April 1st, 2009, 11:49 PM | #1 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R Posts: 52
Need help with throttle cables.
Ever since I did my Woodcraft Clip-On install, my throttle has been out of order.
Essentially, it will travel from one carb stop to the other, and back to idle, but it will also travel the other way. So I can twist the grip downwards from idle, as normal, but i can also twist it upwards from idle, and quite some ways too. I've taken the side cowl off and tried adjusting the nuts on the carb to move the cable up or down, but it didn't help, so I think i might have installed them wrong when I put everything back together.
'08 Ninja 250R: Yoshi Full System, HID's, FP Jet Kit, Snorkel removed, LED Brakelight, LED Footpeg Turnsignals, Zero Gravity SR Windscreen, Fender Eliminator, Solo Seat Cowl, Woodcraft Clip-Ons |
April 2nd, 2009, 09:09 AM | #2 |
Did you reinstall both cables, or only one?
April 2nd, 2009, 01:32 PM | #3 |
installed both of them. I would just like to see how the cables go into the throttle housing and how they attach to the grip. The service manual i got doesn't show it.
There is one cable that has a curved end to it and one with a straight end.
April 2nd, 2009, 01:48 PM | #4 |
do these help???
April 2nd, 2009, 02:47 PM | #5 |
wow, that is exactly what i needed! thank you very much
[RoadRUNNER] - Maintaining Clutch, Brake, Throttle Controls, and Cables | Ninjette Newsbot | Motorcycling News | 0 | March 11th, 2015 03:02 AM |
How do I adjust the throttle push-pull cables? | wtfh4xx | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 10th, 2011 05:45 AM |
Lubing the throttle cables | Boom King | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 26th, 2011 06:30 PM |
Throttle Cables... Do we really need 2? | kkim | 2008 - 2012 Ninja 250R Tech Talk | 23 | December 10th, 2008 08:47 AM |
