Old March 23rd, 2017, 06:41 AM   #1
UFOmoplata
UFOmoplata's Avatar
Motorcycle(s): 2007 Hoodrat 250
Oil leak from the side
Hello Newgen tech,
I'm having an oil leak come from the side of the engine here:
I first noticed it when leaning the bike on the kickstand. The bike is normally on a rear stand.
Is this a sign of too much oil or a gasket or some other type of issue?
Other things I've noticed:
-Oil pukes out of the breather filter/recirculation (K&N 0990 attached) when running.
Related?
"Brah, you can't be looking like that on a 250, brah. You gotta mod a 250, brah. It's like the hachi-roku of bikes."
UFOmoplata is offline   Reply With Quote
Old March 23rd, 2017, 06:49 AM   #2
The photo shows the screw-in plug in the alternator covor. As I understand it, it's normal for some oil to be inside that cover. If it's seeping out, that cover is not tight, or something is causing it to not seal properly.
I don't have enough experience with the 250 breather system to offer much there, but from experience with other motorcycles, I can tell you that overfilling the engine or tipping the bike over can cause oil to be expelled. Excessive blowby can too.
Old March 23rd, 2017, 07:46 AM   #3
taz
taz's Avatar
MOTM - May '17
like Jim said it might not be tight or the o ring for it to seal could be bad.
Old March 23rd, 2017, 07:58 AM   #4
UFOmoplata
UFOmoplata's Avatar
Okay so, it's not a huge deal. Common, even.
Cool. Thank you, gents.
Old March 23rd, 2017, 08:37 AM   #5
It's normal for oil to be under the cover, but not common for it to be leaking out.
Still got this oil leak!! xXecuterXx2 1986 - 2007 Ninja 250R Tech Talk 11 August 11th, 2015 11:56 PM
Oil leak.... skilletmo 2008 - 2012 Ninja 250R Tech Talk 13 October 24th, 2014 09:31 PM
Oil leak Xaero 1986 - 2007 Ninja 250R Tech Talk 11 November 16th, 2013 06:58 PM
Oil Leak? Fakker 1986 - 2007 Ninja 250R Tech Talk 5 September 6th, 2013 06:38 AM
Oil Leak Help sjc88 1986 - 2007 Ninja 250R Tech Talk 7 December 29th, 2011 04:13 PM
