Old August 9th, 2011, 09:48 AM   #1
CmichRider
CmichRider's Avatar
Motorcycle(s): 2000 Ninja 250
Bike won't idle/stay running after carb removal
If you've been reading this section of the forum at all, no doubt you saw one of my threads in which I mentioned a problem with fuel leaking from the carbs. I removed the carbs, cleaned them, and then, after much hassle with an airbox boot, finally finished installing them yesterday.
Today I got the cables and hoses hooked up, and started the bike up. after cranking to fill the bowls, the bike started, but only by using the throttle. after, it required many small and weird adjustments of throttle and choke to keep it idling, and even then, stalled after a few minutes of warming up.
Whats up??? Im planning on using the bike tomorrow and need it to be in a reliable state. What should I check for?
CmichRider is offline   Reply With Quote
Old August 10th, 2011, 05:27 AM   #2
dubojr1
dubojr1's Avatar
Lets start with the idle adjustment. I assume the bike starts with the choke and then as your release the choke then it stalls.... Is this correct?
Old August 10th, 2011, 06:23 AM   #3
remember to get it fully warmed up before settling on an idle speed.
Old August 11th, 2011, 04:28 AM   #4
n4mwd
n4mwd's Avatar
If you have had the carbs off, did you resynchronize them? If they are badly out of sync, the engine will run rough because one cylinder is trying to run faster than the other one. If it stalls easy, you may need to crank up the idle speed temporarily until you complete the syncing process.
My Ninja Blog
Old August 11th, 2011, 09:52 AM   #5
d16soda
Motorcycle(s): 2005 Ninja 250
By the way it is easy to sync the carbs yourself. Adjust the throttle plates so they open the same amount. There is a screw directly in between them. I did this and, even though i had no way of measuring it, they are working well now.
Your bike will idle higher when it isn't warm. Hold the throttle if need be or set the idle really high until it is warm, then readjust the idle. You may not have cleaned the idle jets out right as well. Inside the carb there are 4 jets. There are two sticking out in the float bowls, and two that are recessed within the float bowls. Make sure you clean them all. If you have access to an air hose and an air nozzle, blow compressed air through them. Otherwise soak them in some carb/choke cleaner. Both methods have worked well for me. I even soaked them in seafoam once then blew on them with my mouth and it worked well.
d16soda is offline   Reply With Quote
Old August 11th, 2011, 09:55 AM   #6
dubojr1
dubojr1's Avatar
Carb syncing: http://www.ninjette.org/forums/showthread.php?t=9754
Carb cleaning: http://www.ninjette.org/forums/showthread.php?t=65198
Old August 11th, 2011, 01:26 PM   #7
n4mwd
n4mwd's Avatar
Here is one that is more specific to the pregen. But you'll still need to make your sync tool as defined in the newgen link above.
My Ninja Blog
Bike Won't Stay Running - Looking For Ideas aharnak 1986 - 2007 Ninja 250R Tech Talk 13 May 26th, 2013 01:23 PM
Valve adjustment and now bike won't stay idle har0ld 2008 - 2012 Ninja 250R Tech Talk 13 December 16th, 2012 06:16 PM
Bike won't stay running...HELP!! Pretzel 1986 - 2007 Ninja 250R Tech Talk 7 July 6th, 2012 07:22 PM
Won't idle or stay running haze5736 1986 - 2007 Ninja 250R Tech Talk 10 March 25th, 2012 12:49 PM
bike won't stay running cabeenaz 1986 - 2007 Ninja 250R Tech Talk 42 December 20th, 2011 02:05 PM
