Old September 17th, 2013, 11:32 AM   #1
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Color swap?
My buddy is looking at buying a bike. He is looking at a slightly used 250 his only aversion is that it is 09 green color scheme. I kind of like the green colors schemes and mentioned that if the plastics and tank are in similar condition to my bikes that maybe we could do a swap.
IDK seems like it could be a fun idea to get a little change, no?
I mean I like my black SE but it's not like it makes me wet or anything ya know?
thoughts anyone?
Old September 17th, 2013, 11:38 AM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Same gen, same parts. Go for it.
If I had the pieces lying around, i'd love to swap between my candy lime green to the rich deep blue (Thunder blue?) color. In pictures I wasn't overwhelmed, but then I ended up with one of the cowls and felt it a sin to have sanded it down to repaint it. Love that color.
<-- Linky
Old September 17th, 2013, 11:55 AM   #3
Panda
not an actual panda
It's a good idea if you want to get a slower bike. Green bikes do 0-60 in roughly 7 minutes and 29 seconds. Downhill. With a tailwind.
Old September 17th, 2013, 12:02 PM   #4
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I didn't take that into consideration, but thinking if I put enough stickers on it I can make up the power difference
Old September 17th, 2013, 12:17 PM   #5
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
What would happen if one of you "have to lay it down"?
Better clarifiy those thing before swapping anything...
Otherwise, if you want to tackle the hassle to change color, why not...
Even simpler, swap the whole bike... I know yours is a 2012, but beside that, they're identical...
broken neck is offline   Reply With Quote
Old September 17th, 2013, 12:20 PM   #6
MR2Aaron
Motorcycle(s): 2003 Kawasaki Ninja 250
Why would this matter? If you crash, you get replacement parts and fix it.
MR2Aaron is offline   Reply With Quote
Old September 17th, 2013, 12:34 PM   #7
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I think the rules are simply understood, it's in the unwritten man code book.
Plus it could be a permanent switch, no going back.
and as far as swapping bikes it is reasonable thought but mods make them non identical
Old September 17th, 2013, 12:51 PM   #8
rasta
Your face
rasta's Avatar
You should only swap one side of the fairings. It's like having 2 bikes!!
Old September 17th, 2013, 12:53 PM   #9
NevadaWolf
NevadaWolf's Avatar
Then what? Paint half the tank, the front cowling, and front fender with a funky blend design down the middle? And a license plate HARVEY?
<-- Linky
Old September 17th, 2013, 12:56 PM   #10
MR2Aaron
Um... Yes!
Old September 17th, 2013, 01:33 PM   #11
rasta
Your face
rasta's Avatar
Lol I hadn't considered that far into it. But yes, that's a terrific idea
Old September 17th, 2013, 02:12 PM   #12
broken neck
Sometime, understood is not enough... Dont' know you or your friend, but better be clear if it's more of a loan than a permanent thing... Could lead to rude awakening in some case...
And, didn't knew that yours had some modifications...
So all is clear then...
carb swap james250ninja 2008 - 2012 Ninja 250R Tech Talk 2 April 17th, 2015 07:26 AM
I can't believe I am going to do this vehicle swap! verboten1 Off-Topic 49 October 28th, 2014 03:30 PM
exhaust swap ???? barnyardcivic 1986 - 2007 Ninja 250R Tech Talk 9 August 30th, 2014 12:44 PM
Fairing Swap anyone Bushmaster11B Items Wanted 16 November 18th, 2011 02:25 PM
engine swap almanza2010 2008 - 2012 Ninja 250R Tech Talk 12 March 16th, 2011 11:50 AM
