Old August 7th, 2012, 07:52 AM   #1
nrninja
Motorcycle(s): '99 EX500 (road bike), '99 EX500 (race bike), '74 CB125S
Angry Replacing a broken choke lever
I've spent well over an hour trying to get this ****ing thing into the housing and onto the handlebar with no luck. Is there some secret voodoo magic I don't know about? Do I have to sell my soul?
PRE GEN IS BEST GEN
nrninja is offline   Reply With Quote
Old August 7th, 2012, 09:44 AM   #2
How are you doing it?
Old August 7th, 2012, 09:46 AM   #3
nrninja
Lining up the lever with the inner part of the housing, then trying to put the housing onto the bar.
PRE GEN IS BEST GEN
Old August 7th, 2012, 09:51 AM   #4
I did it not long ago, but I don't remember the details.
I do remember that I fixed the housing alone to the bar first; it was not something particularly difficult.
I was looking for some how-to article, but couldn't find any, sorry.
Old August 7th, 2012, 01:30 PM   #5
Monkeytofu
I told you bro
Monkeytofu's Avatar
The throttle and the choke housing require copious amounts of cussing, ritual sweating, and angered pacing. So in a sense, yes it does require voodoo magic and it may just be easier to sell your soul to get it closed.
However, when I put together my throttle body I've found that roughly shaking the two pieces together until they click together is the fastest method to use. You'll need to perfectly align the plastic pieces to fit on the bar, but a couple shakes should bring them together.
Old August 10th, 2012, 03:27 PM   #6
It's a lot easier on the bar than off. In fact, you'll just be cursing again as you install it if you do it before getting the whole assembly on the bar.
Old August 16th, 2012, 10:45 PM   #7
Jono
Jono's Avatar
It really isn't that difficult. Haha. Throttle side is a little tricky but after you have done it once it is purty easy. Just look at how it comes apart and put it back together the same way. I recently had to remove both because I put on clip-ons. Had no trouble getting everything back together. I guess I know my voodoo magic!
Old August 17th, 2012, 05:02 AM   #8
nrninja
I finally got the lever on. I had to roll back the handlebar grip and loosen the perch which holds the clutch lever to the handlebar to slide it out of the way. Only took about a minute once I'd created enough space on the handlebar to work with.
PRE GEN IS BEST GEN
Replacing a broken choke lever Trailerboy531 2008 - 2012 Ninja 250R Tech Talk 8 June 10th, 2012 11:45 AM
choke lever ninja_thresh_hold 2008 - 2012 Ninja 250R Tech Talk 2 March 29th, 2012 02:26 PM
Ebay lever broke my clutch lever mounting bolt! pilotgeorge747 2008 - 2012 Ninja 250R Tech Talk 8 December 22nd, 2011 07:22 AM
choke lever tinng321 2008 - 2012 Ninja 250R Tech Talk 6 August 1st, 2011 06:11 PM
Choke lever replacement shadowskater 2008 - 2012 Ninja 250R Tech Talk 4 July 20th, 2010 05:53 AM
