? I'm pretty sure there is enough adjustment to go with the 106 link, 95% sure actually, but with my luck lately, I need to be sure.
BTW: The only part of the chain that has rust on it, is the master [clip] link. Theoretically, only the master link is bad, but I'm thinking since the chain is kind of important, I should play it safe. Also, I never replaced the sprockets last time, and wear still isn't obvious to me... do I REALLY need to replace both sprockets?
September 19th, 2011, 11:04 PM | #2 |
You do not need a different length chain due to a 15-tooth in front instead of a 14-tooth. The advice to change both sprockets whenever replacing the chain, is due to the new chain wearing much more quickly on the worn sprockets. If the sprockets truly aren't worn at all and look/work as new, then there is no safety reason that would require new ones. But at 26k miles, I'd be darned sure to compare them against newish ones to make sure that they do look good. If they are worn at all, I'd replace 'em.
September 19th, 2011, 11:06 PM | #3 | |
Join Date: Aug 2010 Motorcycle(s): Bike-less, Can I ride yours? Posts: 318
Also, when was the first time you changed your chain/sprockets, I am about 10k and not sure whether I should change them or not.
RR stands for Responsible Riding... Right? |
September 19th, 2011, 11:24 PM | #4 | |
I replaced it the first time at 15K due to rust.
Chain and sprocket question | Baron | 2008 - 2012 Ninja 250R Tech Talk | 12 | July 11th, 2014 01:35 PM |
Sprocket Replacement? | kennetht | 2008 - 2012 Ninja 250R Tech Talk | 22 | April 6th, 2014 07:37 AM |
Chain and Sprocket Question | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 25th, 2014 01:44 AM |
Sprocket and chain length question. | MKlein3004 | Ninjettes At Speed | 2 | August 14th, 2013 06:40 PM |
Chain/Sprocket replacement | 02ninjaeastbay | 1986 - 2007 Ninja 250R Tech Talk | 2 | June 12th, 2011 07:52 AM |
